Re: 24V Generator
james chybicki
24V Generator
'Hi Allanyone have a 24 Volt Generator that fits a Ranger?After clean up and checking, our unit is only 12 Volt.Trying to keep our UC-61K as close to original as possible.
Has anyone put a 24 volt Alternator on the Ranger?Looking for advice from the group
thanksJim ChybickiMidwest Aeronautique LLCUC-61K USAAF# 43-14964 / RAF HB-690RampRatOne-at-Yahoo.com'
Re: 24V Generator
' Jim,
What's the amps on your generator? I have a 24 volt generator that is currently mounted on a Jacobs engine from a bamboo bomber.
Ted
30rchildclub@yahoogroups.com
Date: Tue, 21 Oct 2014 06:32:24 -0700
Subject: [fairchildclub] 24V Generator
Ted
james chybicki
Re: 24V Generator
The manual calls for 15 amp.
To: Jon Martin ;
Subject: RE: [fairchildclub] 24V Generator
Sent: Tue, Oct 21, 2014 9:48:17 PM
Jim,
Ted
To: Jon Martin ;
Jim,
Ted
Gene Haines
Re: 24V Generator
'Hi Jim,
Did you fine a generator yet?
I have an Eclipse four Bolt 28.5 Volt generator. Serial # A2418 Order number 43-8282P\Man Dwg 112180-1235-1 On the attach end there is the following stamp EA 20245 There are six groves on the shaft. There is no part number shown on the plate.
Gene Haines
From: james chybicki rampratone@yahoo.com [fairchildclub]
To: Fairchild Club
Sent: Tue, Oct 21, 2014 9:32 am
Hi All anyone have a 24 Volt Generator that fits a Ranger? After clean up and checking, our unit is only 12 Volt. Trying to keep our UC-61K as close to original as possible.
Has anyone put a 24 volt Alternator on the Ranger? Looking for advice from the group
thanks Jim Chybicki Midwest Aeronautique LLC UC-61K USAAF# 43-14964 / RAF HB-690 RampRatOne-at-Yahoo.com '
Gene Haines
To: Fairchild Club
Gene Haines
Re: 24V Generator
'Hi Jim,
Gene Haines
To: Fairchild Club
Gene Haines
To: Fairchild Club
james chybicki
Re: 24V Generator
'Hi GeneNot yet, let me do some research on the unit you have and see if I can use it.Any Idea where or what it came off of?Jim
On Thursday, October 23, 2014 12:05 PM, "Gene Haines Pilot4906@aol.com [fairchildclub]" wrote:
Hi Jim,
Gene Haines
To: Fairchild Club
thanks Jim Chybicki Midwest Aeronautique LLC UC-61K USAAF# 43-14964 / RAF HB-690 RampRatOne-at-Yahoo.com #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421 -- #ygrps-yiv-1098682711yiv4820616421ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-mkp #ygrps-yiv-1098682711yiv4820616421hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-mkp #ygrps-yiv-1098682711yiv4820616421ads { margin-bottom:10px;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-mkp .ygrps-yiv-1098682711yiv4820616421ad { padding:0 0;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-mkp .ygrps-yiv-1098682711yiv4820616421ad p { margin:0;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-mkp .ygrps-yiv-1098682711yiv4820616421ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-sponsor #ygrps-yiv-1098682711yiv4820616421ygrp-lc { font-family:Arial;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-sponsor #ygrps-yiv-1098682711yiv4820616421ygrp-lc #ygrps-yiv-1098682711yiv4820616421hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-sponsor #ygrps-yiv-1098682711yiv4820616421ygrp-lc .ygrps-yiv-1098682711yiv4820616421ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421activity span { font-weight:700;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421activity span span { color:#ff7900;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421activity span .ygrps-yiv-1098682711yiv4820616421underline { text-decoration:underline;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 .ygrps-yiv-1098682711yiv4820616421attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 .ygrps-yiv-1098682711yiv4820616421attach div a { text-decoration:none;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 .ygrps-yiv-1098682711yiv4820616421attach img { border:none;padding-right:5px;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 .ygrps-yiv-1098682711yiv4820616421attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 .ygrps-yiv-1098682711yiv4820616421attach label a { text-decoration:none;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 .ygrps-yiv-1098682711yiv4820616421bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 .ygrps-yiv-1098682711yiv4820616421bold a { text-decoration:none;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 dd.ygrps-yiv-1098682711yiv4820616421last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 dd.ygrps-yiv-1098682711yiv4820616421last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 dd.ygrps-yiv-1098682711yiv4820616421last p span.ygrps-yiv-1098682711yiv4820616421yshortcuts { margin-right:0;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 div.ygrps-yiv-1098682711yiv4820616421attach-table div div a { text-decoration:none;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 div.ygrps-yiv-1098682711yiv4820616421attach-table { width:400px;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 div.ygrps-yiv-1098682711yiv4820616421file-title a, #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 div.ygrps-yiv-1098682711yiv4820616421file-title a:active, #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 div.ygrps-yiv-1098682711yiv4820616421file-title a:hover, #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 div.ygrps-yiv-1098682711yiv4820616421file-title a:visited { text-decoration:none;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 div.ygrps-yiv-1098682711yiv4820616421photo-title a, #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 div.ygrps-yiv-1098682711yiv4820616421photo-title a:active, #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 div.ygrps-yiv-1098682711yiv4820616421photo-title a:hover, #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 div.ygrps-yiv-1098682711yiv4820616421photo-title a:visited { text-decoration:none;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 div#ygrps-yiv-1098682711yiv4820616421ygrp-mlmsg #ygrps-yiv-1098682711yiv4820616421ygrp-msg p a span.ygrps-yiv-1098682711yiv4820616421yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 .ygrps-yiv-1098682711yiv4820616421green { color:#628c2a;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 .ygrps-yiv-1098682711yiv4820616421MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 o { font-size:0;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421photos div { float:left;width:72px;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421reco-category { font-size:77%;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421reco-desc { font-size:77%;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 .ygrps-yiv-1098682711yiv4820616421replbq { margin:4px;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-mlmsg select, #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 input, #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-mlmsg pre, #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 code { font:115% monospace;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-mlmsg #ygrps-yiv-1098682711yiv4820616421logo { padding-bottom:10px;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-msg p#ygrps-yiv-1098682711yiv4820616421attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-reco #ygrps-yiv-1098682711yiv4820616421reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-sponsor #ygrps-yiv-1098682711yiv4820616421ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-sponsor #ygrps-yiv-1098682711yiv4820616421ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-sponsor #ygrps-yiv-1098682711yiv4820616421ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-text { font-family:Georgia;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-text tt { font-size:120%;} #ygrps-yiv-1098682711 #ygrps-yiv-1098682711yiv4820616421 #ygrps-yiv-1098682711yiv4820616421ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1098682711
Hi Jim,
Gene Haines
To: Fairchild Club
Gene Haines
Re: 24V Generator
' I am not sure. It probably came with other parts when we purchased some engines and PT parts. I can check to see if it fits on a Ranger engine if you like.
Gene Haines
To: fairchildclub
Sent: Thu, Oct 23, 2014 1:49 pm
Subject: Re: [fairchildclub] 24V Generator
Hi Gene Not yet, let me do some research on the unit you have and see if I can use it. Any Idea where or what it came off of? Jim
Hi Jim,
Gene Haines
To: Fairchild Club
Gene Haines
To: fairchildclub
Hi Jim,
Gene Haines
To: Fairchild Club
Re: 24V Generator
'Jim,
I have a champion 24 volt (I think) which came off my Ranger (Argus III 24 volt system) – I’m putting on an alternator.
I will look tomorrow when I go to the ‘Shed’ and get what I can off the Data plate. It was working when it came off 18 years ago. Would you be interested?
Frank Cox (UK)
Sent: 23 October 2014 18:50
Hi Gene
Frank Cox (UK)
Hi Gene
'On Thursday, October 23, 2014 12:05 PM, "Gene Haines Pilot4906@aol.com [fairchildclub]" wrote:
Hi Jim,
Gene Haines
To: Fairchild Club
Hi All
thanks
Jim Chybicki
james chybicki
Re: 24V Generator
'yes please!
On Thursday, October 23, 2014 12:55 PM, "Gene Haines Pilot4906@aol.com [fairchildclub]" wrote:
Gene Haines
To: fairchildclub
Hi Jim,
Gene Haines
To: Fairchild Club
Gene Haines
To: fairchildclub
Hi Jim,
Gene Haines
To: Fairchild Club
Gene Haines
Re: 24V Generator
' I checked the generators on two Ranger engines this morning. The 24 volt one is a little longer but will fit OK. It is not as big around. Maybe 1/2" smaller in diameter. There is a place to attach a cooling hose. The bolt pattern is the same as the engine. The engine must be female for the shaft to slide into. Generally the same set up as the 12 Volt system. I think it would work just fine. If you find it does not fit you can return it for a refund.
I think $250.00 plus shipping would work unless you think it should be more. We are a not for profit so any cash helps keep our airport open.
Gene Haines 585-747-3278 Cell
To: fairchildclub
Sent: Thu, Oct 23, 2014 4:56 pm
yes please!
Gene Haines
To: fairchildclub
Hi Jim,
Gene Haines
To: Fairchild Club
To: fairchildclub
yes please!
Gene Haines
To: fairchildclub
Hi Jim,
Gene Haines
To: Fairchild Club
