Re: F24 Tail Wheel Assembly
'Hi AllAs out plane gets ever closer to flight, one big thorn in our side is the tail wheel assembly. Our plane was a small handful of UC-61 that received the self centering trailing link (knuckle) tail wheel assembly. Believed to be installed in UK by the RAF. There does not appear to be any written Fairchild Documents indicating how many were installed, who the manufacture is/was. I have contacted UC-61 owners and museums around the world that have this particular style of tail wheel and all have responded the same way. No Manufacture Data plate, only a small stamped data plate with a drawing number, serial number and date. We have tried researching the DRWG# with out luck.
The Wheel itself is British made. the bead is 3 1/2 inches, the width is 4.00 and it holds a 10.00" tall tire. From pictures, I have seen 3 different manufactures (all out of business or no longer produce this size)1. Dunlop Tyre UK. 2. Air Ministry(AM) Tyre 3. Royal Aero Tyres. (Note: Tire is same size as some Marks of Spitfire) I purchased the standard 4.0 X 3.5 X 10.00 tire from Desser thinking it should fit......Wrong! the bead on these are 4.00 by 3.5 wide......
The Strut is Very heavy duty, self centering, fully hydraulic, NO spring inside. Our unit appears to be missing some of its internals.
Does anyone have a Standard F24 Tail Wheel assembly & Wheel that is spare to them and would like to sell or trade it please contact me.
Or if anyone out there knows anything about these "British Tail Wheels" and can assist me with internal parts PLEASE contact me.
If you need to see pictures, let me know and I will forward them on.
Any Ideas or assistance is greatly appreciated. You can contacted me direct if desired.
Thank You!
Jim ChybickiCo-Owner Midwest Aeronautique LLCUC-61K USAAF #43-14964 / RAF # HB690RampRatOne-at-yahoo-dot-com
Thank You!
Hi Jim
Do you have a picture of your tail wheel you can send me? I'd like to see if my configuration is the same as yours as I purchased a tyre from Dresser that didn't fit.
Many thanks
Richard
UK
From: fairchildclub@yahoogroups.com on behalf of james chybicki rampratone@yahoo.com [fairchildclub]
Sent: 03 November 2016 13:59
To: Fairchildclub
Subject: [fairchildclub] F24 Tail Wheel Assembly
Hi All As out plane gets ever closer to flight, one big thorn in our side is the tail wheel assembly. Our plane was a small handful of UC-61 that received the self centering trailing link (knuckle) tail wheel assembly. Believed to be installed in UK by the RAF. There does not appear to be any written Fairchild Documents indicating how many were installed, who the manufacture is/was. I have contacted UC-61 owners and museums around the world that have this particular style of tail wheel and all have responded the same way. No Manufacture Data plate, only a small stamped data plate with a drawing number, serial number and date. We have tried researching the DRWG# with out luck.
The Wheel itself is British made. the bead is 3 1/2 inches, the width is 4.00 and it holds a 10.00" tall tire. From pictures, I have seen 3 different manufactures (all out of business or no longer produce this size) 1. Dunlop Tyre UK. 2. Air Ministry(AM) Tyre 3. Royal Aero Tyres. (Note: Tire is same size as some Marks of Spitfire) I purchased the standard 4.0 X 3.5 X 10.00 tire from Desser thinking it should fit......Wrong! the bead on these are 4.00 by 3.5 wide......
Thank You!
Jim Chybicki Co-Owner Midwest Aeronautique LLC UC-61K USAAF #43-14964 / RAF # HB690 RampRatOne-at-yahoo-dot-com
Hi Jim
Many thanks
Richard
UK
To: Fairchildclub
Thank You!
'I have an early f-24 tail wheel assembly, along with a PT-19 tailwheel assembly both less the wheel itself. I’m asking 450.00 each.
Sent: Thursday, November 03, 2016 7:00 AM
To: Fairchildclub
Hi All
Thank You!
Jim Chybicki
To: Fairchildclub
Hi All
Thank You!
Jim Chybicki
'Richard,
Yours is the same as mine, G-BCBL, which is the standard fit - I got a tyre
from Watts which I think originated from Desser but did not fit the hub I
had which was of some obscure European origin with a Go-kart tyre on it. I
managed to find a serviceable hub in the States for it. The problem I do
have is Finding an inner tube with the correct valve placement on it.
Frank
Sent: Thursday, November 3, 2016 2:12 PM
Subject: Re: [fairchildclub] F24 Tail Wheel Assembly
Hi Jim
that didn't fit.
Many thanks
Richard
UK
To: Fairchildclub
Hi All
out luck.
if desired.
Thank You!
Jim Chybicki
Frank
Hi Jim
that didn't fit.
Many thanks
Richard
UK
To: Fairchildclub
Hi All
out luck.
if desired.
Thank You!
Jim Chybicki
Hi Frank
Thanks for your email. I also had the same problem with the valve and the 90 degree bend needed. I use a valve extension as it requires regular inflation!
How do you get on with the main brakes and binding? I find every couple of months a strip down clean and rubbing the pads with fine grit seems to sort it.
Kind Regards
Richard
From: fairchildclub@yahoogroups.com on behalf of 'Frank Cox' frankjcox44@gmail.com [fairchildclub]
Sent: 03 November 2016 14:26
Subject: RE: [fairchildclub] F24 Tail Wheel Assembly
Richard,
Frank
Hi Jim
that didn't fit.
Many thanks
Richard
UK
To: Fairchildclub
Hi All
out luck.
if desired.
Thank You!
Jim Chybicki
Hi Frank
Kind Regards
Richard
Richard,
Frank
Hi Jim
that didn't fit.
Many thanks
Richard
UK
To: Fairchildclub
Hi All
out luck.
if desired.
Thank You!
Jim Chybicki
What condition is the PT tailwheel assembly in?
Bill Johnson
WASP Museum
Sweetwater, TX
Sent: Thursday, November 03, 2016 9:22 AM
To: 'fairchildclub@yahoogroups.com'
To: Fairchildclub
Hi All
Thank You!
Jim Chybicki
Bill Johnson
WASP Museum
Sweetwater, TX
To: Fairchildclub
Hi All
Thank You!
Jim Chybicki
'Appears to be good condition. Give me your phone # and I will text you some pictures.
Sent: Thursday, November 03, 2016 7:53 AM
Bill Johnson
WASP Museum
Sweetwater, TX
To: Fairchildclub
Hi All
Thank You!
Jim Chybicki
Bill Johnson
WASP Museum
Sweetwater, TX
To: Fairchildclub
Hi All
Thank You!
Jim Chybicki
'RichardWith regard to the brakes ……………. Not flying yet – just got to cover the wings in the next few months – looking at mid to late next year to get air under the wheels without jacks – only 22 years up to now!Frank From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Sent: Thursday, November 3, 2016 2:45 PM
Hi Frank
Kind Regards
Richard
Virus-free. www.avast.com '
Hi Frank
Kind Regards
Richard
Hi Frank
I remember contacting you last year! I've been flying GRGUS all year and its been superb, a joy to fly. It'll be good to see another Argus on the scene! There's another Argus at my strip painted exactly the same, planning to get them both together next year.
Good luck with the rest of the project.
Regards
Richard
Sent: 03 November 2016 16:09
Richard With regard to the brakes ……………. Not flying yet – just got to cover the wings in the next few months – looking at mid to late next year to get air under the wheels without jacks – only 22 years up to now! Frank From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Hi Frank
Kind Regards
Richard
Hi Frank
Regards
Richard
Hi Frank
Kind Regards
Richard
'Hi RichardHere is our "RAF" style tail wheel
thanksJim
From: "Richard Ellingworth richardecho@hotmail.com [fairchildclub]"
Sent: Thursday, November 3, 2016 9:12 AM
Hi Jim
Many thanks
RichardUK
To: Fairchildclub
Subject: [fairchildclub] F24 Tail Wheel Assembly Hi AllAs out plane gets ever closer to flight, one big thorn in our side is the tail wheel assembly. Our plane was a small handful of UC-61 that received the self centering trailing link (knuckle) tail wheel assembly. Believed to be installed in UK by the RAF. There does not appear to be any written Fairchild Documents indicating how many were installed, who the manufacture is/was. I have contacted UC-61 owners and museums around the world that have this particular style of tail wheel and all have responded the same way. No Manufacture Data plate, only a small stamped data plate with a drawing number, serial number and date. We have tried researching the DRWG# with out luck.
Thank You!
#yiv3288794127 #yiv3288794127 -- #yiv3288794127ygrp-mkp {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}#yiv3288794127 #yiv3288794127ygrp-mkp hr {border:1px solid #d8d8d8;}#yiv3288794127 #yiv3288794127ygrp-mkp #yiv3288794127hd {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}#yiv3288794127 #yiv3288794127ygrp-mkp #yiv3288794127ads {margin-bottom:10px;}#yiv3288794127 #yiv3288794127ygrp-mkp .yiv3288794127ad {padding:0 0;}#yiv3288794127 #yiv3288794127ygrp-mkp .yiv3288794127ad p {margin:0;}#yiv3288794127 #yiv3288794127ygrp-mkp .yiv3288794127ad a {color:#0000ff;text-decoration:none;}#yiv3288794127 #yiv3288794127ygrp-sponsor #yiv3288794127ygrp-lc {font-family:Arial;}#yiv3288794127 #yiv3288794127ygrp-sponsor #yiv3288794127ygrp-lc #yiv3288794127hd {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}#yiv3288794127 #yiv3288794127ygrp-sponsor #yiv3288794127ygrp-lc .yiv3288794127ad {margin-bottom:10px;padding:0 0;}#yiv3288794127 #yiv3288794127actions {font-family:Verdana;font-size:11px;padding:10px 0;}#yiv3288794127 #yiv3288794127activity {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}#yiv3288794127 #yiv3288794127activity span {font-weight:700;}#yiv3288794127 #yiv3288794127activity span:first-child {text-transform:uppercase;}#yiv3288794127 #yiv3288794127activity span a {color:#5085b6;text-decoration:none;}#yiv3288794127 #yiv3288794127activity span span {color:#ff7900;}#yiv3288794127 #yiv3288794127activity span .yiv3288794127underline {text-decoration:underline;}#yiv3288794127 .yiv3288794127attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}#yiv3288794127 .yiv3288794127attach div a {text-decoration:none;}#yiv3288794127 .yiv3288794127attach img {border:none;padding-right:5px;}#yiv3288794127 .yiv3288794127attach label {display:block;margin-bottom:5px;}#yiv3288794127 .yiv3288794127attach label a {text-decoration:none;}#yiv3288794127 blockquote {margin:0 0 0 4px;}#yiv3288794127 .yiv3288794127bold {font-family:Arial;font-size:13px;font-weight:700;}#yiv3288794127 .yiv3288794127bold a {text-decoration:none;}#yiv3288794127 dd.yiv3288794127last p a {font-family:Verdana;font-weight:700;}#yiv3288794127 dd.yiv3288794127last p span {margin-right:10px;font-family:Verdana;font-weight:700;}#yiv3288794127 dd.yiv3288794127last p span.yiv3288794127yshortcuts {margin-right:0;}#yiv3288794127 div.yiv3288794127attach-table div div a {text-decoration:none;}#yiv3288794127 div.yiv3288794127attach-table {width:400px;}#yiv3288794127 div.yiv3288794127file-title a, #yiv3288794127 div.yiv3288794127file-title a:active, #yiv3288794127 div.yiv3288794127file-title a:hover, #yiv3288794127 div.yiv3288794127file-title a:visited {text-decoration:none;}#yiv3288794127 div.yiv3288794127photo-title a, #yiv3288794127 div.yiv3288794127photo-title a:active, #yiv3288794127 div.yiv3288794127photo-title a:hover, #yiv3288794127 div.yiv3288794127photo-title a:visited {text-decoration:none;}#yiv3288794127 div#yiv3288794127ygrp-mlmsg #yiv3288794127ygrp-msg p a span.yiv3288794127yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;}#yiv3288794127 .yiv3288794127green {color:#628c2a;}#yiv3288794127 .yiv3288794127MsoNormal {margin:0 0 0 0;}#yiv3288794127 o {font-size:0;}#yiv3288794127 #yiv3288794127photos div {float:left;width:72px;}#yiv3288794127 #yiv3288794127photos div div {border:1px solid #666666;height:62px;overflow:hidden;width:62px;}#yiv3288794127 #yiv3288794127photos div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}#yiv3288794127 #yiv3288794127reco-category {font-size:77%;}#yiv3288794127 #yiv3288794127reco-desc {font-size:77%;}#yiv3288794127 .yiv3288794127replbq {margin:4px;}#yiv3288794127 #yiv3288794127ygrp-actbar div a:first-child {margin-right:2px;padding-right:5px;}#yiv3288794127 #yiv3288794127ygrp-mlmsg {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}#yiv3288794127 #yiv3288794127ygrp-mlmsg table {font-size:inherit;font:100%;}#yiv3288794127 #yiv3288794127ygrp-mlmsg select, #yiv3288794127 input, #yiv3288794127 textarea {font:99% Arial, Helvetica, clean, sans-serif;}#yiv3288794127 #yiv3288794127ygrp-mlmsg pre, #yiv3288794127 code {font:115% monospace;}#yiv3288794127 #yiv3288794127ygrp-mlmsg * {line-height:1.22em;}#yiv3288794127 #yiv3288794127ygrp-mlmsg #yiv3288794127logo {padding-bottom:10px;}#yiv3288794127 #yiv3288794127ygrp-msg p a {font-family:Verdana;}#yiv3288794127 #yiv3288794127ygrp-msg p#yiv3288794127attach-count span {color:#1E66AE;font-weight:700;}#yiv3288794127 #yiv3288794127ygrp-reco #yiv3288794127reco-head {color:#ff7900;font-weight:700;}#yiv3288794127 #yiv3288794127ygrp-reco {margin-bottom:20px;padding:0px;}#yiv3288794127 #yiv3288794127ygrp-sponsor #yiv3288794127ov li a {font-size:130%;text-decoration:none;}#yiv3288794127 #yiv3288794127ygrp-sponsor #yiv3288794127ov li {font-size:77%;list-style-type:square;padding:6px 0;}#yiv3288794127 #yiv3288794127ygrp-sponsor #yiv3288794127ov ul {margin:0;padding:0 0 0 8px;}#yiv3288794127 #yiv3288794127ygrp-text {font-family:Georgia;}#yiv3288794127 #yiv3288794127ygrp-text p {margin:0 0 1em 0;}#yiv3288794127 #yiv3288794127ygrp-text tt {font-size:120%;}#yiv3288794127 #yiv3288794127ygrp-vital ul li:last-child {border-right:none !important;}#yiv3288794127
thanksJim
Hi Jim
Many thanks
RichardUK
To: Fairchildclub
Thank You!
