PT-19 Ranger list of parts needed
' Following are the list of parts that I will need. I have some of these items, but for the most part they're in pretty sad shape. So I'd like to find something a little better than what I have. The numbers given are from the Fairchild PT-19 Parts Catalog. -David Exhaust manifold cowling Fig 91 page 98 1. 64107 - pipe, hotspot inlet 2. 64108 - bracket, hotspot outlet tube 3. 64109 - Pipe, hotspot outlet 4. 64117-7 - Housing, upper 5. 64117-8 - Housing, lower 6. 64117-9 Shield & plate assembly 7. 64118 - Door, cylinder cooling cowl 8. 64119 - Cowl, exhaust - cooling upper-inner 9. 64120 - Cowl, exhaust - cooling upper-outer 10. 64121 - Cowl, exhaust - cooling lower-inner 11. 64122 - Cowl, exhaust - cooling lower-outer 12. 64123 - Cowl, exhaust - cooling upper - rear 13. 64124 - Cowl, exhaust - cooling lower-rear 14. 64125 - Pin, exhaust cooling cowl 16. 64127 - Plate, hot spot inlet tube 17. 64129 - Clip, rear baffle 18 - 64131 - Deflector 19 - 64132 - Spacer, cooling cowl rear Oiler Cooler Fig. 79 page 88 4. 64142 - Bracket, oil cooler front 5. 64143 - Bracket, oil cooler rear 6. U-3160-D-5 Oil Cooler 7. FS102-33 Spacer (2) 11. 3265 Relief valve 12. AC 852-16 Elbow 13. AC 851-16 Elbow Air Maze Fig. 94 page 100 1. Hose, Neoprene 3. 68634 - Door, duct 5. 68639 Clamp (2) 6. 68640 Elbow (carb) 7. 68641 Control (Shakespeare) 8. 1029 Swivel (A-3/32") 9. 68642 Screen (air maze) 10. 68645 Clip '
