'Dear List,
I have a newly overhauled Ranger almost ready to start for the 1st time.
What's the best way to pre-oil? I have a pump I can use to pump into the
engine most readily at the oil pressure fitting. Is there a better
method or a better place to pump oil? In the past I've pre-oiled Lyc's
by removing a plug in each cyl and cranking. I always feel like I'm
doing the starter a disservice even though I crank a little then rest
for a good while, then continue until I finally see oil pressure. Still,
I don't like to stress the starter. What's the best way to do the Ranger?
David'
Re: pre-oil new Ranger
John Ellis
'Hi David,
After engine is mounted on test stand and ready start, the last thing I do
is prime engine.. I use a pressure tank and force 2 quarts 60 weight
non-detergent oil through oil pressure port..
This primes oil pump and provides oil for scavenger pump to pickup as
well as lubricates all engine bearings..
John Ellis
From: Ranchaero Wing Shop david@ranchaerowingshop.com [fairchildclub]
Sent: Wednesday, June 1, 2016 12:23 PM
Subject: [fairchildclub] pre-oil new Ranger
Dear List,
David
Posted by: Ranchaero Wing Shop
Yahoo Groups Links'
John Ellis
Dear List,
David
Yahoo Groups Links'
Ranchaero Wing Shop
' Perfect. Thanks John.
Hi David,
John Ellis
Dear List,
David
Posted by: Ranchaero Wing Shop david@ranchaerowingshop.com
Yahoo Groups Links
