'Does anyone know where I can get a set of those annoying 63175 wing hinge bolt washers?
David
Re: 63175 wing hinge bolt washers?
William Hatfield
'Is this what you're looking for?
http://www.maperformance.com/rear-toe-lock-kit-w63175.html#.UYeisErKT0k
On Sun, May 5, 2013 at 11:42 PM, David McCord
[Non-text portions of this message have been removed]'> **
> bolt washers?
> Thanks,
> David
Gene Haines
'Those do not look like the washers. The Drawings for the washers are on the Fairchild Drawing DVD's many of you have. The bolts are part numbers 63136 and 63137. The leads that screw on the bolts to guide the bolt through the hinge holes are SK 5-367 and SK 5-368. The are located under the bolt number if you scan forward or back from the bolt drawings. I am home now but will get the part number for the washers and send the drawing numbers.
Gene Haines
To: fairchildclub
Sent: Mon, May 6, 2013 8:32 am
Subject: Re: [fairchildclub] 63175 wing hinge bolt washers?
Gene Haines
To: fairchildclub
[Non-text portions of this message have been removed]> **
> bolt washers?
> Thanks,
> David
David McCord
'Here's the drawing of the washer I'm looking for:
http://www.ranchaerowingshop.com/PT-19/63175Washer.jpg
David
David
Sent: Monday, May 06, 2013 5:32 AM
>> bolt washers?
>> Thanks,
>> David
