Re: Flap Gap
George Sands
Flap Gap
Post by George Sands »
'We've installed the flaps on our F-24 and there is a gap when the flaps are retracted that ranges from about an inch near the root to about a half inch or less at outer end.  Is this normal?  Will it impact the flight characteristics?  I wasn't expecting clam shell tight.
The flaps are not original to the wings, and the wings are neither original to the aircraft or a matched pair.  I believe that the flaps are a matched pair. If any of that matters.
One last thing the left side flap when retracted extends beyond the trailing edge by about a 1/4 inch.  Issue or not?
As I always, I appreciate the help and insight.
George'
William
Re: Flap Gap
Post by William »
' George,NC 28685.  Flaps are flush across entire span, with no overhang at trailing edge.Bill C.
Date: Sun, 17 May 2015 14:22:38 +0000
Subject: [fairchildclub] Flap Gap
George
tonylowe2
Re: Flap Gap
Post by tonylowe2 »
' My flaps have a little gaposis when retracted.  I don’t know why.  I ignore it.  Sounds like you have more.  Are your flaps or the mating wing trailing edge warped a little, or is there an adjustment in the linkage?   Tony Lowe N28522 – 1940 24W-40 converted to 41-A in 1951   From: fairchildclub@yahoogroups.com Sent: Sunday, May 17, 2015 3:18 PM To: fairchildclub@yahoogroups.com Subject: RE: [fairchildclub] Flap Gap     George, NC 28685.  Flaps are flush across entire span, with no overhang at trailing edge. Bill C.
    We've installed the flaps on our F-24 and there is a gap when the flaps are retracted that ranges from about an inch near the root to about a half inch or less at outer end.  Is this normal?  Will it impact the flight characteristics?  I wasn't expecting clam shell tight.    The flaps are not original to the wings, and the wings are neither original to the aircraft or a matched pair.  I believe that the flaps are a matched pair. If any of that matters.   One last thing the left side flap when retracted extends beyond the trailing edge by about a 1/4 inch.  Issue or not?   As I always, I appreciate the help and insight.   George   '
Re: Flap Gap
Post by robert Etter »
'Sounds like you have some issues.To answer some questions.  My F-24 is a 1946.  After an accident in 1948, the airplane ended up with a pre-war right wing, and a UC-61 left.  I have completely rebuilt both.  Other than Nav light position, I haven't seen a dimes worth of difference between the them.  The UC-61 has a few pieces that are built heavier.  I have found that the flaps are not necessarily inter-changeable.  The hinges seem to vary in location slightly.  I don't know the history of the flaps, so I can't explain the variations.Try a tight string between the wing mounted hinges and the flap hinges.  Measure top-top-top, bottom-bottom-bottom, front-front-front, & back-back-back.  Use a fine thread that can stand some serious tension.  It may give you a clue about where the problem is.  I used a string to help locate my wing mounted hinges.  The other thing that works is to center bore 2 old AN-4 bolts, put them on each end and see where the taught thread hits the center hinge.Good luckBob
    We've installed the flaps on our F-24 and there is a gap when the flaps are retracted that ranges from about an inch near the root to about a half inch or less at outer end.  Is this normal?  Will it impact the flight characteristics?  I wasn't expecting clam shell tight.    The flaps are not original to the wings, and the wings are neither original to the aircraft or a matched pair.  I believe that the flaps are a matched pair. If any of that matters.   One last thing the left side flap when retracted extends beyond the trailing edge by about a 1/4 inch.  Issue or not?   As I always, I appreciate the help and insight.   George   #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668 -- #ygrps-yiv-2009345577yiv3271984668ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-mkp #ygrps-yiv-2009345577yiv3271984668hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-mkp #ygrps-yiv-2009345577yiv3271984668ads { margin-bottom:10px;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-mkp .ygrps-yiv-2009345577yiv3271984668ad { padding:0 0;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-mkp .ygrps-yiv-2009345577yiv3271984668ad p { margin:0;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-mkp .ygrps-yiv-2009345577yiv3271984668ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-sponsor #ygrps-yiv-2009345577yiv3271984668ygrp-lc { font-family:Arial;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-sponsor #ygrps-yiv-2009345577yiv3271984668ygrp-lc #ygrps-yiv-2009345577yiv3271984668hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-sponsor #ygrps-yiv-2009345577yiv3271984668ygrp-lc .ygrps-yiv-2009345577yiv3271984668ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668activity span { font-weight:700;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668activity span:first-child { text-transform:uppercase;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668activity span span { color:#ff7900;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668activity span .ygrps-yiv-2009345577yiv3271984668underline { text-decoration:underline;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 .ygrps-yiv-2009345577yiv3271984668attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 .ygrps-yiv-2009345577yiv3271984668attach div a { text-decoration:none;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 .ygrps-yiv-2009345577yiv3271984668attach img { border:none;padding-right:5px;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 .ygrps-yiv-2009345577yiv3271984668attach label { display:block;margin-bottom:5px;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 .ygrps-yiv-2009345577yiv3271984668attach label a { text-decoration:none;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 blockquote { margin:0 0 0 4px;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 .ygrps-yiv-2009345577yiv3271984668bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 .ygrps-yiv-2009345577yiv3271984668bold a { text-decoration:none;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 dd.ygrps-yiv-2009345577yiv3271984668last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 dd.ygrps-yiv-2009345577yiv3271984668last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 dd.ygrps-yiv-2009345577yiv3271984668last p span.ygrps-yiv-2009345577yiv3271984668yshortcuts { margin-right:0;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 div.ygrps-yiv-2009345577yiv3271984668attach-table div div a { text-decoration:none;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 div.ygrps-yiv-2009345577yiv3271984668attach-table { width:400px;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 div.ygrps-yiv-2009345577yiv3271984668file-title a, #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 div.ygrps-yiv-2009345577yiv3271984668file-title a:active, #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 div.ygrps-yiv-2009345577yiv3271984668file-title a:hover, #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 div.ygrps-yiv-2009345577yiv3271984668file-title a:visited { text-decoration:none;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 div.ygrps-yiv-2009345577yiv3271984668photo-title a, #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 div.ygrps-yiv-2009345577yiv3271984668photo-title a:active, #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 div.ygrps-yiv-2009345577yiv3271984668photo-title a:hover, #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 div.ygrps-yiv-2009345577yiv3271984668photo-title a:visited { text-decoration:none;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 div#ygrps-yiv-2009345577yiv3271984668ygrp-mlmsg #ygrps-yiv-2009345577yiv3271984668ygrp-msg p a span.ygrps-yiv-2009345577yiv3271984668yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 .ygrps-yiv-2009345577yiv3271984668green { color:#628c2a;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 .ygrps-yiv-2009345577yiv3271984668MsoNormal { margin:0 0 0 0;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 o { font-size:0;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668photos div { float:left;width:72px;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668reco-category { font-size:77%;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668reco-desc { font-size:77%;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 .ygrps-yiv-2009345577yiv3271984668replbq { margin:4px;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-mlmsg select, #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 input, #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-mlmsg pre, #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 code { font:115% monospace;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-mlmsg #ygrps-yiv-2009345577yiv3271984668logo { padding-bottom:10px;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-msg p#ygrps-yiv-2009345577yiv3271984668attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-reco #ygrps-yiv-2009345577yiv3271984668reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-sponsor #ygrps-yiv-2009345577yiv3271984668ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-sponsor #ygrps-yiv-2009345577yiv3271984668ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-sponsor #ygrps-yiv-2009345577yiv3271984668ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-text { font-family:Georgia;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-text tt { font-size:120%;} #ygrps-yiv-2009345577 #ygrps-yiv-2009345577yiv3271984668 #ygrps-yiv-2009345577yiv3271984668ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-2009345577
Re: Flap Gap
'When you were referring to gaps, was that end gap?  I have the 2 that  were on the airplane when I bought it, and 2 that I bought later in the "70s".   It would only take about 10 minutes.  I have a right wing that is ready for cover, and the left is freshly covered and is waiting for fuel tank install. I can do photos.Bob
On Sunday, May 17, 2015 5:44 PM, "Robert Etter robertetter@ymail.com [fairchildclub]" wrote:
#ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813 -- #ygrps-yiv-1412009069yiv6341912813ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-mkp #ygrps-yiv-1412009069yiv6341912813hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-mkp #ygrps-yiv-1412009069yiv6341912813ads { margin-bottom:10px;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-mkp .ygrps-yiv-1412009069yiv6341912813ad { padding:0 0;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-mkp .ygrps-yiv-1412009069yiv6341912813ad p { margin:0;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-mkp .ygrps-yiv-1412009069yiv6341912813ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-sponsor #ygrps-yiv-1412009069yiv6341912813ygrp-lc { font-family:Arial;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-sponsor #ygrps-yiv-1412009069yiv6341912813ygrp-lc #ygrps-yiv-1412009069yiv6341912813hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-sponsor #ygrps-yiv-1412009069yiv6341912813ygrp-lc .ygrps-yiv-1412009069yiv6341912813ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813activity span { font-weight:700;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813activity span span { color:#ff7900;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813activity span .ygrps-yiv-1412009069yiv6341912813underline { text-decoration:underline;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 .ygrps-yiv-1412009069yiv6341912813attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 .ygrps-yiv-1412009069yiv6341912813attach div a { text-decoration:none;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 .ygrps-yiv-1412009069yiv6341912813attach img { border:none;padding-right:5px;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 .ygrps-yiv-1412009069yiv6341912813attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 .ygrps-yiv-1412009069yiv6341912813attach label a { text-decoration:none;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 .ygrps-yiv-1412009069yiv6341912813bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 .ygrps-yiv-1412009069yiv6341912813bold a { text-decoration:none;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 dd.ygrps-yiv-1412009069yiv6341912813last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 dd.ygrps-yiv-1412009069yiv6341912813last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 dd.ygrps-yiv-1412009069yiv6341912813last p span.ygrps-yiv-1412009069yiv6341912813yshortcuts { margin-right:0;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 div.ygrps-yiv-1412009069yiv6341912813attach-table div div a { text-decoration:none;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 div.ygrps-yiv-1412009069yiv6341912813attach-table { width:400px;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 div.ygrps-yiv-1412009069yiv6341912813file-title a, #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 div.ygrps-yiv-1412009069yiv6341912813file-title a:active, #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 div.ygrps-yiv-1412009069yiv6341912813file-title a:hover, #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 div.ygrps-yiv-1412009069yiv6341912813file-title a:visited { text-decoration:none;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 div.ygrps-yiv-1412009069yiv6341912813photo-title a, #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 div.ygrps-yiv-1412009069yiv6341912813photo-title a:active, #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 div.ygrps-yiv-1412009069yiv6341912813photo-title a:hover, #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 div.ygrps-yiv-1412009069yiv6341912813photo-title a:visited { text-decoration:none;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 div#ygrps-yiv-1412009069yiv6341912813ygrp-mlmsg #ygrps-yiv-1412009069yiv6341912813ygrp-msg p a span.ygrps-yiv-1412009069yiv6341912813yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 .ygrps-yiv-1412009069yiv6341912813green { color:#628c2a;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 .ygrps-yiv-1412009069yiv6341912813MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 o { font-size:0;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813photos div { float:left;width:72px;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813reco-category { font-size:77%;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813reco-desc { font-size:77%;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 .ygrps-yiv-1412009069yiv6341912813replbq { margin:4px;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-mlmsg select, #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 input, #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-mlmsg pre, #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 code { font:115% monospace;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-mlmsg #ygrps-yiv-1412009069yiv6341912813logo { padding-bottom:10px;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-msg p#ygrps-yiv-1412009069yiv6341912813attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-reco #ygrps-yiv-1412009069yiv6341912813reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-sponsor #ygrps-yiv-1412009069yiv6341912813ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-sponsor #ygrps-yiv-1412009069yiv6341912813ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-sponsor #ygrps-yiv-1412009069yiv6341912813ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-text { font-family:Georgia;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-text tt { font-size:120%;} #ygrps-yiv-1412009069 #ygrps-yiv-1412009069yiv6341912813 #ygrps-yiv-1412009069yiv6341912813ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1412009069
Re: Flap Gap
'Me again.I took another re-read on your earlier E-mail.  1/2" over almost 8'  doesn't sound too bad.  I think that mine were about 1/4" on the tips and 1/2-3/4" in the middle.  The rear tips of the ribs were bowed up ward.   Of coarse on your flaps, it almost sounds like too many Cessna pilots got out of the airplane and walked to the rear while the flaps were still extended.  As a good guess,  if the flap is flat, not warped, and all of the hinges on the wing & flap are solid, I wouldn't think there is much to worry about.Regarding the trailing end of the wing and the flap sticks out 1/4", it sounds to me like someone changed out the trailing edge and when they replaced it, they seated the new one a 1/4" further forward than they should have.  They also might have had a little dry rot on the rib tips, which allowed it to go on too far.Don't do what I did.  I was all ate up with ambition in 1973, I should fly the old girl around the end of summer.  I reused only 3 pieces of OE wood.
On Tuesday, May 19, 2015 8:40 AM, "Robert Etter robertetter@ymail.com [fairchildclub]" wrote:
  My flaps have a little gaposis when retracted.  I don’t know why.  I ignore it.  Sounds like you have more.  Are your flaps or the mating wing trailing edge warped a little, or is there an adjustment in the linkage? Tony LoweN28522 – 1940 24W-40 converted to 41-A in 1951 From: mailto:fairchildclub@yahoogroups.com Sent: Sunday, May 17, 2015 3:18 PMTo: fairchildclub@yahoogroups.com Subject: RE: [fairchildclub] Flap Gap   George, NC 28685.  Flaps are flush across entire span, with no overhang at trailing edge.Bill C.
#yiv0859286095 #yiv0859286095 -- #yiv0859286095ygrp-mkp {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}#yiv0859286095 #yiv0859286095ygrp-mkp hr {border:1px solid #d8d8d8;}#yiv0859286095 #yiv0859286095ygrp-mkp #yiv0859286095hd {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}#yiv0859286095 #yiv0859286095ygrp-mkp #yiv0859286095ads {margin-bottom:10px;}#yiv0859286095 #yiv0859286095ygrp-mkp .yiv0859286095ad {padding:0 0;}#yiv0859286095 #yiv0859286095ygrp-mkp .yiv0859286095ad p {margin:0;}#yiv0859286095 #yiv0859286095ygrp-mkp .yiv0859286095ad a {color:#0000ff;text-decoration:none;}#yiv0859286095 #yiv0859286095ygrp-sponsor #yiv0859286095ygrp-lc {font-family:Arial;}#yiv0859286095 #yiv0859286095ygrp-sponsor #yiv0859286095ygrp-lc #yiv0859286095hd {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}#yiv0859286095 #yiv0859286095ygrp-sponsor #yiv0859286095ygrp-lc .yiv0859286095ad {margin-bottom:10px;padding:0 0;}#yiv0859286095 #yiv0859286095actions {font-family:Verdana;font-size:11px;padding:10px 0;}#yiv0859286095 #yiv0859286095activity {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}#yiv0859286095 #yiv0859286095activity span {font-weight:700;}#yiv0859286095 #yiv0859286095activity span:first-child {text-transform:uppercase;}#yiv0859286095 #yiv0859286095activity span a {color:#5085b6;text-decoration:none;}#yiv0859286095 #yiv0859286095activity span span {color:#ff7900;}#yiv0859286095 #yiv0859286095activity span .yiv0859286095underline {text-decoration:underline;}#yiv0859286095 .yiv0859286095attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}#yiv0859286095 .yiv0859286095attach div a {text-decoration:none;}#yiv0859286095 .yiv0859286095attach img {border:none;padding-right:5px;}#yiv0859286095 .yiv0859286095attach label {display:block;margin-bottom:5px;}#yiv0859286095 .yiv0859286095attach label a {text-decoration:none;}#yiv0859286095 blockquote {margin:0 0 0 4px;}#yiv0859286095 .yiv0859286095bold {font-family:Arial;font-size:13px;font-weight:700;}#yiv0859286095 .yiv0859286095bold a {text-decoration:none;}#yiv0859286095 dd.yiv0859286095last p a {font-family:Verdana;font-weight:700;}#yiv0859286095 dd.yiv0859286095last p span {margin-right:10px;font-family:Verdana;font-weight:700;}#yiv0859286095 dd.yiv0859286095last p span.yiv0859286095yshortcuts {margin-right:0;}#yiv0859286095 div.yiv0859286095attach-table div div a {text-decoration:none;}#yiv0859286095 div.yiv0859286095attach-table {width:400px;}#yiv0859286095 div.yiv0859286095file-title a, #yiv0859286095 div.yiv0859286095file-title a:active, #yiv0859286095 div.yiv0859286095file-title a:hover, #yiv0859286095 div.yiv0859286095file-title a:visited {text-decoration:none;}#yiv0859286095 div.yiv0859286095photo-title a, #yiv0859286095 div.yiv0859286095photo-title a:active, #yiv0859286095 div.yiv0859286095photo-title a:hover, #yiv0859286095 div.yiv0859286095photo-title a:visited {text-decoration:none;}#yiv0859286095 div#yiv0859286095ygrp-mlmsg #yiv0859286095ygrp-msg p a span.yiv0859286095yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;}#yiv0859286095 .yiv0859286095green {color:#628c2a;}#yiv0859286095 .yiv0859286095MsoNormal {margin:0 0 0 0;}#yiv0859286095 o {font-size:0;}#yiv0859286095 #yiv0859286095photos div {float:left;width:72px;}#yiv0859286095 #yiv0859286095photos div div {border:1px solid #666666;height:62px;overflow:hidden;width:62px;}#yiv0859286095 #yiv0859286095photos div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}#yiv0859286095 #yiv0859286095reco-category {font-size:77%;}#yiv0859286095 #yiv0859286095reco-desc {font-size:77%;}#yiv0859286095 .yiv0859286095replbq {margin:4px;}#yiv0859286095 #yiv0859286095ygrp-actbar div a:first-child {margin-right:2px;padding-right:5px;}#yiv0859286095 #yiv0859286095ygrp-mlmsg {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}#yiv0859286095 #yiv0859286095ygrp-mlmsg table {font-size:inherit;font:100%;}#yiv0859286095 #yiv0859286095ygrp-mlmsg select, #yiv0859286095 input, #yiv0859286095 textarea {font:99% Arial, Helvetica, clean, sans-serif;}#yiv0859286095 #yiv0859286095ygrp-mlmsg pre, #yiv0859286095 code {font:115% monospace;}#yiv0859286095 #yiv0859286095ygrp-mlmsg * {line-height:1.22em;}#yiv0859286095 #yiv0859286095ygrp-mlmsg #yiv0859286095logo {padding-bottom:10px;}#yiv0859286095 #yiv0859286095ygrp-msg p a {font-family:Verdana;}#yiv0859286095 #yiv0859286095ygrp-msg p#yiv0859286095attach-count span {color:#1E66AE;font-weight:700;}#yiv0859286095 #yiv0859286095ygrp-reco #yiv0859286095reco-head {color:#ff7900;font-weight:700;}#yiv0859286095 #yiv0859286095ygrp-reco {margin-bottom:20px;padding:0px;}#yiv0859286095 #yiv0859286095ygrp-sponsor #yiv0859286095ov li a {font-size:130%;text-decoration:none;}#yiv0859286095 #yiv0859286095ygrp-sponsor #yiv0859286095ov li {font-size:77%;list-style-type:square;padding:6px 0;}#yiv0859286095 #yiv0859286095ygrp-sponsor #yiv0859286095ov ul {margin:0;padding:0 0 0 8px;}#yiv0859286095 #yiv0859286095ygrp-text {font-family:Georgia;}#yiv0859286095 #yiv0859286095ygrp-text p {margin:0 0 1em 0;}#yiv0859286095 #yiv0859286095ygrp-text tt {font-size:120%;}#yiv0859286095 #yiv0859286095ygrp-vital ul li:last-child {border-right:none !important;}#yiv0859286095
Re: Flap Gap
'As you can guess, I don't have professional knowledge on Fairchilds, but I do have intimate knowledge of every nail and gusset in the airplane.  The bad thing is that some of the things that I have done, slight mistakes, are nothing more than re-doing something that some one else did before me.  The worst thing that I did was positioning the aft most former/bulkhead in the top of the fuselage is about 1/2" too far aft and maybe 1/2" lower than it should have been.  Other than that, it looks great.If you need or want some photos.  Glad I could help.Bob (ret)775-482-9243
On Tuesday, May 19, 2015 5:53 PM, "Robert Etter robertetter@ymail.com [fairchildclub]" wrote:
#ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885 -- #ygrps-yiv-810765759yiv0568992885ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-mkp #ygrps-yiv-810765759yiv0568992885hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-mkp #ygrps-yiv-810765759yiv0568992885ads { margin-bottom:10px;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-mkp .ygrps-yiv-810765759yiv0568992885ad { padding:0 0;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-mkp .ygrps-yiv-810765759yiv0568992885ad p { margin:0;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-mkp .ygrps-yiv-810765759yiv0568992885ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-sponsor #ygrps-yiv-810765759yiv0568992885ygrp-lc { font-family:Arial;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-sponsor #ygrps-yiv-810765759yiv0568992885ygrp-lc #ygrps-yiv-810765759yiv0568992885hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-sponsor #ygrps-yiv-810765759yiv0568992885ygrp-lc .ygrps-yiv-810765759yiv0568992885ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885activity span { font-weight:700;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885activity span:first-child { text-transform:uppercase;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885activity span span { color:#ff7900;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885activity span .ygrps-yiv-810765759yiv0568992885underline { text-decoration:underline;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 .ygrps-yiv-810765759yiv0568992885attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 .ygrps-yiv-810765759yiv0568992885attach div a { text-decoration:none;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 .ygrps-yiv-810765759yiv0568992885attach img { border:none;padding-right:5px;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 .ygrps-yiv-810765759yiv0568992885attach label { display:block;margin-bottom:5px;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 .ygrps-yiv-810765759yiv0568992885attach label a { text-decoration:none;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 blockquote { margin:0 0 0 4px;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 .ygrps-yiv-810765759yiv0568992885bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 .ygrps-yiv-810765759yiv0568992885bold a { text-decoration:none;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 dd.ygrps-yiv-810765759yiv0568992885last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 dd.ygrps-yiv-810765759yiv0568992885last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 dd.ygrps-yiv-810765759yiv0568992885last p span.ygrps-yiv-810765759yiv0568992885yshortcuts { margin-right:0;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 div.ygrps-yiv-810765759yiv0568992885attach-table div div a { text-decoration:none;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 div.ygrps-yiv-810765759yiv0568992885attach-table { width:400px;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 div.ygrps-yiv-810765759yiv0568992885file-title a, #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 div.ygrps-yiv-810765759yiv0568992885file-title a:active, #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 div.ygrps-yiv-810765759yiv0568992885file-title a:hover, #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 div.ygrps-yiv-810765759yiv0568992885file-title a:visited { text-decoration:none;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 div.ygrps-yiv-810765759yiv0568992885photo-title a, #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 div.ygrps-yiv-810765759yiv0568992885photo-title a:active, #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 div.ygrps-yiv-810765759yiv0568992885photo-title a:hover, #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 div.ygrps-yiv-810765759yiv0568992885photo-title a:visited { text-decoration:none;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 div#ygrps-yiv-810765759yiv0568992885ygrp-mlmsg #ygrps-yiv-810765759yiv0568992885ygrp-msg p a span.ygrps-yiv-810765759yiv0568992885yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 .ygrps-yiv-810765759yiv0568992885green { color:#628c2a;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 .ygrps-yiv-810765759yiv0568992885MsoNormal { margin:0 0 0 0;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 o { font-size:0;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885photos div { float:left;width:72px;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885reco-category { font-size:77%;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885reco-desc { font-size:77%;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 .ygrps-yiv-810765759yiv0568992885replbq { margin:4px;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-mlmsg select, #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 input, #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-mlmsg pre, #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 code { font:115% monospace;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-mlmsg #ygrps-yiv-810765759yiv0568992885logo { padding-bottom:10px;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-msg p#ygrps-yiv-810765759yiv0568992885attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-reco #ygrps-yiv-810765759yiv0568992885reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-sponsor #ygrps-yiv-810765759yiv0568992885ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-sponsor #ygrps-yiv-810765759yiv0568992885ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-sponsor #ygrps-yiv-810765759yiv0568992885ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-text { font-family:Georgia;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-text tt { font-size:120%;} #ygrps-yiv-810765759 #ygrps-yiv-810765759yiv0568992885 #ygrps-yiv-810765759yiv0568992885ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-810765759
