Has anyone installed the Airtex 345 ELT in the Fairchild 24? If so where did you put it and where did you install the antenna and ground plane?'
Re: Installing 406Mhz ELT
higham_jim
'You should be able to mount it to tube structure in the tail and make a ground plane and antenna mount inside the tail so as not to have an external antenna. AC 43.13 has examplesJim N81207
Sent from my U.S. Cellular® Smartphone
-------- Original message --------From: "george.leighton@me.com [fairchildclub]" Date: 9/16/16 12:40 PM (GMT-06:00) To: fairchildclub@yahoogroups.com Subject: [fairchildclub] Installing 406Mhz ELT
