I would like to confirm what master cyl rebuild kits are needed....I have heard several mentioned.
NAPA (Raybestos?) MK33
Wagner F-33108
Bendix 22976
Thanks, Steve in OK
PT-23 N64225'
PT series master cyl rebuild kits
Steve Link
I’ll try sending out an update on the master cyl kits again….Can anyone comment on the Wagner or Bendix kits? I picked all these up from past emails I’ve saved but they were never verified.NAPA UP-190 Repair Kits Not available! (Bob McCorkle used these on PT-19 cyls installed on his Kinner Sportster)
RockAuto (Raybestos) MK-190 (1” Diameter) Supposed to work on the PT series. Waiting on an update from Fritz.
Wagner F-33108Wagner F-11301
Bendix 22976
NAPA (Raybestos?) MK33 (1.25” in Diameter) Won’t work on PT series, Works on F-24 series?
Dorman TM3613 (1.25” in Diameter) The one I was told they would work on a PT-19/23/26. They won’t. Again for the F-24 series?
Thanks, Steve in OK
PT-23 N64225_'
Bendix 22976
Thanks, Steve in OK
PT-23 N64225_'
Steve Link
'Update On the Wagner F-11301
I’ll try sending out an update on the master cyl kits again…. I picked all these up from past emails I’ve saved but they were never verified.
Can anyone comment on the Wagner or Bendix kits?NAPA UP-190 Repair Kits Not available! (Bob McCorkle used these on PT-19 cyls installed on his Kinner Sportster)
Wagner F-33108Wagner F-11301 (1” Diameter) Mike Kelly said need to use the old plunger
Bendix 22976
Thanks, Steve in OK
PT-23 N64225_'
Bendix 22976
Thanks, Steve in OK
PT-23 N64225_'
