'Hi,
 I'm missing a few prop hub bolts for Sensenich/Ranger. Do I need a
 special bolt or can AN bolts be used?
 Also, anyone know where to get Ranger magneto mounting bolts? They are
 3/8-16 x 3/4" with a drilled head. I need 4.
 David
 http://www.avast.com'
						Re: Prop hub bolts
Re: Prop hub bolts
'David, The propeller hub bolts are AN but not AN7-?? standard bolts. They are AN5018 boltsFIXED PITCH WOOD PROPELLER and TEST CLUB. I measured a bolt I have for my PT-26propeller hub to determine the exact part number for you, it is a AN5018-20-229.(7/16 dia. length from under the head to end of threads 7-5/32) If your dimensions are different I can look up the appropriate partnumber from the AN standard drawings.
I would check the RANGER parts book for the correct bolt number. If it is just AN the Part number for the bolt you describe is AN76A5(47/64 long) or AN76A6(57/64 long). But I would need to verify per IPC to be sure. Ryan'
				Ranchaero Wing Shop
Re: Prop hub bolts
'                   AN5018? Sounds like a special bolt. But       mine are 5" long. I'll check it again and measure the prop to be       sure the bolts I think are prop bolts are actually that and not       something else. I went looking through the Fairchild parts book       for that number today but didn't see it. It showed the hub and the       bolts but I couldn't find a number for the bolts. It was the end       of the day so maybe tomorrow I'll see more than I could see today!       haha Thanks for your help.
David
David, The propeller hub bolts are AN but not AN7-?? standard bolts. They are AN5018 bolts FIXED PITCH WOOD PROPELLER and TEST CLUB. I measured a bolt I have for my PT-26 propeller hub to determine the exact part number for you, it is a AN5018-20-229.(7/16 dia. length from under the head to end of threads 7-5/32) If your dimensions are different I can look up the appropriate part number from the AN standard drawings.
www.avast.com
						David
 			 		 		 			 				This email has been checked for viruses by Avast antivirus software. 				www.avast.com
				Joe Preston
Re: Prop hub bolts
'       You have to look at the Prop manufacturers installation guide. Sensenich for example has all of the props and bolts listed on their guide. Joe
Sent from my iPad Mini
On Apr 9, 2015, at 23:22, Ranchaero Wing Shop david@ranchaerowingshop.com [fairchildclub] wrote:
www.avast.com
David
				james chybicki
Re: Prop hub bolts
'Just off the phone with SensenichIf your running a 8 bolt Warner Hub (7900) the AN6-51A is an acceptable alternate to the original bolts supplied.NOTE*** Please use this as a reference, contact Sensenich 813-752-3711 ask for Charlie
Jim ChybickiMidwest Aeronautique LLCUC-61K USAAF# 43-1496 / RAF# HB690
From: "Joe Preston Joe@Preston-Company.com [fairchildclub]"
Sent: Friday, April 10, 2015 5:52 AM
Subject: Re: [fairchildclub] Re: Prop hub bolts
www.avast.com
#ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239 -- #ygrps-yiv-222411695yiv5967628239ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-mkp #ygrps-yiv-222411695yiv5967628239hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-mkp #ygrps-yiv-222411695yiv5967628239ads { margin-bottom:10px;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-mkp .ygrps-yiv-222411695yiv5967628239ad { padding:0 0;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-mkp .ygrps-yiv-222411695yiv5967628239ad p { margin:0;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-mkp .ygrps-yiv-222411695yiv5967628239ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-sponsor #ygrps-yiv-222411695yiv5967628239ygrp-lc { font-family:Arial;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-sponsor #ygrps-yiv-222411695yiv5967628239ygrp-lc #ygrps-yiv-222411695yiv5967628239hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-sponsor #ygrps-yiv-222411695yiv5967628239ygrp-lc .ygrps-yiv-222411695yiv5967628239ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239activity span { font-weight:700;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239activity span:first-child { text-transform:uppercase;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239activity span span { color:#ff7900;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239activity span .ygrps-yiv-222411695yiv5967628239underline { text-decoration:underline;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 .ygrps-yiv-222411695yiv5967628239attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 .ygrps-yiv-222411695yiv5967628239attach div a { text-decoration:none;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 .ygrps-yiv-222411695yiv5967628239attach img { border:none;padding-right:5px;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 .ygrps-yiv-222411695yiv5967628239attach label { display:block;margin-bottom:5px;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 .ygrps-yiv-222411695yiv5967628239attach label a { text-decoration:none;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 blockquote { margin:0 0 0 4px;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 .ygrps-yiv-222411695yiv5967628239bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 .ygrps-yiv-222411695yiv5967628239bold a { text-decoration:none;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 dd.ygrps-yiv-222411695yiv5967628239last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 dd.ygrps-yiv-222411695yiv5967628239last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 dd.ygrps-yiv-222411695yiv5967628239last p span.ygrps-yiv-222411695yiv5967628239yshortcuts { margin-right:0;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 div.ygrps-yiv-222411695yiv5967628239attach-table div div a { text-decoration:none;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 div.ygrps-yiv-222411695yiv5967628239attach-table { width:400px;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 div.ygrps-yiv-222411695yiv5967628239file-title a, #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 div.ygrps-yiv-222411695yiv5967628239file-title a:active, #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 div.ygrps-yiv-222411695yiv5967628239file-title a:hover, #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 div.ygrps-yiv-222411695yiv5967628239file-title a:visited { text-decoration:none;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 div.ygrps-yiv-222411695yiv5967628239photo-title a, #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 div.ygrps-yiv-222411695yiv5967628239photo-title a:active, #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 div.ygrps-yiv-222411695yiv5967628239photo-title a:hover, #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 div.ygrps-yiv-222411695yiv5967628239photo-title a:visited { text-decoration:none;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 div#ygrps-yiv-222411695yiv5967628239ygrp-mlmsg #ygrps-yiv-222411695yiv5967628239ygrp-msg p a span.ygrps-yiv-222411695yiv5967628239yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 .ygrps-yiv-222411695yiv5967628239green { color:#628c2a;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 .ygrps-yiv-222411695yiv5967628239MsoNormal { margin:0 0 0 0;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 o { font-size:0;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239photos div { float:left;width:72px;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239reco-category { font-size:77%;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239reco-desc { font-size:77%;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 .ygrps-yiv-222411695yiv5967628239replbq { margin:4px;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-mlmsg select, #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 input, #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-mlmsg pre, #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 code { font:115% monospace;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-mlmsg #ygrps-yiv-222411695yiv5967628239logo { padding-bottom:10px;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-msg p#ygrps-yiv-222411695yiv5967628239attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-reco #ygrps-yiv-222411695yiv5967628239reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-sponsor #ygrps-yiv-222411695yiv5967628239ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-sponsor #ygrps-yiv-222411695yiv5967628239ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-sponsor #ygrps-yiv-222411695yiv5967628239ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-text { font-family:Georgia;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-text tt { font-size:120%;} #ygrps-yiv-222411695 #ygrps-yiv-222411695yiv5967628239 #ygrps-yiv-222411695yiv5967628239ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-222411695
David
Re: Prop hub bolts
'An bolts are Acceptable BUT with a wood prop one must be very careful one doesn't bottom out the threads.  A true prop bolt has longer threads, but ANs work very well if you are aware of the limited thread length.  Cy Galley - Chairman of Emergency Aircraft RepairA service project of EAA Chapter 75      From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Sent: Friday, April 10, 2015 1:34 PM
Subject: Re: [fairchildclub] Re: Prop hub bolts Just off the phone with SensenichIf your running a 8 bolt Warner Hub (7900) the AN6-51A is an acceptable alternate to the original bolts supplied.NOTE*** Please use this as a reference, contact Sensenich 813-752-3711 ask for Charlie Jim ChybickiMidwest Aeronautique LLCUC-61K USAAF# 43-1496 / RAF# HB690 From: "Joe Preston Joe@Preston-Company.com [fairchildclub]"
Subject: Re: [fairchildclub] Re: Prop hub bolts You have to look at the Prop manufacturers installation guide. Sensenich for example has all of the props and bolts listed on their guide.Joe
On Apr 9, 2015, at 23:22, Ranchaero Wing Shop david@ranchaerowingshop.com [fairchildclub] wrote: This email has been checked for viruses by Avast antivirus software.
www.avast.com '
David
On 4/9/2015 6:16 PM, cagog@yahoo.com [fairchildclub] wrote: David, The propeller hub bolts are AN but not AN7-?? standard bolts. They are AN5018 boltsFIXED PITCH WOOD PROPELLER and TEST CLUB. I measured a bolt I have for my PT-26propeller hub to determine the exact part number for you, it is a AN5018-20-229.(7/16 dia. length from under the head to end of threads 7-5/32) If your dimensions are different I can look up the appropriate partnumber from the AN standard drawings. I would check the RANGER parts book for the correct bolt number. If it is just AN the Part number for the bolt you describe is AN76A5(47/64 long) or AN76A6(57/64 long). But I would need to verify per IPC to be sure. Ryan
This email has been checked for viruses by Avast antivirus software. www.avast.com '
				Hugh Loewenhardt
Re: Prop hub bolts
'Good, solid, information. Thank you Cy. Have not read both bolt specifications, but I'm thinking they are the same material, finish and thread tolerances except for the thread length.
On Friday, April 10, 2015 4:54 PM, "'Cy Galley' cgalley@mchsi.com [fairchildclub]" wrote:
www.avast.com #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301 -- #ygrps-yiv-1207284948yiv1775883301ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mkp #ygrps-yiv-1207284948yiv1775883301hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mkp #ygrps-yiv-1207284948yiv1775883301ads { margin-bottom:10px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mkp .ygrps-yiv-1207284948yiv1775883301ad { padding:0 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mkp .ygrps-yiv-1207284948yiv1775883301ad p { margin:0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mkp .ygrps-yiv-1207284948yiv1775883301ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-sponsor #ygrps-yiv-1207284948yiv1775883301ygrp-lc { font-family:Arial;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-sponsor #ygrps-yiv-1207284948yiv1775883301ygrp-lc #ygrps-yiv-1207284948yiv1775883301hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-sponsor #ygrps-yiv-1207284948yiv1775883301ygrp-lc .ygrps-yiv-1207284948yiv1775883301ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301activity span { font-weight:700;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301activity span span { color:#ff7900;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301activity span .ygrps-yiv-1207284948yiv1775883301underline { text-decoration:underline;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301attach div a { text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301attach img { border:none;padding-right:5px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301attach label a { text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301bold a { text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 dd.ygrps-yiv-1207284948yiv1775883301last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 dd.ygrps-yiv-1207284948yiv1775883301last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 dd.ygrps-yiv-1207284948yiv1775883301last p span.ygrps-yiv-1207284948yiv1775883301yshortcuts { margin-right:0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301attach-table div div a { text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301attach-table { width:400px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301file-title a, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301file-title a:active, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301file-title a:hover, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301file-title a:visited { text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301photo-title a, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301photo-title a:active, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301photo-title a:hover, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301photo-title a:visited { text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div#ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg #ygrps-yiv-1207284948yiv1775883301ygrp-msg p a span.ygrps-yiv-1207284948yiv1775883301yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301green { color:#628c2a;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 o { font-size:0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301photos div { float:left;width:72px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301reco-category { font-size:77%;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301reco-desc { font-size:77%;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301replbq { margin:4px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg select, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 input, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg pre, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 code { font:115% monospace;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg #ygrps-yiv-1207284948yiv1775883301logo { padding-bottom:10px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-msg p#ygrps-yiv-1207284948yiv1775883301attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-reco #ygrps-yiv-1207284948yiv1775883301reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-sponsor #ygrps-yiv-1207284948yiv1775883301ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-sponsor #ygrps-yiv-1207284948yiv1775883301ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-sponsor #ygrps-yiv-1207284948yiv1775883301ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-text { font-family:Georgia;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-text tt { font-size:120%;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1207284948
David
This email has been checked for viruses by Avast antivirus software. www.avast.com #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301 -- #ygrps-yiv-1207284948yiv1775883301ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mkp #ygrps-yiv-1207284948yiv1775883301hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mkp #ygrps-yiv-1207284948yiv1775883301ads { margin-bottom:10px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mkp .ygrps-yiv-1207284948yiv1775883301ad { padding:0 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mkp .ygrps-yiv-1207284948yiv1775883301ad p { margin:0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mkp .ygrps-yiv-1207284948yiv1775883301ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-sponsor #ygrps-yiv-1207284948yiv1775883301ygrp-lc { font-family:Arial;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-sponsor #ygrps-yiv-1207284948yiv1775883301ygrp-lc #ygrps-yiv-1207284948yiv1775883301hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-sponsor #ygrps-yiv-1207284948yiv1775883301ygrp-lc .ygrps-yiv-1207284948yiv1775883301ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301activity span { font-weight:700;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301activity span span { color:#ff7900;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301activity span .ygrps-yiv-1207284948yiv1775883301underline { text-decoration:underline;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301attach div a { text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301attach img { border:none;padding-right:5px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301attach label a { text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301bold a { text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 dd.ygrps-yiv-1207284948yiv1775883301last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 dd.ygrps-yiv-1207284948yiv1775883301last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 dd.ygrps-yiv-1207284948yiv1775883301last p span.ygrps-yiv-1207284948yiv1775883301yshortcuts { margin-right:0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301attach-table div div a { text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301attach-table { width:400px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301file-title a, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301file-title a:active, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301file-title a:hover, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301file-title a:visited { text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301photo-title a, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301photo-title a:active, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301photo-title a:hover, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301photo-title a:visited { text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div#ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg #ygrps-yiv-1207284948yiv1775883301ygrp-msg p a span.ygrps-yiv-1207284948yiv1775883301yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301green { color:#628c2a;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 o { font-size:0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301photos div { float:left;width:72px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301reco-category { font-size:77%;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301reco-desc { font-size:77%;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301replbq { margin:4px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg select, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 input, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg pre, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 code { font:115% monospace;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg #ygrps-yiv-1207284948yiv1775883301logo { padding-bottom:10px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-msg p#ygrps-yiv-1207284948yiv1775883301attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-reco #ygrps-yiv-1207284948yiv1775883301reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-sponsor #ygrps-yiv-1207284948yiv1775883301ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-sponsor #ygrps-yiv-1207284948yiv1775883301ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-sponsor #ygrps-yiv-1207284948yiv1775883301ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-text { font-family:Georgia;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-text tt { font-size:120%;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1207284948
				Ranchaero Wing Shop
Re: Prop hub bolts
'                   Thanks to all who helped with this       question!! Several good answers.
David
www.avast.com
www.avast.com
						David
An bolts are Acceptable BUT with a wood prop one must be very careful one doesn't bottom out the threads. A true prop bolt has longer threads, but ANs work very well if you are aware of the limited thread length. Cy Galley - Chairman of Emergency Aircraft Repair A service project of EAA Chapter 75 From: fairchildclub@yahoogroups.com [fairchildclub@yahoogroups.com]
Subject: Re: [fairchildclub] Re: Prop hub bolts Just off the phone with Sensenich If your running a 8 bolt Warner Hub (7900) the AN6-51A is an acceptable alternate to the original bolts supplied. NOTE*** Please use this as a reference, contact Sensenich 813-752-3711 ask for Charlie Jim Chybicki Midwest Aeronautique LLC UC-61K USAAF# 43-1496 / RAF# HB690 From: "Joe Preston Joe@Preston-Company.com [fairchildclub]"
Subject: Re: [fairchildclub] Re: Prop hub bolts You have to look at the Prop manufacturers installation guide. Sensenich for example has all of the props and bolts listed on their guide. Joe
On Apr 9, 2015, at 23:22, Ranchaero Wing Shop david@ranchaerowingshop.com [fairchildclub] wrote: AN5018? Sounds like a special bolt. But mine are 5" long. I'll check it again and measure the prop to be sure the bolts I think are prop bolts are actually that and not something else. I went looking through the Fairchild parts book for that number today but didn't see it. It showed the hub and the bolts but I couldn't find a number for the bolts. It was the end of the day so maybe tomorrow I'll see more than I could see today! haha Thanks for your help.
David
On 4/9/2015 6:16 PM, cagog@yahoo.com [fairchildclub] wrote: David, The propeller hub bolts are AN but not AN7-?? standard bolts. They are AN5018 bolts FIXED PITCH WOOD PROPELLER and TEST CLUB. I measured a bolt I have for my PT-26 propeller hub to determine the exact part number for you, it is a AN5018-20-229.(7/16 dia. length from under the head to end of threads 7-5/32) If your dimensions are different I can look up the appropriate part number from the AN standard drawings. I would check the RANGER parts book for the correct bolt number. If it is just AN the Part number for the bolt you describe is AN76A5(47/64 long) or AN76A6(57/64 long). But I would need to verify per IPC to be sure. Ryan
