'Hi All1. Does anyone have a spare 3 tooth Eclipse E80 Type 397 12 or 24 volt available for the Ranger? I have a NEW E80 Type 756 24 volt 12 gear tooth (Warner or Continental) for trade or sale
2. I have a couple rangers cores, some have the 2 stud carb hotspot that allows the NA-R4B Stromberg Carb and another has the 4 Stud Hotspot for the MA-4-5 Marvel Carb. Are both carbs good for the 200 HP Ranger or is it a matter of choice?
3. I have a PT-26 Canadian exhaust assembly that will not be used on my UC-61K. I want to put the 6 single stack exhausts on my plane. I need the base plates for the exhaust to manufacture the straight pipes. I don't want to cut up the Canadian set up since it is pretty good shape. Anyone got any ideas on making the base plate or have the single or 3 into one stacks laying around?
Let me know your thoughts
Jim ChybickiMidwest AeronautiquesUC-61K USAAF# 43-14964 RAF # HB-690
Re: Starter Carb and Exhausts for Ranger
james chybicki
Fritz Mehrer
'Hello Jim,I maybe have the three tooth starter and would welcome the trade. Which way does the three tooth rotate? From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com] On Behalf Of james chybicki
Sent: Monday, December 16, 2013 1:34 PM
Subject: [fairchildclub] Starter Carb and Exhausts for Ranger
Hi All1. Does anyone have a spare 3 tooth Eclipse E80 Type 397 12 or 24 volt available for the Ranger? I have a NEW E80 Type 756 24 volt 12 gear tooth (Warner or Continental) for trade or sale 2. I have a couple rangers cores, some have the 2 stud carb hotspot that allows the NA-R4B Stromberg Carb and another has the 4 Stud Hotspot for the MA-4-5 Marvel Carb. Are both carbs good for the 200 HP Ranger or is it a matter of choice? 3. I have a PT-26 Canadian exhaust assembly that will not be used on my UC-61K. I want to put the 6 single stack exhausts on my plane. I need the base plates for the exhaust to manufacture the straight pipes. I don't want to cut up the Canadian set up since it is pretty good shape. Anyone got any ideas on making the base plate or have the single or 3 into one stacks laying around? Let me know your thoughts Jim ChybickiMidwest AeronautiquesUC-61K USAAF# 43-14964 RAF # HB-690
