Re: Hayes banjo copper washers
dc871f
Post by dc871f »
Does anybody know the 2 sizes for the copper washers on the F24 banjo fitting?
Trying to order some but do not know the size.
Thanks a bunch gang.'
Fritz
Post by Fritz »
'If the F24 has the same brake banjo fittings as the PT-19, then the two sizes are available from Amazon.  1.     Use SUR & R Autoparts DMI 15mm and, 2.     Use 13mm x 18mm x1.5mm from UX CELL. They sell for about $6 to $10 for 20 pcs each  Fritz,San Diego.  From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Sent: Monday, July 18, 2016 9:47 PM
Subject: [fairchildclub] Hayes banjo copper washers
Buell Powell
Post by Buell Powell »
'       Napa part numbers 1244 and 1246 are the correct size.
dc871f
Post by dc871f »
'You guys make fixing this old gal a lot less stressful.
Thank you.'
