What are the best gaskets to use for the rocker covers on Warner 165's, and where can I get them. I have some orange silicone ones now, and I think I need to replace some of them -- I have a couple of leaks that did not fix themselves with a little tightening of the cover hold-down nuts. Are there better gaskets? Any advice/tricks I should know about selecting/installing/replacing/maintaining Warner rocker cover gaskets.
Re: Warner Rocker Cover Gaskets
'?Yeateryear 4322 Curtice Rd., Mason, MI 48854 Phone: (517) 676-4416 | Fax: (517) 676-3485 www.yesteryearaviation.com
Sent from my BlackBerry 10 smartphone. From: lowea1@comcast.net [fairchildclub]Sent: Friday, November 18, 2016 12:34To: fairchildclub@yahoogroups.comReply To: fairchildclub@yahoogroups.comSubject: [fairchildclub] Warner Rocker Cover Gaskets
John Duncan
' Let me see if I have some in stock. . . Will let you know.
Kindest regards, JD Warner Engines llc
