Re: Ranger Hot Box Tubes
james chybicki
Post by james chybicki »
'Hi AllHappy New Year from Chicago!It's 4 degrees F and we are getting about 10 inches of snow between yesterday and today.  Makes it touch to get out to the hangar and work!Our Ranger Build up is progressing nicely! However, I am missing the Carburetor Hot Box Inlet end exhaust tubes. Does anyone still use these and if not can you spare a set?Let me knowThanksJim ChybickiMidwest AeronautiquesUC-61K 43-14964 / HB-690'
tandemtrainer
Post by tandemtrainer »
'Jim,
I believe there's a service bulletin doing away with the tubes because it overheated the intake and they also carboned up.  Most I  see today are plugged.
Steve Lawlor
F24R46  N1010W'
Jack Threadgill
Post by Jack Threadgill »
'Mine is plugged.
Jack
From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com] On Behalf Of 9mo3@stjoelive.com
Sent: Thursday, January 02, 2014 7:47 AM
Subject: [fairchildclub] RE: Ranger Hot Box Tubes
Jim,
Steve Lawlor
F24R46 N1010W
hotfoot49
Post by hotfoot49 »
Hot Spot Service Bulletin
RANGR AIRCRAFT ENGINE service Bulletin No. 91 October 22, 1943  covers this .It basiclly says to block off the hot spot by removing the tube from the exhaust to the hot spot. Close the little stub of the exhaust pipe. (Weld it shut). Remove the tube going to the hot spot and block the hot spot  off with a piece of aluminum and the gasket. I left the other pipe on the hot spot on mine to fill the hole in the bottom cowling. It is blocked off on that side of the hot spot also.
I think the reason they did away with the hot spot tube was becasue the exhaust gases were eating holes in the hot spot casting. The hot spot was supose to help eliminate carb icing I think.
Mike Kelly
Fairchild Club'
james chybicki
'Thanks for all the responses.  I must have been sleepy when reviewing the S.B. list. I see it now.   Jim C
On Thursday, January 2, 2014 8:53 AM, "hotfoot49@hotmail.com" wrote:
  Hot Spot Service Bulletin RANGR AIRCRAFT ENGINE service Bulletin No. 91 October 22, 1943  covers this .It basiclly says to block off the hot spot by removing the tube from the exhaust to the hot spot. Close the little stub of the exhaust pipe. (Weld it shut). Remove the tube going to the hot spot and block the hot spot  off with a piece of aluminum and the gasket. I left the other pipe on the hot spot on mine to fill the hole in the bottom cowling. It is blocked off on that side of the hot spot also. I think the reason they did away with the hot spot tube was becasue the exhaust gases were eating holes in the hot spot casting. The hot spot was supose to help eliminate carb icing I think.  Mike KellyFairchild Club #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163 -- #ygrps-yiv-530518767yiv4861990163ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-mkp #ygrps-yiv-530518767yiv4861990163hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-mkp #ygrps-yiv-530518767yiv4861990163ads { margin-bottom:10px;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-mkp .ygrps-yiv-530518767yiv4861990163ad { padding:0 0;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-mkp .ygrps-yiv-530518767yiv4861990163ad p { margin:0;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-mkp .ygrps-yiv-530518767yiv4861990163ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-sponsor #ygrps-yiv-530518767yiv4861990163ygrp-lc { font-family:Arial;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-sponsor #ygrps-yiv-530518767yiv4861990163ygrp-lc #ygrps-yiv-530518767yiv4861990163hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-sponsor #ygrps-yiv-530518767yiv4861990163ygrp-lc .ygrps-yiv-530518767yiv4861990163ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163activity span { font-weight:700;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163activity span:first-child { text-transform:uppercase;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163activity span span { color:#ff7900;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163activity span .ygrps-yiv-530518767yiv4861990163underline { text-decoration:underline;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 .ygrps-yiv-530518767yiv4861990163attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 .ygrps-yiv-530518767yiv4861990163attach div a { text-decoration:none;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 .ygrps-yiv-530518767yiv4861990163attach img { border:none;padding-right:5px;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 .ygrps-yiv-530518767yiv4861990163attach label { display:block;margin-bottom:5px;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 .ygrps-yiv-530518767yiv4861990163attach label a { text-decoration:none;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 blockquote { margin:0 0 0 4px;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 .ygrps-yiv-530518767yiv4861990163bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 .ygrps-yiv-530518767yiv4861990163bold a { text-decoration:none;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 dd.ygrps-yiv-530518767yiv4861990163last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 dd.ygrps-yiv-530518767yiv4861990163last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 dd.ygrps-yiv-530518767yiv4861990163last p span.ygrps-yiv-530518767yiv4861990163yshortcuts { margin-right:0;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 div.ygrps-yiv-530518767yiv4861990163attach-table div div a { text-decoration:none;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 div.ygrps-yiv-530518767yiv4861990163attach-table { width:400px;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 div.ygrps-yiv-530518767yiv4861990163file-title a, #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 div.ygrps-yiv-530518767yiv4861990163file-title a:active, #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 div.ygrps-yiv-530518767yiv4861990163file-title a:hover, #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 div.ygrps-yiv-530518767yiv4861990163file-title a:visited { text-decoration:none;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 div.ygrps-yiv-530518767yiv4861990163photo-title a, #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 div.ygrps-yiv-530518767yiv4861990163photo-title a:active, #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 div.ygrps-yiv-530518767yiv4861990163photo-title a:hover, #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 div.ygrps-yiv-530518767yiv4861990163photo-title a:visited { text-decoration:none;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 div#ygrps-yiv-530518767yiv4861990163ygrp-mlmsg #ygrps-yiv-530518767yiv4861990163ygrp-msg p a span.ygrps-yiv-530518767yiv4861990163yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 .ygrps-yiv-530518767yiv4861990163green { color:#628c2a;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 .ygrps-yiv-530518767yiv4861990163MsoNormal { margin:0 0 0 0;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 o { font-size:0;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163photos div { float:left;width:72px;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163reco-category { font-size:77%;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163reco-desc { font-size:77%;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 .ygrps-yiv-530518767yiv4861990163replbq { margin:4px;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-mlmsg select, #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 input, #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-mlmsg pre, #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 code { font:115% monospace;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-mlmsg #ygrps-yiv-530518767yiv4861990163logo { padding-bottom:10px;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-msg p#ygrps-yiv-530518767yiv4861990163attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-reco #ygrps-yiv-530518767yiv4861990163reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-sponsor #ygrps-yiv-530518767yiv4861990163ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-sponsor #ygrps-yiv-530518767yiv4861990163ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-sponsor #ygrps-yiv-530518767yiv4861990163ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-text { font-family:Georgia;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-text tt { font-size:120%;} #ygrps-yiv-530518767 #ygrps-yiv-530518767yiv4861990163 #ygrps-yiv-530518767yiv4861990163ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-530518767
