Re: Shock mounts for instrument panel.
Does anyone know of a source for the rubber shock mounts for the PT-26 instrument panels? The metal plate that the rubber is mounted in is 1-3/4" square. Banaire use to have them but they have went out of buiness and sold everything at auction I think.
A old one I have says MONEL Series 150 on the metal plate.
Keep 'Em Flying!
Mike Kelly'
Keep 'Em Flying!
Mike Kelly'
				Fritz Mehrer
'Yeah, I got a set last year for the 26 that I am building. I don’t have the paperwork with me here at the house, it’s at the hangar. I will retrieve my files in the next few days and let ya know…    Now…..  I need a favor. I need one floating instrument panel for my 26, with the brackets. Do you have an extra or know where I can find one?????????????FritzSan Diego  From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com] On Behalf Of hotfoot49@hotmail.com
Sent: Tuesday, December 03, 2013 7:15 AM
Subject: [fairchildclub] Shock mounts for instrument panel.
Keep 'Em Flying!
Mike Kelly
Keep 'Em Flying!
Mike Kelly
'Found this place on line.....the catalog shows the right mounts.  Not sure of availability.   The 150 is the size(1.5 inch)/type(diamond).  The stiffness of the rubber is the other variable.  I seem to recall that number being on the mount or molded into the rubber.   http://www.westernrubber.com/products/lord-mounts/   http://www.westernrubber.com/wp-content/uploads/Lord-Plateform-Mounts.pdf
ptcurt@gmail.com '
Keep 'Em Flying!
Mike Kelly
ptcurt@gmail.com '
				mcclurebill@rocketmail.com
' Mike:   I have quite a few rubber shock mounts of different types, some of which sound like what you are looking for. Can you give me a description and I'll check the stock.     Bill McClure    '
'Good luck on finding new 100APL (Square) shock mounts.  If I remember correctly, Lord doesn't make that model any longer.  If someone was to front a complete run of several hundred, they might do it.  That would be several thousand dollars.  Lord is at 1-877-asklord. I did find some 100PDL(diamond) that look like a good substitute.  They are the diamond design, and they have the same dimension as the 100APL.  They only have 2 mounting holes on a diagonal, and they are the same distance apart 1.414".  That is the same as what you are looking for.   Aircraft Spruce has some 100APL's, and they are surplus, and not  new. The ones that I bought recent are 100PDL-2 (diamond) from "Herber Aircraft Service, Inc  PH 310-322-9575". NOTE: did you notice the small holes either below the upper mounting screws, or above the lower mounting screws on the instrument cluster panel.  They work great for aligning the "L" shaped mounting brackets screw holes.  Use rib stich needle to align the "L" bracket to the main panel.  Then insert the screw. Bob
On Tuesday, December 3, 2013 4:03 PM, "burnmcc@aol.com" wrote:
Mike: I have quite a few rubber shock mounts of different types, some of which sound like what you are looking for. Can you give me a description and I'll check the stock. Bill McClure #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463 -- #ygrps-yiv-936824167yiv5943064463ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-mkp #ygrps-yiv-936824167yiv5943064463hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-mkp #ygrps-yiv-936824167yiv5943064463ads { margin-bottom:10px;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-mkp .ygrps-yiv-936824167yiv5943064463ad { padding:0 0;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-mkp .ygrps-yiv-936824167yiv5943064463ad p { margin:0;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-mkp .ygrps-yiv-936824167yiv5943064463ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-sponsor #ygrps-yiv-936824167yiv5943064463ygrp-lc { font-family:Arial;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-sponsor #ygrps-yiv-936824167yiv5943064463ygrp-lc #ygrps-yiv-936824167yiv5943064463hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-sponsor #ygrps-yiv-936824167yiv5943064463ygrp-lc .ygrps-yiv-936824167yiv5943064463ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463activity span { font-weight:700;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463activity span:first-child { text-transform:uppercase;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463activity span span { color:#ff7900;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463activity span .ygrps-yiv-936824167yiv5943064463underline { text-decoration:underline;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 .ygrps-yiv-936824167yiv5943064463attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 .ygrps-yiv-936824167yiv5943064463attach div a { text-decoration:none;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 .ygrps-yiv-936824167yiv5943064463attach img { border:none;padding-right:5px;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 .ygrps-yiv-936824167yiv5943064463attach label { display:block;margin-bottom:5px;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 .ygrps-yiv-936824167yiv5943064463attach label a { text-decoration:none;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 blockquote { margin:0 0 0 4px;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 .ygrps-yiv-936824167yiv5943064463bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 .ygrps-yiv-936824167yiv5943064463bold a { text-decoration:none;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 dd.ygrps-yiv-936824167yiv5943064463last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 dd.ygrps-yiv-936824167yiv5943064463last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 dd.ygrps-yiv-936824167yiv5943064463last p span.ygrps-yiv-936824167yiv5943064463yshortcuts { margin-right:0;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 div.ygrps-yiv-936824167yiv5943064463attach-table div div a { text-decoration:none;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 div.ygrps-yiv-936824167yiv5943064463attach-table { width:400px;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 div.ygrps-yiv-936824167yiv5943064463file-title a, #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 div.ygrps-yiv-936824167yiv5943064463file-title a:active, #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 div.ygrps-yiv-936824167yiv5943064463file-title a:hover, #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 div.ygrps-yiv-936824167yiv5943064463file-title a:visited { text-decoration:none;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 div.ygrps-yiv-936824167yiv5943064463photo-title a, #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 div.ygrps-yiv-936824167yiv5943064463photo-title a:active, #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 div.ygrps-yiv-936824167yiv5943064463photo-title a:hover, #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 div.ygrps-yiv-936824167yiv5943064463photo-title a:visited { text-decoration:none;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 div#ygrps-yiv-936824167yiv5943064463ygrp-mlmsg #ygrps-yiv-936824167yiv5943064463ygrp-msg p a span.ygrps-yiv-936824167yiv5943064463yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 .ygrps-yiv-936824167yiv5943064463green { color:#628c2a;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 .ygrps-yiv-936824167yiv5943064463MsoNormal { margin:0 0 0 0;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 o { font-size:0;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463photos div { float:left;width:72px;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463reco-category { font-size:77%;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463reco-desc { font-size:77%;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 .ygrps-yiv-936824167yiv5943064463replbq { margin:4px;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-mlmsg select, #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 input, #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-mlmsg pre, #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 code { font:115% monospace;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-mlmsg #ygrps-yiv-936824167yiv5943064463logo { padding-bottom:10px;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-msg p#ygrps-yiv-936824167yiv5943064463attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-reco #ygrps-yiv-936824167yiv5943064463reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-sponsor #ygrps-yiv-936824167yiv5943064463ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-sponsor #ygrps-yiv-936824167yiv5943064463ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-sponsor #ygrps-yiv-936824167yiv5943064463ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-text { font-family:Georgia;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-text tt { font-size:120%;} #ygrps-yiv-936824167 #ygrps-yiv-936824167yiv5943064463 #ygrps-yiv-936824167yiv5943064463ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-936824167
' Still waiting for description. I have quite a few different types I obtained from San Fernando surplus shops years ago.     Bill McC      -----Original Message-----
To: fairchildclub
Sent: Wed, Dec 4, 2013 11:47 am
Subject: Re: [fairchildclub] Shock mounts for instrument panel.
To: fairchildclub
				Fritz Mehrer
'Ok, guys, here’s is the info on the PT-26 instrument shock mounts…Lord still makes the mounts, I bought a full set…  The Part Number is 150APL SERIES and you can choose the load factor you want to put in…  THEY ARE BEAUTIFUL.. and VERY expensive. Fritz…  Ok, for this info, I am asking you guys to source out the PT-26 floating instrument panel I have been looking for……………………FritzSan Diego  From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com] On Behalf Of burnmcc@aol.com
Sent: Wednesday, December 04, 2013 10:34 AM
Still waiting for description. I have quite a few different types I obtained from San Fernando surplus shops years ago. Bill McC-----Original Message-----
To: fairchildclub
Subject: Re: [fairchildclub] Shock mounts for instrument panel. Good luck on finding new 100APL (Square) shock mounts. If I remember correctly, Lord doesn't make that model any longer. If someone was to front a complete run of several hundred, they might do it. That would be several thousand dollars. Lord is at 1-877-asklord. I did find some 100PDL(diamond) that look like a good substitute. They are the diamond design, and they have the same dimension as the 100APL. They only have 2 mounting holes on a diagonal, and they are the same distance apart 1.414". That is the same as what you are looking for. Aircraft Spruce has some 100APL's, and they are surplus, and not new. The ones that I bought recent are 100PDL-2 (diamond) from "Herber Aircraft Service, Inc PH 310-322-9575". NOTE: did you notice the small holes either below the upper mounting screws, or above the lower mounting screws on the instrument cluster panel. They work great for aligning the "L" shaped mounting brackets screw holes. Use rib stich needle to align the "L" bracket to the main panel. Then insert the screw. Bob On Tuesday, December 3, 2013 4:03 PM, "burnmcc @aol.com" wrote: Mike: I have quite a few rubber shock mounts of different types, some of which sound like what you are looking for. Can you give me a description and I'll check the stock. Bill McClure
To: fairchildclub
'I give you a quickie on the dimensions of the mounts that I have looked at. (some of the suffixs may differ)100APL Series  -  1x1"  centers on the bolt pattern.                      Rubber dia - 1".          Bolt dia - 0.166" 150APL Series  -  1.375X1.375"centers on the bolt pattern.         Rubber dia - 1.5".       Bolt dia - 0.257" If you can use the 150 series, I am happy for you.  The PT-19 I worked on  many years ago used the 100 series.  The F-24 that I have uses the 100 series.  I shutter at the thought of remaking the 8 pieces of the instrument cluster mounting system to accommodate the 150 series.   I blue printer the F24 mounts years ago using what I could glean from the CD.  I scaled the  drawing to the point that I could print it,  cut it out and glue it to the metal that I was using.  All the cut lines, centers, dimensions, and bend lines were ready and waiting. I looked at a couple of the mounts that I couldn't use and there isn't enough material to allow for the 1.5" hole  so the rubber can go through the mount and the mounting flange to be flush against the mount. Lord has a E-mail account http://www.lord.com/.  It has all the info for "PLATE FORM MOUNTS". Bob
To: fairchildclub
#ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653 -- #ygrps-yiv-1636511629yiv4908714653ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-mkp #ygrps-yiv-1636511629yiv4908714653hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-mkp #ygrps-yiv-1636511629yiv4908714653ads { margin-bottom:10px;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-mkp .ygrps-yiv-1636511629yiv4908714653ad { padding:0 0;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-mkp .ygrps-yiv-1636511629yiv4908714653ad p { margin:0;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-mkp .ygrps-yiv-1636511629yiv4908714653ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-sponsor #ygrps-yiv-1636511629yiv4908714653ygrp-lc { font-family:Arial;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-sponsor #ygrps-yiv-1636511629yiv4908714653ygrp-lc #ygrps-yiv-1636511629yiv4908714653hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-sponsor #ygrps-yiv-1636511629yiv4908714653ygrp-lc .ygrps-yiv-1636511629yiv4908714653ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653activity span { font-weight:700;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653activity span span { color:#ff7900;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653activity span .ygrps-yiv-1636511629yiv4908714653underline { text-decoration:underline;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 .ygrps-yiv-1636511629yiv4908714653attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 .ygrps-yiv-1636511629yiv4908714653attach div a { text-decoration:none;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 .ygrps-yiv-1636511629yiv4908714653attach img { border:none;padding-right:5px;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 .ygrps-yiv-1636511629yiv4908714653attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 .ygrps-yiv-1636511629yiv4908714653attach label a { text-decoration:none;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 .ygrps-yiv-1636511629yiv4908714653bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 .ygrps-yiv-1636511629yiv4908714653bold a { text-decoration:none;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 dd.ygrps-yiv-1636511629yiv4908714653last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 dd.ygrps-yiv-1636511629yiv4908714653last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 dd.ygrps-yiv-1636511629yiv4908714653last p span.ygrps-yiv-1636511629yiv4908714653yshortcuts { margin-right:0;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 div.ygrps-yiv-1636511629yiv4908714653attach-table div div a { text-decoration:none;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 div.ygrps-yiv-1636511629yiv4908714653attach-table { width:400px;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 div.ygrps-yiv-1636511629yiv4908714653file-title a, #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 div.ygrps-yiv-1636511629yiv4908714653file-title a:active, #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 div.ygrps-yiv-1636511629yiv4908714653file-title a:hover, #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 div.ygrps-yiv-1636511629yiv4908714653file-title a:visited { text-decoration:none;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 div.ygrps-yiv-1636511629yiv4908714653photo-title a, #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 div.ygrps-yiv-1636511629yiv4908714653photo-title a:active, #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 div.ygrps-yiv-1636511629yiv4908714653photo-title a:hover, #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 div.ygrps-yiv-1636511629yiv4908714653photo-title a:visited { text-decoration:none;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 div#ygrps-yiv-1636511629yiv4908714653ygrp-mlmsg #ygrps-yiv-1636511629yiv4908714653ygrp-msg p a span.ygrps-yiv-1636511629yiv4908714653yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 .ygrps-yiv-1636511629yiv4908714653green { color:#628c2a;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 .ygrps-yiv-1636511629yiv4908714653MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 o { font-size:0;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653photos div { float:left;width:72px;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653reco-category { font-size:77%;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653reco-desc { font-size:77%;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 .ygrps-yiv-1636511629yiv4908714653replbq { margin:4px;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-mlmsg select, #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 input, #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-mlmsg pre, #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 code { font:115% monospace;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-mlmsg #ygrps-yiv-1636511629yiv4908714653logo { padding-bottom:10px;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-msg p#ygrps-yiv-1636511629yiv4908714653attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-reco #ygrps-yiv-1636511629yiv4908714653reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-sponsor #ygrps-yiv-1636511629yiv4908714653ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-sponsor #ygrps-yiv-1636511629yiv4908714653ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-sponsor #ygrps-yiv-1636511629yiv4908714653ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-text { font-family:Georgia;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-text tt { font-size:120%;} #ygrps-yiv-1636511629 #ygrps-yiv-1636511629yiv4908714653 #ygrps-yiv-1636511629yiv4908714653ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1636511629
To: fairchildclub
				Gene Haines
'After some research I find that the original mounts for the PT-26 instrument panels that we have, have 150 series and steel stamped on the square metal plate. Looking at Lord documents I find the 150P- ?? is the correct mount.  The ?? are to indicate the weight to be held.
Looking at Aircraft Spruce I find that they have the square 150P for 24 lbs with part number 08-07183. With the old gyros, the floating panel will be quite heavy. The mounts they show are a little less than $12.00 each
The PT-19 panels we have, have the 1" platform mounts. These are also available at Aircraft Spruce.
Gene Haines
To: fairchildclub
Sent: Sat, Dec 7, 2013 2:03 pm
I give you a quickie on the dimensions of the mounts that I have looked at. (some of the suffixs may differ) 100APL Series - 1x1" centers on the bolt pattern. Rubber dia - 1". Bolt dia - 0.166" 150APL Series - 1.375X1.375"centers on the bolt pattern. Rubber dia - 1.5". Bolt dia - 0.257" If you can use the 150 series, I am happy for you. The PT-19 I worked on many years ago used the 100 series. The F-24 that I have uses the 100 series. I shutter at the thought of remaking the 8 pieces of the instrument cluster mounting system to accommodate the 150 series. I blue printer the F24 mounts years ago using what I could glean from the CD. I scaled the drawing to the point that I could print it, cut it out and glue it to the metal that I was using. All the cut lines, centers, dimensions, and bend lines were ready and waiting. I looked at a couple of the mounts that I couldn't use and there isn't enough material to allow for the 1.5" hole so the rubber can go through the mount and the mounting flange to be flush against the mount. Lord has a E-mail account http://www.lord.com/. It has all the info for "PLATE FORM MOUNTS". Bob
Ok, guys, here’s is the info on the PT-26 instrument shock mounts… Lord still makes the mounts, I bought a full set… The Part Number is 150APL SERIES and you can choose the load factor you want to put in… THEY ARE BEAUTIFUL.. and VERY expensive. Fritz… Ok, for this info, I am asking you guys to source out the PT-26 floating instrument panel I have been looking for…………………… Fritz San Diego From: fairchildclub@yahoogroups.com [fairchildclub@yahoogroups.com?] On Behalf Of burnmcc@aol.com
To: fairchildclub
Gene Haines
To: fairchildclub
To: fairchildclub
Mike: I have quite a few rubber shock mounts of different types, some of which sound like what you are looking for. Can you give me a description and I'll check the stock. Bill McClureOn Tuesday, December 3, 2013 4:03 PM, "burnmcc @aol.com" wrote:
'That sure sounds good to me.   I noticed on the Aircraft Spruce catalog, the 100APL "New surplus item - like new mfg".   I have several of the 1" square mounts, but I have no idea as to the date of manufacture.  So I bought 8 of the 100 APDL that were  certified as new.  The price was quite a bit higher than what you paid. How I need to remove 16 1/8" rivets.  And it happens to be too darn cold.  Today's high, maybe 29 deg. Bob
Gene Haines
To: fairchildclub
To: fairchildclub
#ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 -- #ygrps-yiv-1051466434yiv3703906000ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-mkp #ygrps-yiv-1051466434yiv3703906000hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-mkp #ygrps-yiv-1051466434yiv3703906000ads { margin-bottom:10px;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-mkp .ygrps-yiv-1051466434yiv3703906000ad { padding:0 0;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-mkp .ygrps-yiv-1051466434yiv3703906000ad p { margin:0;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-mkp .ygrps-yiv-1051466434yiv3703906000ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-sponsor #ygrps-yiv-1051466434yiv3703906000ygrp-lc { font-family:Arial;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-sponsor #ygrps-yiv-1051466434yiv3703906000ygrp-lc #ygrps-yiv-1051466434yiv3703906000hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-sponsor #ygrps-yiv-1051466434yiv3703906000ygrp-lc .ygrps-yiv-1051466434yiv3703906000ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000activity span { font-weight:700;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000activity span span { color:#ff7900;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000activity span .ygrps-yiv-1051466434yiv3703906000underline { text-decoration:underline;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 .ygrps-yiv-1051466434yiv3703906000attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 .ygrps-yiv-1051466434yiv3703906000attach div a { text-decoration:none;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 .ygrps-yiv-1051466434yiv3703906000attach img { border:none;padding-right:5px;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 .ygrps-yiv-1051466434yiv3703906000attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 .ygrps-yiv-1051466434yiv3703906000attach label a { text-decoration:none;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 .ygrps-yiv-1051466434yiv3703906000bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 .ygrps-yiv-1051466434yiv3703906000bold a { text-decoration:none;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 dd.ygrps-yiv-1051466434yiv3703906000last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 dd.ygrps-yiv-1051466434yiv3703906000last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 dd.ygrps-yiv-1051466434yiv3703906000last p span.ygrps-yiv-1051466434yiv3703906000yshortcuts { margin-right:0;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 div.ygrps-yiv-1051466434yiv3703906000attach-table div div a { text-decoration:none;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 div.ygrps-yiv-1051466434yiv3703906000attach-table { width:400px;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 div.ygrps-yiv-1051466434yiv3703906000file-title a, #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 div.ygrps-yiv-1051466434yiv3703906000file-title a:active, #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 div.ygrps-yiv-1051466434yiv3703906000file-title a:hover, #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 div.ygrps-yiv-1051466434yiv3703906000file-title a:visited { text-decoration:none;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 div.ygrps-yiv-1051466434yiv3703906000photo-title a, #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 div.ygrps-yiv-1051466434yiv3703906000photo-title a:active, #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 div.ygrps-yiv-1051466434yiv3703906000photo-title a:hover, #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 div.ygrps-yiv-1051466434yiv3703906000photo-title a:visited { text-decoration:none;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 div#ygrps-yiv-1051466434yiv3703906000ygrp-mlmsg #ygrps-yiv-1051466434yiv3703906000ygrp-msg p a span.ygrps-yiv-1051466434yiv3703906000yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 .ygrps-yiv-1051466434yiv3703906000green { color:#628c2a;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 .ygrps-yiv-1051466434yiv3703906000MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 o { font-size:0;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000photos div { float:left;width:72px;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000reco-category { font-size:77%;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000reco-desc { font-size:77%;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 .ygrps-yiv-1051466434yiv3703906000replbq { margin:4px;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-mlmsg select, #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 input, #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-mlmsg pre, #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 code { font:115% monospace;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-mlmsg #ygrps-yiv-1051466434yiv3703906000logo { padding-bottom:10px;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-msg p#ygrps-yiv-1051466434yiv3703906000attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-reco #ygrps-yiv-1051466434yiv3703906000reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-sponsor #ygrps-yiv-1051466434yiv3703906000ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-sponsor #ygrps-yiv-1051466434yiv3703906000ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-sponsor #ygrps-yiv-1051466434yiv3703906000ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-text { font-family:Georgia;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-text tt { font-size:120%;} #ygrps-yiv-1051466434 #ygrps-yiv-1051466434yiv3703906000 #ygrps-yiv-1051466434yiv3703906000ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1051466434
Gene Haines
To: fairchildclub
To: fairchildclub
