Re: UC-61A motor mounts.
'After hearing the tails regarding the removal of the outer shells of the cushioning motor mounts for the Warner, I am happy to say that I successfully removed all 4 of the outer shells within a single afternoon, and didn't damage a thing. And I didn't even need a hammer.I made a cylindrical plug that was about 1.24?" in diameter by 1.5" long, with a 1/2" hole through the center. The 1.24?" diameter is slightly less than the inside diameter of the seat for the cushioning mount. Then I made a closed off cylinder whose inside diameter was slightly larger than the inside diameter of the seat. I put the plug against the side of the outer shell that I wanted to push on, and the cylinder against the opposite side of the mount. I put a 1/2" bolt through both pieces, with several heavy washer against the cylinder, put a nut on it and snugged it down tight. I used 2 hinge handles to get some good torque. None of the 4 moved at that time even the slightest bit. I then took out a 1500W hot air gun (cheap) for less than 3-5 minutes to warm each mount, then they started to move. The mounts never got so hot that the heat damaged the paint.Some time this next week, I will sit down at the computer and make a drawing.I can see that it will require heat on the seat and cold on the mount in order to get everything back together. I remember seeing 1.250" on the outer diameter of the shell, but the seat was 1.24?" on the inside. .002" to .004" difference will really lock the mounts into place when it normalizes. Bob'
gilmoreredlion
Hi Bob,
I believe I've got a handle on your description but a photo of the set up would be nice if you have something.
Mark Gilmore'
Hi Bob,
Mark Gilmore'
james chybicki
'Hi MarkWho / What are you responding to?
Website Gatekeeper?I have not had a new "Fairchildclub" post in a few weeks.Are some club emails getting dropped from the full view?
Let me know. I miss being involvedthanksJim C.Midwest Aeronautique LLCUC-61K USAAF# 43-14961 / RAF # HB-690
Sent: Tuesday, January 6, 2015 2:20 PM
Subject: [fairchildclub] Re: UC-61A motor mounts.
Hi Bob, I believe I've got a handle on your description but a photo of the set up would be nice if you have something.Thanks,Mark Gilmore #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555 -- #ygrps-yiv-675810200yiv1165537555ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-mkp #ygrps-yiv-675810200yiv1165537555hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-mkp #ygrps-yiv-675810200yiv1165537555ads { margin-bottom:10px;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-mkp .ygrps-yiv-675810200yiv1165537555ad { padding:0 0;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-mkp .ygrps-yiv-675810200yiv1165537555ad p { margin:0;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-mkp .ygrps-yiv-675810200yiv1165537555ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-sponsor #ygrps-yiv-675810200yiv1165537555ygrp-lc { font-family:Arial;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-sponsor #ygrps-yiv-675810200yiv1165537555ygrp-lc #ygrps-yiv-675810200yiv1165537555hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-sponsor #ygrps-yiv-675810200yiv1165537555ygrp-lc .ygrps-yiv-675810200yiv1165537555ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555activity span { font-weight:700;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555activity span:first-child { text-transform:uppercase;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555activity span span { color:#ff7900;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555activity span .ygrps-yiv-675810200yiv1165537555underline { text-decoration:underline;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 .ygrps-yiv-675810200yiv1165537555attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 .ygrps-yiv-675810200yiv1165537555attach div a { text-decoration:none;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 .ygrps-yiv-675810200yiv1165537555attach img { border:none;padding-right:5px;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 .ygrps-yiv-675810200yiv1165537555attach label { display:block;margin-bottom:5px;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 .ygrps-yiv-675810200yiv1165537555attach label a { text-decoration:none;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 blockquote { margin:0 0 0 4px;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 .ygrps-yiv-675810200yiv1165537555bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 .ygrps-yiv-675810200yiv1165537555bold a { text-decoration:none;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 dd.ygrps-yiv-675810200yiv1165537555last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 dd.ygrps-yiv-675810200yiv1165537555last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 dd.ygrps-yiv-675810200yiv1165537555last p span.ygrps-yiv-675810200yiv1165537555yshortcuts { margin-right:0;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 div.ygrps-yiv-675810200yiv1165537555attach-table div div a { text-decoration:none;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 div.ygrps-yiv-675810200yiv1165537555attach-table { width:400px;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 div.ygrps-yiv-675810200yiv1165537555file-title a, #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 div.ygrps-yiv-675810200yiv1165537555file-title a:active, #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 div.ygrps-yiv-675810200yiv1165537555file-title a:hover, #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 div.ygrps-yiv-675810200yiv1165537555file-title a:visited { text-decoration:none;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 div.ygrps-yiv-675810200yiv1165537555photo-title a, #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 div.ygrps-yiv-675810200yiv1165537555photo-title a:active, #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 div.ygrps-yiv-675810200yiv1165537555photo-title a:hover, #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 div.ygrps-yiv-675810200yiv1165537555photo-title a:visited { text-decoration:none;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 div#ygrps-yiv-675810200yiv1165537555ygrp-mlmsg #ygrps-yiv-675810200yiv1165537555ygrp-msg p a span.ygrps-yiv-675810200yiv1165537555yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 .ygrps-yiv-675810200yiv1165537555green { color:#628c2a;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 .ygrps-yiv-675810200yiv1165537555MsoNormal { margin:0 0 0 0;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 o { font-size:0;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555photos div { float:left;width:72px;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555reco-category { font-size:77%;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555reco-desc { font-size:77%;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 .ygrps-yiv-675810200yiv1165537555replbq { margin:4px;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-mlmsg select, #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 input, #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-mlmsg pre, #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 code { font:115% monospace;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-mlmsg #ygrps-yiv-675810200yiv1165537555logo { padding-bottom:10px;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-msg p#ygrps-yiv-675810200yiv1165537555attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-reco #ygrps-yiv-675810200yiv1165537555reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-sponsor #ygrps-yiv-675810200yiv1165537555ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-sponsor #ygrps-yiv-675810200yiv1165537555ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-sponsor #ygrps-yiv-675810200yiv1165537555ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-text { font-family:Georgia;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-text tt { font-size:120%;} #ygrps-yiv-675810200 #ygrps-yiv-675810200yiv1165537555 #ygrps-yiv-675810200yiv1165537555ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-675810200
gilmoreredlion
'Hi, It was Bob Etter with the UC-61, his post about removing the bushings in the Warner motor mount'
