Re: Ranger 6-410B-2A performance issue
'Hi,
I’m looking for someone that knows his or her way around the Ranger engines type: 6-410B-2A 165HP 6 cylinder in-line engines.
We operate an Fairchild 24R9 with a 6-410B-2A engine.
As far as I can remember, we had troubles with engine performance, so after a while, they called me to take a closer look in relation with the poor engine performance.
I quickly find out that the 6-410B-2A data plate on the engine, had different valve opening and closing settings that did not make any sense if I took a good look in the overhaul books I have.
I than found out that I have an camshaft installed that cooperated with the data in the overhaul manual. Basically, the 6-410B-2 & -3 engines have a valve opening cycle bigger that previous types.
So my question here is where is the missing link regarding my data plate on the engine telling me a whole other story?
Can someone share some light on this?
My data plate on the engine tells me:
Inlet opens 3deg. Early / closes 51deg. Late
Exhaust opens 55deg. Early / closes 20deg. Late
Intake remains open: 234 deg.
Exhaust remains open: 255 deg.
The overhaul manual tells me:
Inlet opens 15deg. Before TDC / closes 65deg. After BDC
Exhaust opens 70deg. Before BDC / closes 30deg. After BDC
Intake remains open: 260 deg.
Exhaust remains open: 280 deg.
Eventually I developed tooling to adjust the camshaft on the Ranger engine. With laser guiding I was able to adjust it to within halve of a degree i.a.w. information in the overhaul manual.
But poor engine performance still remains.
Any idea’s or shared experiences?
Greetings from the Netherlands.
Melvin Joseph
Melvin Joseph
gtg15751@yahoo.com
'Ck with Joe Denest, 6103997028. Maybe all 440's covert to 175 & 200 with piston/valve change(new timing paramiters too
Sent from my BlackBerry 10 smartphone. From: Melvin J melvin_j86@yahoo.com [fairchildclub]Sent: Tuesday, January 19, 2016 12:06To: fairchildclub@yahoogroups.comReply To: fairchildclub@yahoogroups.comSubject: [fairchildclub] Ranger 6-410B-2A performance issue
Hi,
Melvin Joseph
Hi,
Melvin Joseph
'The 6-440 and 6-410 are two totally different engines. 6-410 cylinder diameters are 4.00 inches while the 6-440 is 4.125 inch. I don't have the 6-440 manual handy but the intake cam timing varies between the 175 and 200hp models.
Are you sure you have the correct cam installed? You said nothing about magneto timing. Having the spark retarted or advanced from optimum will affect performance.
Mike Denest
Sent from my iPhone
Hi,
Melvin Joseph
Mike Denest
Sent from my iPhone
Hi,
Melvin Joseph
Ranchaero Wing Shop
Looking for a Warner 8 bolt prop hub for Ranger PT-19
'Looking for a Warner 8 bolt hub for a Ranger PT-19. I believe the number
is #7900. It looks like the one in the Fairchild parts catalog.
The one that came with the project has been chrome-plated which I
believe renders it not-airworthy. Somebody please correct me if I'm wrong.
David McCord
Chico Ranchaero Airport
530-743-0900
David McCord
530-743-0900
'We have the 165HP version,
We checked timing and all other issue's / components that could relate to the performance of the engine.But I am sure about the camshaft settings versus the manual, and the camshaft installed in the engine, but not on my data plate of the engine, it tells me a whole other story.
I have a picture of the data plate, which does not make any sense to me or relate to the information of the overhaul manual.
On Wednesday, January 20, 2016 12:08 AM, "Michael Denest mjd12k@yahoo.com [fairchildclub]" wrote:
Mike Denest
Sent from my iPhone
Mike Denest
Sent from my iPhone
#ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215 -- #ygrps-yiv-1312552959yiv4748691215ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-mkp #ygrps-yiv-1312552959yiv4748691215hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-mkp #ygrps-yiv-1312552959yiv4748691215ads { margin-bottom:10px;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-mkp .ygrps-yiv-1312552959yiv4748691215ad { padding:0 0;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-mkp .ygrps-yiv-1312552959yiv4748691215ad p { margin:0;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-mkp .ygrps-yiv-1312552959yiv4748691215ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-sponsor #ygrps-yiv-1312552959yiv4748691215ygrp-lc { font-family:Arial;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-sponsor #ygrps-yiv-1312552959yiv4748691215ygrp-lc #ygrps-yiv-1312552959yiv4748691215hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-sponsor #ygrps-yiv-1312552959yiv4748691215ygrp-lc .ygrps-yiv-1312552959yiv4748691215ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215activity span { font-weight:700;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215activity span span { color:#ff7900;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215activity span .ygrps-yiv-1312552959yiv4748691215underline { text-decoration:underline;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 .ygrps-yiv-1312552959yiv4748691215attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 .ygrps-yiv-1312552959yiv4748691215attach div a { text-decoration:none;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 .ygrps-yiv-1312552959yiv4748691215attach img { border:none;padding-right:5px;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 .ygrps-yiv-1312552959yiv4748691215attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 .ygrps-yiv-1312552959yiv4748691215attach label a { text-decoration:none;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 .ygrps-yiv-1312552959yiv4748691215bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 .ygrps-yiv-1312552959yiv4748691215bold a { text-decoration:none;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 dd.ygrps-yiv-1312552959yiv4748691215last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 dd.ygrps-yiv-1312552959yiv4748691215last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 dd.ygrps-yiv-1312552959yiv4748691215last p span.ygrps-yiv-1312552959yiv4748691215yshortcuts { margin-right:0;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 div.ygrps-yiv-1312552959yiv4748691215attach-table div div a { text-decoration:none;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 div.ygrps-yiv-1312552959yiv4748691215attach-table { width:400px;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 div.ygrps-yiv-1312552959yiv4748691215file-title a, #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 div.ygrps-yiv-1312552959yiv4748691215file-title a:active, #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 div.ygrps-yiv-1312552959yiv4748691215file-title a:hover, #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 div.ygrps-yiv-1312552959yiv4748691215file-title a:visited { text-decoration:none;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 div.ygrps-yiv-1312552959yiv4748691215photo-title a, #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 div.ygrps-yiv-1312552959yiv4748691215photo-title a:active, #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 div.ygrps-yiv-1312552959yiv4748691215photo-title a:hover, #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 div.ygrps-yiv-1312552959yiv4748691215photo-title a:visited { text-decoration:none;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 div#ygrps-yiv-1312552959yiv4748691215ygrp-mlmsg #ygrps-yiv-1312552959yiv4748691215ygrp-msg p a span.ygrps-yiv-1312552959yiv4748691215yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 .ygrps-yiv-1312552959yiv4748691215green { color:#628c2a;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 .ygrps-yiv-1312552959yiv4748691215MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 o { font-size:0;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215photos div { float:left;width:72px;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215reco-category { font-size:77%;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215reco-desc { font-size:77%;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 .ygrps-yiv-1312552959yiv4748691215replbq { margin:4px;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-mlmsg select, #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 input, #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-mlmsg pre, #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 code { font:115% monospace;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-mlmsg #ygrps-yiv-1312552959yiv4748691215logo { padding-bottom:10px;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-msg p#ygrps-yiv-1312552959yiv4748691215attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-reco #ygrps-yiv-1312552959yiv4748691215reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-sponsor #ygrps-yiv-1312552959yiv4748691215ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-sponsor #ygrps-yiv-1312552959yiv4748691215ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-sponsor #ygrps-yiv-1312552959yiv4748691215ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-text { font-family:Georgia;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-text tt { font-size:120%;} #ygrps-yiv-1312552959 #ygrps-yiv-1312552959yiv4748691215 #ygrps-yiv-1312552959yiv4748691215ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1312552959Ck with Joe Denest, 6103997028. Maybe all 440's covert to 175 & 200 with piston/valve change(new timing paramiters too
Hi,
Melvin Joseph
'Ok, does the manual state static ground RPM? The 6-440 turns 1960 rpm's with an 86R61 prop. What is your prop diameter and pitch?
I have a copy of the CAA ATC 187 document which quotes ignition timing at 30 degrees BTC while the -B3 engine is timed at 25 degrees BTC. Can you send me the picture of your data plate? Don't attach it here as attachments are blocked. Send it to mjd12k@yahoo.com.
Specification A-706 for the F24R-9 allows a prop diameter up to 106 inches with the Ranger 6-410-B1, -B1A, -B2, -B2A or -B2B engine. The -B3 engine is installed on the F24R-40. The prop diameter is limited to an 86R58 prop.
Mike Denest
"He's crazy Lew, he builds toy airplanes!"
- Frank Towns Flight of the Phoenix
On Wednesday, January 20, 2016 6:19 PM, "Melvin J melvin_j86@yahoo.com [fairchildclub]" wrote:
Mike Denest
Sent from my iPhone
#ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199 -- #ygrps-yiv-601201952yiv2444057199ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-mkp #ygrps-yiv-601201952yiv2444057199hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-mkp #ygrps-yiv-601201952yiv2444057199ads { margin-bottom:10px;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-mkp .ygrps-yiv-601201952yiv2444057199ad { padding:0 0;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-mkp .ygrps-yiv-601201952yiv2444057199ad p { margin:0;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-mkp .ygrps-yiv-601201952yiv2444057199ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-sponsor #ygrps-yiv-601201952yiv2444057199ygrp-lc { font-family:Arial;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-sponsor #ygrps-yiv-601201952yiv2444057199ygrp-lc #ygrps-yiv-601201952yiv2444057199hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-sponsor #ygrps-yiv-601201952yiv2444057199ygrp-lc .ygrps-yiv-601201952yiv2444057199ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199activity span { font-weight:700;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199activity span:first-child { text-transform:uppercase;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199activity span span { color:#ff7900;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199activity span .ygrps-yiv-601201952yiv2444057199underline { text-decoration:underline;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 .ygrps-yiv-601201952yiv2444057199attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 .ygrps-yiv-601201952yiv2444057199attach div a { text-decoration:none;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 .ygrps-yiv-601201952yiv2444057199attach img { border:none;padding-right:5px;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 .ygrps-yiv-601201952yiv2444057199attach label { display:block;margin-bottom:5px;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 .ygrps-yiv-601201952yiv2444057199attach label a { text-decoration:none;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 blockquote { margin:0 0 0 4px;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 .ygrps-yiv-601201952yiv2444057199bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 .ygrps-yiv-601201952yiv2444057199bold a { text-decoration:none;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 dd.ygrps-yiv-601201952yiv2444057199last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 dd.ygrps-yiv-601201952yiv2444057199last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 dd.ygrps-yiv-601201952yiv2444057199last p span.ygrps-yiv-601201952yiv2444057199yshortcuts { margin-right:0;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 div.ygrps-yiv-601201952yiv2444057199attach-table div div a { text-decoration:none;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 div.ygrps-yiv-601201952yiv2444057199attach-table { width:400px;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 div.ygrps-yiv-601201952yiv2444057199file-title a, #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 div.ygrps-yiv-601201952yiv2444057199file-title a:active, #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 div.ygrps-yiv-601201952yiv2444057199file-title a:hover, #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 div.ygrps-yiv-601201952yiv2444057199file-title a:visited { text-decoration:none;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 div.ygrps-yiv-601201952yiv2444057199photo-title a, #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 div.ygrps-yiv-601201952yiv2444057199photo-title a:active, #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 div.ygrps-yiv-601201952yiv2444057199photo-title a:hover, #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 div.ygrps-yiv-601201952yiv2444057199photo-title a:visited { text-decoration:none;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 div#ygrps-yiv-601201952yiv2444057199ygrp-mlmsg #ygrps-yiv-601201952yiv2444057199ygrp-msg p a span.ygrps-yiv-601201952yiv2444057199yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 .ygrps-yiv-601201952yiv2444057199green { color:#628c2a;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 .ygrps-yiv-601201952yiv2444057199MsoNormal { margin:0 0 0 0;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 o { font-size:0;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199photos div { float:left;width:72px;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199reco-category { font-size:77%;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199reco-desc { font-size:77%;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 .ygrps-yiv-601201952yiv2444057199replbq { margin:4px;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-mlmsg select, #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 input, #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-mlmsg pre, #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 code { font:115% monospace;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-mlmsg #ygrps-yiv-601201952yiv2444057199logo { padding-bottom:10px;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-msg p#ygrps-yiv-601201952yiv2444057199attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-reco #ygrps-yiv-601201952yiv2444057199reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-sponsor #ygrps-yiv-601201952yiv2444057199ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-sponsor #ygrps-yiv-601201952yiv2444057199ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-sponsor #ygrps-yiv-601201952yiv2444057199ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-text { font-family:Georgia;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-text tt { font-size:120%;} #ygrps-yiv-601201952 #ygrps-yiv-601201952yiv2444057199 #ygrps-yiv-601201952yiv2444057199ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-601201952
Mike Denest
Mike Denest
Sent from my iPhone
Hi,
Melvin Joseph
'Did some quick research - all 6-410 models use 4.125" bore diameter by 5.125 " stroke cylinders while the 6-440 is a 4.125" bore and 5.50" stroke. I was thinking of the 6-390 which is a 4.00" diameter.
Just curious, have you measured the stroke?
Mike Denest
On Wednesday, January 20, 2016 8:54 PM, "Michael Denest mjd12k@yahoo.com [fairchildclub]" wrote:
Mike Denest
Mike Denest
Sent from my iPhone
#ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991 -- #ygrps-yiv-2077646578yiv9119056991ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-mkp #ygrps-yiv-2077646578yiv9119056991hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-mkp #ygrps-yiv-2077646578yiv9119056991ads { margin-bottom:10px;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-mkp .ygrps-yiv-2077646578yiv9119056991ad { padding:0 0;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-mkp .ygrps-yiv-2077646578yiv9119056991ad p { margin:0;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-mkp .ygrps-yiv-2077646578yiv9119056991ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-sponsor #ygrps-yiv-2077646578yiv9119056991ygrp-lc { font-family:Arial;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-sponsor #ygrps-yiv-2077646578yiv9119056991ygrp-lc #ygrps-yiv-2077646578yiv9119056991hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-sponsor #ygrps-yiv-2077646578yiv9119056991ygrp-lc .ygrps-yiv-2077646578yiv9119056991ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991activity span { font-weight:700;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991activity span:first-child { text-transform:uppercase;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991activity span span { color:#ff7900;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991activity span .ygrps-yiv-2077646578yiv9119056991underline { text-decoration:underline;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 .ygrps-yiv-2077646578yiv9119056991attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 .ygrps-yiv-2077646578yiv9119056991attach div a { text-decoration:none;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 .ygrps-yiv-2077646578yiv9119056991attach img { border:none;padding-right:5px;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 .ygrps-yiv-2077646578yiv9119056991attach label { display:block;margin-bottom:5px;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 .ygrps-yiv-2077646578yiv9119056991attach label a { text-decoration:none;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 blockquote { margin:0 0 0 4px;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 .ygrps-yiv-2077646578yiv9119056991bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 .ygrps-yiv-2077646578yiv9119056991bold a { text-decoration:none;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 dd.ygrps-yiv-2077646578yiv9119056991last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 dd.ygrps-yiv-2077646578yiv9119056991last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 dd.ygrps-yiv-2077646578yiv9119056991last p span.ygrps-yiv-2077646578yiv9119056991yshortcuts { margin-right:0;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 div.ygrps-yiv-2077646578yiv9119056991attach-table div div a { text-decoration:none;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 div.ygrps-yiv-2077646578yiv9119056991attach-table { width:400px;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 div.ygrps-yiv-2077646578yiv9119056991file-title a, #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 div.ygrps-yiv-2077646578yiv9119056991file-title a:active, #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 div.ygrps-yiv-2077646578yiv9119056991file-title a:hover, #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 div.ygrps-yiv-2077646578yiv9119056991file-title a:visited { text-decoration:none;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 div.ygrps-yiv-2077646578yiv9119056991photo-title a, #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 div.ygrps-yiv-2077646578yiv9119056991photo-title a:active, #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 div.ygrps-yiv-2077646578yiv9119056991photo-title a:hover, #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 div.ygrps-yiv-2077646578yiv9119056991photo-title a:visited { text-decoration:none;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 div#ygrps-yiv-2077646578yiv9119056991ygrp-mlmsg #ygrps-yiv-2077646578yiv9119056991ygrp-msg p a span.ygrps-yiv-2077646578yiv9119056991yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 .ygrps-yiv-2077646578yiv9119056991green { color:#628c2a;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 .ygrps-yiv-2077646578yiv9119056991MsoNormal { margin:0 0 0 0;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 o { font-size:0;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991photos div { float:left;width:72px;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991reco-category { font-size:77%;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991reco-desc { font-size:77%;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 .ygrps-yiv-2077646578yiv9119056991replbq { margin:4px;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-mlmsg select, #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 input, #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-mlmsg pre, #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 code { font:115% monospace;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-mlmsg #ygrps-yiv-2077646578yiv9119056991logo { padding-bottom:10px;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-msg p#ygrps-yiv-2077646578yiv9119056991attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-reco #ygrps-yiv-2077646578yiv9119056991reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-sponsor #ygrps-yiv-2077646578yiv9119056991ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-sponsor #ygrps-yiv-2077646578yiv9119056991ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-sponsor #ygrps-yiv-2077646578yiv9119056991ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-text { font-family:Georgia;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-text tt { font-size:120%;} #ygrps-yiv-2077646578 #ygrps-yiv-2077646578yiv9119056991 #ygrps-yiv-2077646578yiv9119056991ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-2077646578
Mike Denest
Mike Denest
Mike Denest
Sent from my iPhone
Hi,
Melvin Joseph
'Another question - what overhaul manual are you using?
Mike Denest
On Thursday, January 21, 2016 11:28 AM, "Michael Denest mjd12k@yahoo.com [fairchildclub]" wrote:
Mike Denest
Mike Denest
Mike Denest
Sent from my iPhone
#ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842 -- #ygrps-yiv-1976662402yiv9537662842ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-mkp #ygrps-yiv-1976662402yiv9537662842hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-mkp #ygrps-yiv-1976662402yiv9537662842ads { margin-bottom:10px;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-mkp .ygrps-yiv-1976662402yiv9537662842ad { padding:0 0;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-mkp .ygrps-yiv-1976662402yiv9537662842ad p { margin:0;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-mkp .ygrps-yiv-1976662402yiv9537662842ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-sponsor #ygrps-yiv-1976662402yiv9537662842ygrp-lc { font-family:Arial;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-sponsor #ygrps-yiv-1976662402yiv9537662842ygrp-lc #ygrps-yiv-1976662402yiv9537662842hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-sponsor #ygrps-yiv-1976662402yiv9537662842ygrp-lc .ygrps-yiv-1976662402yiv9537662842ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842activity span { font-weight:700;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842activity span span { color:#ff7900;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842activity span .ygrps-yiv-1976662402yiv9537662842underline { text-decoration:underline;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 .ygrps-yiv-1976662402yiv9537662842attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 .ygrps-yiv-1976662402yiv9537662842attach div a { text-decoration:none;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 .ygrps-yiv-1976662402yiv9537662842attach img { border:none;padding-right:5px;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 .ygrps-yiv-1976662402yiv9537662842attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 .ygrps-yiv-1976662402yiv9537662842attach label a { text-decoration:none;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 .ygrps-yiv-1976662402yiv9537662842bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 .ygrps-yiv-1976662402yiv9537662842bold a { text-decoration:none;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 dd.ygrps-yiv-1976662402yiv9537662842last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 dd.ygrps-yiv-1976662402yiv9537662842last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 dd.ygrps-yiv-1976662402yiv9537662842last p span.ygrps-yiv-1976662402yiv9537662842yshortcuts { margin-right:0;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 div.ygrps-yiv-1976662402yiv9537662842attach-table div div a { text-decoration:none;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 div.ygrps-yiv-1976662402yiv9537662842attach-table { width:400px;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 div.ygrps-yiv-1976662402yiv9537662842file-title a, #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 div.ygrps-yiv-1976662402yiv9537662842file-title a:active, #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 div.ygrps-yiv-1976662402yiv9537662842file-title a:hover, #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 div.ygrps-yiv-1976662402yiv9537662842file-title a:visited { text-decoration:none;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 div.ygrps-yiv-1976662402yiv9537662842photo-title a, #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 div.ygrps-yiv-1976662402yiv9537662842photo-title a:active, #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 div.ygrps-yiv-1976662402yiv9537662842photo-title a:hover, #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 div.ygrps-yiv-1976662402yiv9537662842photo-title a:visited { text-decoration:none;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 div#ygrps-yiv-1976662402yiv9537662842ygrp-mlmsg #ygrps-yiv-1976662402yiv9537662842ygrp-msg p a span.ygrps-yiv-1976662402yiv9537662842yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 .ygrps-yiv-1976662402yiv9537662842green { color:#628c2a;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 .ygrps-yiv-1976662402yiv9537662842MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 o { font-size:0;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842photos div { float:left;width:72px;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842reco-category { font-size:77%;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842reco-desc { font-size:77%;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 .ygrps-yiv-1976662402yiv9537662842replbq { margin:4px;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-mlmsg select, #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 input, #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-mlmsg pre, #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 code { font:115% monospace;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-mlmsg #ygrps-yiv-1976662402yiv9537662842logo { padding-bottom:10px;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-msg p#ygrps-yiv-1976662402yiv9537662842attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-reco #ygrps-yiv-1976662402yiv9537662842reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-sponsor #ygrps-yiv-1976662402yiv9537662842ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-sponsor #ygrps-yiv-1976662402yiv9537662842ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-sponsor #ygrps-yiv-1976662402yiv9537662842ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-text { font-family:Georgia;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-text tt { font-size:120%;} #ygrps-yiv-1976662402 #ygrps-yiv-1976662402yiv9537662842 #ygrps-yiv-1976662402yiv9537662842ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1976662402
Mike Denest
Mike Denest
Mike Denest
Mike Denest
Sent from my iPhone
Hi,
Melvin Joseph
75ncndwjwpw2wfxdakf6ff67tdqsyikmvm3ljbsb
'Hi Mike Denest or orther reader,
I am working also on the same Fairchild as Melvin.We just did a engine test and the max throttle rpm is 1910 indicated with de 6-410 B2A,
Could you(Mike Denest) or some else say,:what the maximum static rpm is for the Ranger 6-410 B2A?
With kind regards,Steije
'Sounds about right. 6-440 gets 1960 static so you should be ok. From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Sent: Saturday, August 12, 2017 10:59 AM
Subject: Re: [fairchildclub] Ranger 6-410B-2A performance issue
Hi Mike Denest or orther reader, I am working also on the same Fairchild as Melvin.We just did a engine test and the max throttle rpm is 1910 indicated with de 6-410 B2A, Could you(Mike Denest) or some else say,:what the maximum static rpm is for the Ranger 6-410 B2A? With kind regards,Steije '
