Re: Main Landing Gear Struts
Buell Powell
Post by Buell Powell »
'#ygrps-yiv-1353471321 p {margin:0;}        I am working on the main landing gear struts for my F24. I have drained the old fluid out and it was a clear fluid that had turned blackish-I think it was some type of brake fluid.  I am thinking of using the synthetic Dextron VI trans fluid which is compatible with the older trans fluids. I am considering taking them apart and cleaning them but would most likely need to replace the packings. My questions are--is the fluid I am thinking of using OK, Does anyone have a tool for the gland nuts or any ideas about making one, And any leads as to where to get new packings?  Thanks, Buell Powell
BHP
rangerrobertmn
Post by rangerrobertmn »
Buell,
I made a tool from 1/4 inch steel plate, 3"x18".  Drilled a hole near one end that exceeded the diameter of the strut, then cut a slot to that hole, to allow it to slip around the strut.  I then drilled two 1/4 inch (?) holes to line up with the small holes in the top of the packing-nut.  I put two short pieces of music wire into those two holes, and the nut came right off.  Probably overkill, but the results were great.  The steel plate might have been a bit smaller that what I described  --  possibly even 1/8 inch x 2"  --  it was just material that I had laying around.
Bob WaldronWebster MN
Post by robert Etter »
'I know that it may be a little late in coming, but sometime in the long distant past I located an infinitely variable divider type gland wrench with 1/4" pegs on it.  I think that the pegs were about 3/8" long.  I think that I found it a catalogue store in Arizona.  The only modification that I needed to do was to remove about 1/32" from the inner edge of the arms.  The clearance between the hole on the gland nut it pretty tight.I'll try to go back in the archives to see if I can locate the E-mail.Bob
On Saturday, December 21, 2013 5:00 AM, "rangerrobertmn@yahoo.com" wrote:
  Buell,
#ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699 -- #ygrps-yiv-334578442yiv7044239699ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-mkp #ygrps-yiv-334578442yiv7044239699hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-mkp #ygrps-yiv-334578442yiv7044239699ads { margin-bottom:10px;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-mkp .ygrps-yiv-334578442yiv7044239699ad { padding:0 0;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-mkp .ygrps-yiv-334578442yiv7044239699ad p { margin:0;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-mkp .ygrps-yiv-334578442yiv7044239699ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-sponsor #ygrps-yiv-334578442yiv7044239699ygrp-lc { font-family:Arial;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-sponsor #ygrps-yiv-334578442yiv7044239699ygrp-lc #ygrps-yiv-334578442yiv7044239699hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-sponsor #ygrps-yiv-334578442yiv7044239699ygrp-lc .ygrps-yiv-334578442yiv7044239699ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699activity span { font-weight:700;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699activity span:first-child { text-transform:uppercase;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699activity span span { color:#ff7900;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699activity span .ygrps-yiv-334578442yiv7044239699underline { text-decoration:underline;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 .ygrps-yiv-334578442yiv7044239699attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 .ygrps-yiv-334578442yiv7044239699attach div a { text-decoration:none;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 .ygrps-yiv-334578442yiv7044239699attach img { border:none;padding-right:5px;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 .ygrps-yiv-334578442yiv7044239699attach label { display:block;margin-bottom:5px;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 .ygrps-yiv-334578442yiv7044239699attach label a { text-decoration:none;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 blockquote { margin:0 0 0 4px;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 .ygrps-yiv-334578442yiv7044239699bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 .ygrps-yiv-334578442yiv7044239699bold a { text-decoration:none;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 dd.ygrps-yiv-334578442yiv7044239699last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 dd.ygrps-yiv-334578442yiv7044239699last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 dd.ygrps-yiv-334578442yiv7044239699last p span.ygrps-yiv-334578442yiv7044239699yshortcuts { margin-right:0;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 div.ygrps-yiv-334578442yiv7044239699attach-table div div a { text-decoration:none;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 div.ygrps-yiv-334578442yiv7044239699attach-table { width:400px;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 div.ygrps-yiv-334578442yiv7044239699file-title a, #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 div.ygrps-yiv-334578442yiv7044239699file-title a:active, #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 div.ygrps-yiv-334578442yiv7044239699file-title a:hover, #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 div.ygrps-yiv-334578442yiv7044239699file-title a:visited { text-decoration:none;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 div.ygrps-yiv-334578442yiv7044239699photo-title a, #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 div.ygrps-yiv-334578442yiv7044239699photo-title a:active, #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 div.ygrps-yiv-334578442yiv7044239699photo-title a:hover, #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 div.ygrps-yiv-334578442yiv7044239699photo-title a:visited { text-decoration:none;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 div#ygrps-yiv-334578442yiv7044239699ygrp-mlmsg #ygrps-yiv-334578442yiv7044239699ygrp-msg p a span.ygrps-yiv-334578442yiv7044239699yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 .ygrps-yiv-334578442yiv7044239699green { color:#628c2a;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 .ygrps-yiv-334578442yiv7044239699MsoNormal { margin:0 0 0 0;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 o { font-size:0;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699photos div { float:left;width:72px;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699reco-category { font-size:77%;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699reco-desc { font-size:77%;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 .ygrps-yiv-334578442yiv7044239699replbq { margin:4px;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-mlmsg select, #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 input, #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-mlmsg pre, #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 code { font:115% monospace;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-mlmsg #ygrps-yiv-334578442yiv7044239699logo { padding-bottom:10px;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-msg p#ygrps-yiv-334578442yiv7044239699attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-reco #ygrps-yiv-334578442yiv7044239699reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-sponsor #ygrps-yiv-334578442yiv7044239699ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-sponsor #ygrps-yiv-334578442yiv7044239699ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-sponsor #ygrps-yiv-334578442yiv7044239699ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-text { font-family:Georgia;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-text tt { font-size:120%;} #ygrps-yiv-334578442 #ygrps-yiv-334578442yiv7044239699 #ygrps-yiv-334578442yiv7044239699ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-334578442
'Ididn't find it where I thought it was, but I found a good site. Try "PROTO Tools",  "Black Oxide Adjustable Face Spanner Wrenches"  check "JC483".  Overall length 8 1/4", Pin dia. - 1/4"
  Buell,
#ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086 -- #ygrps-yiv-944896043yiv0265233086ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-mkp #ygrps-yiv-944896043yiv0265233086hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-mkp #ygrps-yiv-944896043yiv0265233086ads { margin-bottom:10px;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-mkp .ygrps-yiv-944896043yiv0265233086ad { padding:0 0;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-mkp .ygrps-yiv-944896043yiv0265233086ad p { margin:0;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-mkp .ygrps-yiv-944896043yiv0265233086ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-sponsor #ygrps-yiv-944896043yiv0265233086ygrp-lc { font-family:Arial;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-sponsor #ygrps-yiv-944896043yiv0265233086ygrp-lc #ygrps-yiv-944896043yiv0265233086hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-sponsor #ygrps-yiv-944896043yiv0265233086ygrp-lc .ygrps-yiv-944896043yiv0265233086ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086activity span { font-weight:700;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086activity span:first-child { text-transform:uppercase;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086activity span span { color:#ff7900;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086activity span .ygrps-yiv-944896043yiv0265233086underline { text-decoration:underline;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 .ygrps-yiv-944896043yiv0265233086attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 .ygrps-yiv-944896043yiv0265233086attach div a { text-decoration:none;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 .ygrps-yiv-944896043yiv0265233086attach img { border:none;padding-right:5px;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 .ygrps-yiv-944896043yiv0265233086attach label { display:block;margin-bottom:5px;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 .ygrps-yiv-944896043yiv0265233086attach label a { text-decoration:none;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 blockquote { margin:0 0 0 4px;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 .ygrps-yiv-944896043yiv0265233086bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 .ygrps-yiv-944896043yiv0265233086bold a { text-decoration:none;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 dd.ygrps-yiv-944896043yiv0265233086last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 dd.ygrps-yiv-944896043yiv0265233086last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 dd.ygrps-yiv-944896043yiv0265233086last p span.ygrps-yiv-944896043yiv0265233086yshortcuts { margin-right:0;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 div.ygrps-yiv-944896043yiv0265233086attach-table div div a { text-decoration:none;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 div.ygrps-yiv-944896043yiv0265233086attach-table { width:400px;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 div.ygrps-yiv-944896043yiv0265233086file-title a, #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 div.ygrps-yiv-944896043yiv0265233086file-title a:active, #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 div.ygrps-yiv-944896043yiv0265233086file-title a:hover, #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 div.ygrps-yiv-944896043yiv0265233086file-title a:visited { text-decoration:none;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 div.ygrps-yiv-944896043yiv0265233086photo-title a, #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 div.ygrps-yiv-944896043yiv0265233086photo-title a:active, #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 div.ygrps-yiv-944896043yiv0265233086photo-title a:hover, #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 div.ygrps-yiv-944896043yiv0265233086photo-title a:visited { text-decoration:none;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 div#ygrps-yiv-944896043yiv0265233086ygrp-mlmsg #ygrps-yiv-944896043yiv0265233086ygrp-msg p a span.ygrps-yiv-944896043yiv0265233086yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 .ygrps-yiv-944896043yiv0265233086green { color:#628c2a;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 .ygrps-yiv-944896043yiv0265233086MsoNormal { margin:0 0 0 0;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 o { font-size:0;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086photos div { float:left;width:72px;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086reco-category { font-size:77%;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086reco-desc { font-size:77%;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 .ygrps-yiv-944896043yiv0265233086replbq { margin:4px;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-mlmsg select, #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 input, #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-mlmsg pre, #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 code { font:115% monospace;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-mlmsg #ygrps-yiv-944896043yiv0265233086logo { padding-bottom:10px;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-msg p#ygrps-yiv-944896043yiv0265233086attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-reco #ygrps-yiv-944896043yiv0265233086reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-sponsor #ygrps-yiv-944896043yiv0265233086ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-sponsor #ygrps-yiv-944896043yiv0265233086ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-sponsor #ygrps-yiv-944896043yiv0265233086ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-text { font-family:Georgia;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-text tt { font-size:120%;} #ygrps-yiv-944896043 #ygrps-yiv-944896043yiv0265233086 #ygrps-yiv-944896043yiv0265233086ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-944896043
Jeffrey Whitesell
Post by Jeffrey Whitesell »
'You can buy the exact tool from F.G Wilcox here in Oxnard California…look at their spanners on line.
Jeff
BHP
---Jeff Whiteselltopfun@fivetogether.com
