Re: PT landing gear torque link bushings
shergei2001
Post by shergei2001 »
'Does anyone know of a source for PT landing gear torque link bushings?  I need them for both ends of the links.
Pete Crawford
cagog
Post by cagog »
'Pete,I don't know of a source for purchase of finished bushings. I replaced my bushings per Service Bulletin 42-5-C. It calls out the bushing part numbers.The Fairchild drawing for the bushings has all the dimensions and material information needed to fabricate. I used Aluminum Bronze 954 that matches the U.T.S. called out on the drawing. Available with certification from Mcmaster Carr or Online Metals..'
Pete Crawford
Post by Pete Crawford »
Thanks so much for the information.  I did find the drawing.  Any suggestions on removal of the old ones?
Pete Crawford
On 10/30/2016 3:47 PM, cagog@yahoo.com [fairchildclub] wrote:
Pete, I don't know of a source for purchase of finished bushings. I replaced my bushings per Service Bulletin 42-5-C. It calls out the bushing part numbers.The Fairchild drawing for the bushings has all the dimensions and material information needed to fabricate. I used Aluminum Bronze 954 that matches the U.T.S. called out on the drawing. Available with certification from Mcmaster Carr or Online Metals..
