Re: Brake assembly
Steve Link
Brake assembly
Post by Steve Link »
' Hey guys, I was going to replace the pads and now I understand that when replacing the pads then need to be turned to a certain dimension? I haven’t found the drawing yet for the dimension. I was mistakenly under the assumption that you just replaced them. Then I saw the T.O. and the statement "New blocks must be ground, concentric with center hole in brake on suitable machine to a diameter that will give proper clearance for brake in drum as specified on the blueprint of brake assembly."
A "suitable" machine? A lathe? At any rate, it would be much simpler if I could just swap out the assemblies….Do you know of anyone that sells them in the backing plate as an assembly ready to install?Thanks again, Steve in OK. '
Re: Brake assembly
Post by robert Etter »
'I found this in the AN 01-115CA-2, pg. 96, wheels and Brakes, 25-30 hr.  inspection, 2nd paragraph, " Check clearance between brake lining and brake drum.   Clearance should be .010 clearance."Bob
On Wednesday, March 30, 2016 3:50 PM, "Steve Link steven_link@msn.com [fairchildclub]" wrote:
A "suitable" machine? A lathe? At any rate, it would be much simpler if I could just swap out the assemblies….Do you know of anyone that sells them in the backing plate as an assembly ready to install?Thanks again, Steve in OK. #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220 -- #ygrps-yiv-333528965yiv0591726220ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-mkp #ygrps-yiv-333528965yiv0591726220hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-mkp #ygrps-yiv-333528965yiv0591726220ads { margin-bottom:10px;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-mkp .ygrps-yiv-333528965yiv0591726220ad { padding:0 0;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-mkp .ygrps-yiv-333528965yiv0591726220ad p { margin:0;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-mkp .ygrps-yiv-333528965yiv0591726220ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-sponsor #ygrps-yiv-333528965yiv0591726220ygrp-lc { font-family:Arial;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-sponsor #ygrps-yiv-333528965yiv0591726220ygrp-lc #ygrps-yiv-333528965yiv0591726220hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-sponsor #ygrps-yiv-333528965yiv0591726220ygrp-lc .ygrps-yiv-333528965yiv0591726220ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220activity span { font-weight:700;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220activity span:first-child { text-transform:uppercase;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220activity span span { color:#ff7900;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220activity span .ygrps-yiv-333528965yiv0591726220underline { text-decoration:underline;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 .ygrps-yiv-333528965yiv0591726220attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 .ygrps-yiv-333528965yiv0591726220attach div a { text-decoration:none;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 .ygrps-yiv-333528965yiv0591726220attach img { border:none;padding-right:5px;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 .ygrps-yiv-333528965yiv0591726220attach label { display:block;margin-bottom:5px;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 .ygrps-yiv-333528965yiv0591726220attach label a { text-decoration:none;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 blockquote { margin:0 0 0 4px;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 .ygrps-yiv-333528965yiv0591726220bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 .ygrps-yiv-333528965yiv0591726220bold a { text-decoration:none;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 dd.ygrps-yiv-333528965yiv0591726220last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 dd.ygrps-yiv-333528965yiv0591726220last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 dd.ygrps-yiv-333528965yiv0591726220last p span.ygrps-yiv-333528965yiv0591726220yshortcuts { margin-right:0;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 div.ygrps-yiv-333528965yiv0591726220attach-table div div a { text-decoration:none;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 div.ygrps-yiv-333528965yiv0591726220attach-table { width:400px;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 div.ygrps-yiv-333528965yiv0591726220file-title a, #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 div.ygrps-yiv-333528965yiv0591726220file-title a:active, #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 div.ygrps-yiv-333528965yiv0591726220file-title a:hover, #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 div.ygrps-yiv-333528965yiv0591726220file-title a:visited { text-decoration:none;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 div.ygrps-yiv-333528965yiv0591726220photo-title a, #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 div.ygrps-yiv-333528965yiv0591726220photo-title a:active, #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 div.ygrps-yiv-333528965yiv0591726220photo-title a:hover, #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 div.ygrps-yiv-333528965yiv0591726220photo-title a:visited { text-decoration:none;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 div#ygrps-yiv-333528965yiv0591726220ygrp-mlmsg #ygrps-yiv-333528965yiv0591726220ygrp-msg p a span.ygrps-yiv-333528965yiv0591726220yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 .ygrps-yiv-333528965yiv0591726220green { color:#628c2a;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 .ygrps-yiv-333528965yiv0591726220MsoNormal { margin:0 0 0 0;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 o { font-size:0;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220photos div { float:left;width:72px;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220reco-category { font-size:77%;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220reco-desc { font-size:77%;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 .ygrps-yiv-333528965yiv0591726220replbq { margin:4px;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-mlmsg select, #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 input, #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-mlmsg pre, #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 code { font:115% monospace;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-mlmsg #ygrps-yiv-333528965yiv0591726220logo { padding-bottom:10px;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-msg p#ygrps-yiv-333528965yiv0591726220attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-reco #ygrps-yiv-333528965yiv0591726220reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-sponsor #ygrps-yiv-333528965yiv0591726220ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-sponsor #ygrps-yiv-333528965yiv0591726220ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-sponsor #ygrps-yiv-333528965yiv0591726220ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-text { font-family:Georgia;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-text tt { font-size:120%;} #ygrps-yiv-333528965 #ygrps-yiv-333528965yiv0591726220 #ygrps-yiv-333528965yiv0591726220ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-333528965
Steve Link
Re: Brake assembly
' Man, the guys in this forum are the best.....
Thanks Bob!!!!!
Tailwinds, Steve in OK....
Date: Thu, 31 Mar 2016 01:05:27 +0000
Subject: Re: [fairchildclub] Brake assembly
Matthew & Patricia Banks
Re: Brake assembly
Post by Matthew & Patricia Banks »
'Steve,
A lot of folks complain about the capability of the Hayes expander brakes but I can tell you that I am perfectly happy with mine. The reason .... because I set them up properly from the beginning. I have 275 HP on the front of my F24 and the Hayes brakes hold the plane at high power settings with no problem. When I restored the brakes on my plane there were a lot of issues so I basically refurbished or replaced every part from the masters down to the weels. When it came to installing the brake pads, I wasn't aware of a procedure to fit them so I asked. Unfortunately what I got was, "take a wood rasp and just rake them down till they fit in the drum". I knew there was a 0.010" clearance requirement and that hand fitting was not going to produce an acceptable result in my book. Unaware that there was also a procedure, I took it upon myself to build up the brake assemblies, mount them on a southbend lathe, and machine them very precisely. The brakes must be machined specifically to the drum they are going in. As you know 0.010" is not much room for error. Mic the drum ID and machine the pads OD occordingly. You should be able to get any local machine shop to do this or maybe enlist some help from one of the forum members. Mine ended up dead on 0.010" clearance and they work great. Unfotunately this is not something you can just buy off the shelf as a ready to go assembly. It requires custom fitting for each installation. Also, make sure that the little spring plates between the pads are in good condition. These are what release the brakes. I had a few that had lost their heat treat or spring. I was able to re-heat treat mine and they work fine but test each one before installing.
Hope this helps.
Matt
F24W-46 / Jacobs 755B2
GA
On Wed, 3/30/16, Steve Link steven_link@msn.com [fairchildclub] wrote:
Subject: RE: [fairchildclub] Brake assembly
Date: Wednesday, March 30, 2016, 9:13 PM
best.....
Thanks Bob!!!!!
Date: Thu, 31
Subject: Re:
clearance."Bob
On Wednesday, March
[fairchildclub]"
Hey guys, I
OK.
Steve Link
Re: Brake assembly
' Matt, that is some reassuring info. After talking to several of you in the group, I am feeling much more confident. I have everything to rebuild them from the master cyl on down and plan to flush the system with denatured alcohol and probably fill with DOT 5 fluid....have not decided yet. While DOT 5 can't draw moisture thru the air, the one bad thing is any moisture that gets in can pool in a low spot causing corrosion. I really don't think that will be a problem as the PT is a hangared baby and not subjected to any type of moisture contamination like cars and motorcycles, etc. DOT 3/4/5.1 is glycol based and can draw moisture microscopically thru the lines and open master cylinder, but it won't pool. It also should be changed out every 3 to 5 years just to be safe and to prevent corrosion. So much info out there on this subject!!!!
What is most of the group running, Glycol based or Synthetic?
Again, thanks for everyone's help in this!!!!!
Date: Thu, 31 Mar 2016 12:32:26 +0000
  Steve,
Hope this helps.
Matt
GA
best.....
Thanks Bob!!!!!
Date: Thu, 31
Subject: Re:
clearance."Bob
On Wednesday, March
[fairchildclub]"
Hey guys, I
OK.
Re: Brake assembly
Post by Michael Denest »
'A personal safety item you should know.  When working with the brakes, keep in mind that the pads are asbestos and must be treated with caution when sanding or machining.  Use a proper mask with filters and a good dust collection system to collect the particles.
 Mike Denest
"He's crazy Lew, he builds toy airplanes!"
         - Frank Towns Flight of the Phoenix
On Thursday, March 31, 2016 9:25 AM, "Steve Link steven_link@msn.com [fairchildclub]" wrote:
  Steve,
Hope this helps.
Matt
GA
best.....
Thanks Bob!!!!!
Date: Thu, 31
Subject: Re:
clearance."Bob
On Wednesday, March
[fairchildclub]"
Hey guys, I
OK.
#ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711 -- #ygrps-yiv-1817837356yiv8922376711ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-mkp #ygrps-yiv-1817837356yiv8922376711hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-mkp #ygrps-yiv-1817837356yiv8922376711ads { margin-bottom:10px;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-mkp .ygrps-yiv-1817837356yiv8922376711ad { padding:0 0;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-mkp .ygrps-yiv-1817837356yiv8922376711ad p { margin:0;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-mkp .ygrps-yiv-1817837356yiv8922376711ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-sponsor #ygrps-yiv-1817837356yiv8922376711ygrp-lc { font-family:Arial;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-sponsor #ygrps-yiv-1817837356yiv8922376711ygrp-lc #ygrps-yiv-1817837356yiv8922376711hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-sponsor #ygrps-yiv-1817837356yiv8922376711ygrp-lc .ygrps-yiv-1817837356yiv8922376711ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711activity span { font-weight:700;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711activity span span { color:#ff7900;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711activity span .ygrps-yiv-1817837356yiv8922376711underline { text-decoration:underline;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 .ygrps-yiv-1817837356yiv8922376711attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 .ygrps-yiv-1817837356yiv8922376711attach div a { text-decoration:none;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 .ygrps-yiv-1817837356yiv8922376711attach img { border:none;padding-right:5px;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 .ygrps-yiv-1817837356yiv8922376711attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 .ygrps-yiv-1817837356yiv8922376711attach label a { text-decoration:none;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 .ygrps-yiv-1817837356yiv8922376711bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 .ygrps-yiv-1817837356yiv8922376711bold a { text-decoration:none;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 dd.ygrps-yiv-1817837356yiv8922376711last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 dd.ygrps-yiv-1817837356yiv8922376711last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 dd.ygrps-yiv-1817837356yiv8922376711last p span.ygrps-yiv-1817837356yiv8922376711yshortcuts { margin-right:0;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 div.ygrps-yiv-1817837356yiv8922376711attach-table div div a { text-decoration:none;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 div.ygrps-yiv-1817837356yiv8922376711attach-table { width:400px;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 div.ygrps-yiv-1817837356yiv8922376711file-title a, #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 div.ygrps-yiv-1817837356yiv8922376711file-title a:active, #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 div.ygrps-yiv-1817837356yiv8922376711file-title a:hover, #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 div.ygrps-yiv-1817837356yiv8922376711file-title a:visited { text-decoration:none;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 div.ygrps-yiv-1817837356yiv8922376711photo-title a, #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 div.ygrps-yiv-1817837356yiv8922376711photo-title a:active, #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 div.ygrps-yiv-1817837356yiv8922376711photo-title a:hover, #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 div.ygrps-yiv-1817837356yiv8922376711photo-title a:visited { text-decoration:none;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 div#ygrps-yiv-1817837356yiv8922376711ygrp-mlmsg #ygrps-yiv-1817837356yiv8922376711ygrp-msg p a span.ygrps-yiv-1817837356yiv8922376711yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 .ygrps-yiv-1817837356yiv8922376711green { color:#628c2a;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 .ygrps-yiv-1817837356yiv8922376711MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 o { font-size:0;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711photos div { float:left;width:72px;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711reco-category { font-size:77%;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711reco-desc { font-size:77%;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 .ygrps-yiv-1817837356yiv8922376711replbq { margin:4px;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-mlmsg select, #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 input, #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-mlmsg pre, #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 code { font:115% monospace;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-mlmsg #ygrps-yiv-1817837356yiv8922376711logo { padding-bottom:10px;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-msg p#ygrps-yiv-1817837356yiv8922376711attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-reco #ygrps-yiv-1817837356yiv8922376711reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-sponsor #ygrps-yiv-1817837356yiv8922376711ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-sponsor #ygrps-yiv-1817837356yiv8922376711ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-sponsor #ygrps-yiv-1817837356yiv8922376711ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-text { font-family:Georgia;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-text tt { font-size:120%;} #ygrps-yiv-1817837356 #ygrps-yiv-1817837356yiv8922376711 #ygrps-yiv-1817837356yiv8922376711ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1817837356
Richard Ellingworth
Re: Brake assembly
Post by Richard Ellingworth »
' Some really handy advice on looking after the brakes, mine keep seizing up so I'll definitely be looking at these points!
Many thanks
Richard
GRGUS
UK
Date: Thu, 31 Mar 2016 13:38:58 +0000
 Mike Denest
  Steve,
Hope this helps.
Matt
GA
best.....
Thanks Bob!!!!!
Date: Thu, 31
Subject: Re:
clearance."Bob
On Wednesday, March
[fairchildclub]"
Hey guys, I
OK.
Steve Link
Re: Brake assembly
' Well dang, closest I have to that is the E&M manual 01-115GA-2 with no inspection criteria. Just talks about "proper clearance for brake in drum as specified on the blue print of brake assembly"....
I would hope that the clearance is the same in the PT as it is in the UC-61 as they are very similar systems....
Date: Thu, 31
Subject: Re:
clearance."Bob
On Wednesday, March
[fairchildclub]"
Hey guys, I
OK.
james chybicki
Re: Brake assembly
Post by james chybicki »
'Hi SteveI can send you a copy in PDF
Let me know
thanksJIM ChybickiMidwest Aeronautique LLCUC-61K 43-14964 / RAF HB690
From: "Steve Link steven_link@msn.com [fairchildclub]"
Sent: Thursday, March 31, 2016 11:50 AM
Date: Thu, 31
Subject: Re:
clearance."Bob
On Wednesday, March
[fairchildclub]"
Hey guys, I
OK.
#ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926 -- #ygrps-yiv-34006601yiv7661602926ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-mkp #ygrps-yiv-34006601yiv7661602926hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-mkp #ygrps-yiv-34006601yiv7661602926ads { margin-bottom:10px;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-mkp .ygrps-yiv-34006601yiv7661602926ad { padding:0 0;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-mkp .ygrps-yiv-34006601yiv7661602926ad p { margin:0;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-mkp .ygrps-yiv-34006601yiv7661602926ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-sponsor #ygrps-yiv-34006601yiv7661602926ygrp-lc { font-family:Arial;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-sponsor #ygrps-yiv-34006601yiv7661602926ygrp-lc #ygrps-yiv-34006601yiv7661602926hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-sponsor #ygrps-yiv-34006601yiv7661602926ygrp-lc .ygrps-yiv-34006601yiv7661602926ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926activity span { font-weight:700;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926activity span:first-child { text-transform:uppercase;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926activity span span { color:#ff7900;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926activity span .ygrps-yiv-34006601yiv7661602926underline { text-decoration:underline;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 .ygrps-yiv-34006601yiv7661602926attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 .ygrps-yiv-34006601yiv7661602926attach div a { text-decoration:none;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 .ygrps-yiv-34006601yiv7661602926attach img { border:none;padding-right:5px;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 .ygrps-yiv-34006601yiv7661602926attach label { display:block;margin-bottom:5px;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 .ygrps-yiv-34006601yiv7661602926attach label a { text-decoration:none;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 blockquote { margin:0 0 0 4px;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 .ygrps-yiv-34006601yiv7661602926bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 .ygrps-yiv-34006601yiv7661602926bold a { text-decoration:none;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 dd.ygrps-yiv-34006601yiv7661602926last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 dd.ygrps-yiv-34006601yiv7661602926last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 dd.ygrps-yiv-34006601yiv7661602926last p span.ygrps-yiv-34006601yiv7661602926yshortcuts { margin-right:0;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 div.ygrps-yiv-34006601yiv7661602926attach-table div div a { text-decoration:none;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 div.ygrps-yiv-34006601yiv7661602926attach-table { width:400px;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 div.ygrps-yiv-34006601yiv7661602926file-title a, #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 div.ygrps-yiv-34006601yiv7661602926file-title a:active, #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 div.ygrps-yiv-34006601yiv7661602926file-title a:hover, #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 div.ygrps-yiv-34006601yiv7661602926file-title a:visited { text-decoration:none;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 div.ygrps-yiv-34006601yiv7661602926photo-title a, #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 div.ygrps-yiv-34006601yiv7661602926photo-title a:active, #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 div.ygrps-yiv-34006601yiv7661602926photo-title a:hover, #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 div.ygrps-yiv-34006601yiv7661602926photo-title a:visited { text-decoration:none;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 div#ygrps-yiv-34006601yiv7661602926ygrp-mlmsg #ygrps-yiv-34006601yiv7661602926ygrp-msg p a span.ygrps-yiv-34006601yiv7661602926yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 .ygrps-yiv-34006601yiv7661602926green { color:#628c2a;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 .ygrps-yiv-34006601yiv7661602926MsoNormal { margin:0 0 0 0;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 o { font-size:0;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926photos div { float:left;width:72px;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926reco-category { font-size:77%;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926reco-desc { font-size:77%;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 .ygrps-yiv-34006601yiv7661602926replbq { margin:4px;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-mlmsg select, #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 input, #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-mlmsg pre, #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 code { font:115% monospace;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-mlmsg #ygrps-yiv-34006601yiv7661602926logo { padding-bottom:10px;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-msg p#ygrps-yiv-34006601yiv7661602926attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-reco #ygrps-yiv-34006601yiv7661602926reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-sponsor #ygrps-yiv-34006601yiv7661602926ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-sponsor #ygrps-yiv-34006601yiv7661602926ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-sponsor #ygrps-yiv-34006601yiv7661602926ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-text { font-family:Georgia;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-text tt { font-size:120%;} #ygrps-yiv-34006601 #ygrps-yiv-34006601yiv7661602926 #ygrps-yiv-34006601yiv7661602926ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-34006601
Steve Link
Re: Brake assembly
' Jim, that would be great!!!!!!!!!
Date: Thu, 31 Mar 2016 17:43:36 +0000
Let me know
Date: Thu, 31
Subject: Re:
clearance."Bob
On Wednesday, March
[fairchildclub]"
Hey guys, I
OK.
