'Dear List,
 I'm reconnecting wires and tubes, etc, to the newly rebuilt Ranger
 engine, and see there are 3 wires from the mag switch - Left, Right, and
 Ground. L & R are clear enough where they connect, but it's not clear
 where the ground should connect. The wiring diagram shows it going to
 ground, and the wire length is 50-1/2". It would seem it can be
 connected almost anywhere on the engine and function as ground, but I
 expect there is a standard location where this wire likes to be
 connected. Can anyone please advise?
 David
 https://www.avast.com/antivirus'
						Ranger Vacuum Pump
				tomatotruck993
Re: Mag switch wiring PT-19
'The preferred location for that ground is the magneto housing. 2nd choice is the engine case. I do not like grounding to the airframe then hoping the engine grounded through it's mount to the same airframe stays grounded.'
				Ranchaero Wing Shop
'                   That makes perfect sense. Thanks!
On 1/22/2016 9:30 PM, wsknettl@centurytel.net [fairchildclub] wrote:
      	 		 			 This email has been sent from a virus-free computer protected by Avast.
www.avast.com '
 		 		This email has been sent from a virus-free computer protected by Avast. www.avast.com '
Ranger Vacuum Pump
Been chasing high oil consumption for quite awhile on my Fairchild. Just installed rebuilt Ranger 200 hp (8.1 hrs). Noting excessive oil on belly below vacuum pump vent/drain.
Recommendations on pump rebuild shop, or replacement yellow-tag?
Bill C.
281-222-6938
NC28685
Bill C.
281-222-6938
NC28685
