'The good book says to use graphite grease well rubbed into the felt pads through which the elevator control rods pass.
I was wondering if there was something better ie. a silicone grease which would do the job and be less messy and possibly better.
Any thoughts gratefully received
UC61K G-BCBL'
Re: Graphite Grease substitute
'Along this line, maybe someone could provide some insight. In my 24, I have always had a odd sort of squeek coming from the left wing when actuating the ailerons. I was able to see (with difficulty) that the source of the sound is a felt pad around the aileron push/pull tube, where it rubs a bit. Trouble is, there is no inspection hole provided to gain access to the immediate area to try any fixes. Is is just a little annoying, and does not affect the operation in any way, so I've lived with it. Any ideas?
Bill McClure
To: fairchildclub
Sent: Thu, Jul 12, 2012 6:14 am
Subject: [fairchildclub] Graphite Grease substitute
UC61K G-BCBL
Bill McClure
To: fairchildclub
UC61K G-BCBL
Does anyone have a source for the above mentioned push pull tube felt collars. Has anyone added the grease to their felt liners?
Steve
Steve
'Just a little information that worked, but is a little messy. When you find the proper felt, thickness, put it in a pan of water and freeze it. Bore a 1/4" hole in the center and cut the outer diameter with a hole saw. Put a mandrel in the center and connect it to a drill press and cut the groove. Maybe under cut the diameter slightly. Then remove the mandrel and cut the center diameter. Since you have the center hole of 1/4", it will stay centered. Then set it a side and let it defrost and dry out.Freezing it in water, will allow you to get a clean of the felt without tearing it to useless pieces. I can guarantee it will be messy. Cut all of the big first, put back in the freezer. Then do each task one at a time and refreeze. It will be less messy. Bob
On Tuesday, August 23, 2016 2:18 PM, "ac500shrike81@yahoo.com [fairchildclub]" wrote:
Thanks,Steve
#ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 -- #ygrps-yiv-297157097yiv6043433022ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-mkp #ygrps-yiv-297157097yiv6043433022hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-mkp #ygrps-yiv-297157097yiv6043433022ads { margin-bottom:10px;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-mkp .ygrps-yiv-297157097yiv6043433022ad { padding:0 0;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-mkp .ygrps-yiv-297157097yiv6043433022ad p { margin:0;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-mkp .ygrps-yiv-297157097yiv6043433022ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-sponsor #ygrps-yiv-297157097yiv6043433022ygrp-lc { font-family:Arial;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-sponsor #ygrps-yiv-297157097yiv6043433022ygrp-lc #ygrps-yiv-297157097yiv6043433022hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-sponsor #ygrps-yiv-297157097yiv6043433022ygrp-lc .ygrps-yiv-297157097yiv6043433022ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022activity span { font-weight:700;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022activity span:first-child { text-transform:uppercase;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022activity span span { color:#ff7900;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022activity span .ygrps-yiv-297157097yiv6043433022underline { text-decoration:underline;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 .ygrps-yiv-297157097yiv6043433022attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 .ygrps-yiv-297157097yiv6043433022attach div a { text-decoration:none;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 .ygrps-yiv-297157097yiv6043433022attach img { border:none;padding-right:5px;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 .ygrps-yiv-297157097yiv6043433022attach label { display:block;margin-bottom:5px;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 .ygrps-yiv-297157097yiv6043433022attach label a { text-decoration:none;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 blockquote { margin:0 0 0 4px;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 .ygrps-yiv-297157097yiv6043433022bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 .ygrps-yiv-297157097yiv6043433022bold a { text-decoration:none;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 dd.ygrps-yiv-297157097yiv6043433022last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 dd.ygrps-yiv-297157097yiv6043433022last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 dd.ygrps-yiv-297157097yiv6043433022last p span.ygrps-yiv-297157097yiv6043433022yshortcuts { margin-right:0;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 div.ygrps-yiv-297157097yiv6043433022attach-table div div a { text-decoration:none;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 div.ygrps-yiv-297157097yiv6043433022attach-table { width:400px;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 div.ygrps-yiv-297157097yiv6043433022file-title a, #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 div.ygrps-yiv-297157097yiv6043433022file-title a:active, #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 div.ygrps-yiv-297157097yiv6043433022file-title a:hover, #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 div.ygrps-yiv-297157097yiv6043433022file-title a:visited { text-decoration:none;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 div.ygrps-yiv-297157097yiv6043433022photo-title a, #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 div.ygrps-yiv-297157097yiv6043433022photo-title a:active, #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 div.ygrps-yiv-297157097yiv6043433022photo-title a:hover, #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 div.ygrps-yiv-297157097yiv6043433022photo-title a:visited { text-decoration:none;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 div#ygrps-yiv-297157097yiv6043433022ygrp-mlmsg #ygrps-yiv-297157097yiv6043433022ygrp-msg p a span.ygrps-yiv-297157097yiv6043433022yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 .ygrps-yiv-297157097yiv6043433022green { color:#628c2a;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 .ygrps-yiv-297157097yiv6043433022MsoNormal { margin:0 0 0 0;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 o { font-size:0;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022photos div { float:left;width:72px;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022photos div div { border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022reco-category { font-size:77%;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022reco-desc { font-size:77%;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 .ygrps-yiv-297157097yiv6043433022replbq { margin:4px;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-mlmsg select, #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 input, #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-mlmsg pre, #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 code { font:115% monospace;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-mlmsg #ygrps-yiv-297157097yiv6043433022logo { padding-bottom:10px;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-msg p#ygrps-yiv-297157097yiv6043433022attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-reco #ygrps-yiv-297157097yiv6043433022reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-sponsor #ygrps-yiv-297157097yiv6043433022ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-sponsor #ygrps-yiv-297157097yiv6043433022ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-sponsor #ygrps-yiv-297157097yiv6043433022ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-text { font-family:Georgia;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-text tt { font-size:120%;} #ygrps-yiv-297157097 #ygrps-yiv-297157097yiv6043433022 #ygrps-yiv-297157097yiv6043433022ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-297157097
Thanks,Steve
Bob,
Thanks for the tip. I'll give it a shot.
Steve
Bob,
Steve
