Re: enlighten me
enlighten me
'Fellow Fairchild enthusiasts:
I am an old A&P, with a great number of projects behind me.....and now I want to restore a Fairchild.
I am contemplating several F-24 projects...all with sketchy or no records....I need some help in identifying the fuselage frames.
Did Fairchild put any identification tags or data on the welded tube structure?
One project has the engine mount welded integral to the frame, and looks like it would take the Ranger engine.
Other local Ranger projects all have a detachable engine mount, with dynafocals...
any wisdom you can share on this frame is appreciated
Jeff Whitesell
topfun@fivetogether.com'
Jeff Whitesell
Re: enlighten me
'Jeff,
Old A&P's need projects too:)
I have never found any ID on the airframe structure. Only on the old Stearmans.
Your correct on the perm mount, takes a Ranger, most likley was a 165HP (390).
Ranger engine mounts for the F-24 series are hard to come by. The Club does have a Ranger engine mount jig. I keep track of it.
The FC Club also have the DVD with plently of data to help you out.
You can get it direct from me. Plently of help out there. Not much we can't fabricate.
Don't hesitate to call.
Sent: Tuesday, November 20, 2012 11:39:19 AM
Subject: [fairchildclub] enlighten me
Jeff Whitesell
Re: enlighten me
'oops forgot the picture
Gentlemen:
This is a GREAT forum, to be able to uncover the mysteries...My thanks for your time.
Attached is a picture of the mystery mount, which is very different from the Ranger mount that I see on the F-24 R that is being restored by the CAF here in Camarillo.
What vintage frame is this likely to be?
This poor thing has been in the weeds many years, and every time I see it , she cries out to me to save her.
Can this frame be modified to take the 200 HP Ranger?
thanks again
Jeff
Gentlemen:
thanks again
Jeff
'On Nov 20, 2012, at 1:37 PM, Jamie Treat wrote:
> Bill,
> Most of the the Short nose versions have been converted to 175 or 200 Rangers. The 390 is hard to support. Cyl parts from the V-770 will work.
> I always liked the small tail short nose with Gull wing cowl. Bob Haas had a beauty.
> As for the fuel. I have never had the metering pin stick on the larger Marvel or Stromberg carbs. Yes I have had them stick on the smaller carbs for the Cont series when equiped with SS metering pins and brass seats esp in cold weather.
> I have always shut the Ranger down with mixture. And have always shut the fuel off. Never an issue.
> Try using idle cut off and leave the fuel on for a few hours so. Check it within the cooling hour to see if it is leaking. If it leaks, it may be time to pull apart and clean the needle and seat. Tom did run autofuel in the bird at a 50/50 rate at times. It sat alot as you know. It could be coated with some varnish.
> JST
> From: "William Creighton"
> To: "Jamie Treat"
> Cc: topfun@fivetogether.com
> Sent: Tuesday, November 20, 2012 2:17:54 PM
> Subject: RE: [fairchildclub] enlighten me
> Jamie, Jeff:
> Pretty sure the '39 Short-nose 24 that I considered buying in FL a few years ago had a Ranger 200 hp 440 in it. Beauty is in the eye of the beholder, but the Fairchild dimensions seemed better balanced on the short-nose, versus the long-nose like I have.
> Jamie, quick one. I've recently been suffering carb overflow during pre-flight when I open a fuel valve. First time I was able to solve it by stroking the throttle several times. Last weekend that approach didn't work, so I uncowled and rapped on the carb with a plastic srewdriver handle. Anyway, I'm wondering if my shutting off the fuel valve during shutdown, before pulling the mixture is emptying the carb bowl, and that's causing the float needle to not properly seat? Behavior is same regardless of which fuel valve is opened during pre-flight... FWIW, I pulled the mixture and let the engine quit last time out before shutting off the fuel valve.
> Regards,
> Bill C.
> CC: topfun@fivetogether.com
> From: jamietreat@q.com
> Date: Tue, 20 Nov 2012 14:38:38 -0500
> Subject: Re: [fairchildclub] enlighten me
> Jeff,
> Jamie
> From: "Jeffrey Whitesell"
> Jeff Whitesell
Jeff Whitesell
Re: enlighten me
'Hi Jamie,
You mentioned 390 Ranger Engine.. I have a core crankcase with a tapered
crankshaft.. In talking with Joe Denest, he says he has set of cylinders...
I's been started to junk yard twice but I keep thinking someone may have a
use for it. Have all the old models been changed over to the 440's.
Have a great evening... John
Cc:
Sent: Tuesday, November 20, 2012 1:38 PM
Jeff,
Stearmans.
(390).
fabricate.
structure?
dynafocals...
Jeff Whitesell
Re: enlighten me
'John,
Just talked to Jim. The owner Jives contracted with Joe Denest to build up a 200hp Ranger. Not going to overhaul the smaller engine. We believe it is a 410, not too sure, really bad paperwork on the engine and airframe. Lists as a 41, but is a small tail 37H.
JST
From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com] On Behalf Of John Ellis
Sent: Tuesday, November 20, 2012 5:45 PM
Hi Jamie,
JST
Hi Jamie,
Cc:
Jeff,
Stearmans.
(390).
fabricate.
structure?
dynafocals...
Jeff Whitesell
Re: enlighten me
'Jeff,
Early Fairchild 24s (at least the ranger powered ones)had the engine mount integral to the frame. These are referred to as the 'short nosed' Rangers. The problem for the company, was that they had to know what engine they were going to mount on the airplane when they began building the fuselage. During the preparations for WWII, lots of Ranger engines were needed for the PT-19s and PT-26s, and there wouldn't always be a Ranger available for the 24.
Starting with the 24-R model, Fairchild made a removable engine mount, allowing the factory to build a fuselage and later decide which engine to install. These aircraft are 11 inches longer than the earlier models, allowing the oil tank to be mounted on the firewall, and allowing the oil cooler to be moved up under the cowl, and requiring the battery to be moved to the tail. The removable mount increased the weight of the fuselage and the max gross weight was not changed, therefor the earlier 'short nosed' Fairchild 24s had a slightly greater 'useful load'.
Good luck on your selection of a project and the restoration of another wonderful airplane.
Webster, MN
1939 Fairchild 24K "short nosed"
Webster, MN
> Jeff Whitesell
> topfun@...
Re: enlighten me
'Bob
Thank you. This is very helpful information. So this frame fits your description, as it has what appears to be a battery box on the left side of the engine mount..
Can we further isolate the type as being "small tail" vs the larger, later tail?
Can you tell from the picture if the mount will accept a 200 Hp ranger?
thanks
Jeff
thanks
Jeff
'On Nov 20, 2012, at 6:36 PM, Bob wrote:
> Jeff,
> Bob Waldron
> Webster, MN
> > Jeff Whitesell
> > topfun@...
Jeff Whitesell
Re: enlighten me
'Jeff,
I have not seen your photo, but it probably wouldn't help me at all.
My 24K was shipped with a 165 hp engine and my IA got a 337 for installing the 200 hp with a plaque that states that the take-off should be kept below 165 hp. I have the Beechcraft adjustable prop and am normally unable to exceed 165 hp on takeoff at my 1000' msl strip. 165 hp is determined from the chart showing rpm and manifold pressure.
I don't know a 'small tail' from a 'large tail', but I do know that the Earliest 24s were certified THREE PERSON airplanes. The later FOUR PERSON airplanes are about two inches wider. Aircraft Spruce sells two different fuselage fabric envelopes. The earlier one won't fit the later models without slitting the fabric near the rear window - and sewing a big ugly dart into the fabric. I provided the pattern for the later model fuselages.
Webster, MN
1939 Fairchild 24K
Webster, MN
1939 Fairchild 24K
> Bob
> thanks
> Jeff
> > Jeff,
> > Bob Waldron
> > Webster, MN
> > > Jeff Whitesell
> > > topfun@
> Jeff Whitesell
> topfun@...
Re: enlighten me
'Bob,
Can you tell me please when you told A/C Spruce about the wider fuselage and that their older envelopes did not fit.
I bought a set of envelopes for a 'Quick recover job' that are still in the box about 19 years ago! and now, after the ensuing rebuild, am just about ready to cover.
I don't really want to buy another one if I can help it.
Many thanks,
UC61K G-BCBL
Many thanks,
UC61K G-BCBL
'--- In fairchildclub@yahoogroups.com, "Bob" wrote:
> Jeff,
> Bob Waldron
> Webster, MN
> 1939 Fairchild 24K
> > Bob
> > thanks
> > Jeff
> > > Jeff,
> > > Bob Waldron
> > > Webster, MN
> > > > Jeff Whitesell
> > > > topfun@
> > Jeff Whitesell
> > topfun@
Re: enlighten me
'Frank,
About twenty years ago, I tried to install an envelope on my fuselage. It was too small. At that time, I remembered seeing many Fairchild 24s with an ugly dart added towards the rear window. I realized that the envelope was the wrong size. I talked to a wonderful lady who was the chief envelope producer at Alexander Aero and had a newer one produced from my pattern. Alexander Aero then listed BOTH envelopes in their catalog -- one for early models and one for later models. I think 24-G and later, were the larger envelope.
Alexander Aero was later purchased by Aircraft Spruce. I thought that Aircraft Spruce continued BOTH sizes, but I see now that they only list ONE size, called 24G R&W.
If I were you, I would call them. Aircraft Spruce EAST, is the company that used to be Alexander Aero, and I think that they are probably the people that still sew the envelopes.
Webster, MN
1939 24K
Webster, MN
1939 24K
'--- In fairchildclub@yahoogroups.com, "Frank" wrote:
> Bob,
> Many thanks,
> Frank Cox
> UC61K G-BCBL
> > Jeff,
> > Bob Waldron
> > Webster, MN
> > 1939 Fairchild 24K
> > > Bob
> > > thanks
> > > Jeff
> > > > Jeff,
> > > > Bob Waldron
> > > > Webster, MN
> > > > > Jeff Whitesell
> > > > > topfun@
> > > Jeff Whitesell
> > > topfun@
