'I'm looking for set of fairings (both sides) where the wing meets the fuselage. Any suggestions as to where these can be found?
Thanks'
Re: Wing fairings
Re: Wing fairings
'George, You can make them if postwar F24. Bottom is flat plate, upper is mostly flat, slight roll on inside near hump. JST From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Sent: Wednesday, February 25, 2015 5:20 PM
Subject: [fairchildclub] Wing fairings I'm looking for set of fairings (both sides) where the wing meets the fuselage. Any suggestions as to where these can be found? Thanks'
