'Folks -
1. I am about to fix the Balsa fairings to the lower longerons to the F24. I would appreciate opinions as to whether they should be 'Sealed' with varnish (I'm using Poly Fibre Epoxy) before applying the adhesive (Strong contact adhesive) to hold them in place or apply the adhesive to virgin wood and seal the exposed balsa after fixing.
All opinions gratefully received
2. There is one grease nipple missing from the gear attachment fittings and finding a replacement is proving very difficult - nobody seems to make them that small these days (1/4AF wrench required). Any body got any good leads as to where I might find one?
The project moves slowly forward!
With many thanks
Frank
UC61K G-BCBL'
Re: Lower longeron balsa wood
'Frank,
I use T-88 for the bonding and then coat with two coats of Stits Two part
epoxy varnish.
JST
On Behalf Of Frank
Sent: Thursday, May 10, 2012 3:16 AM
Subject: [fairchildclub] Lower longeron balsa wood
Folks -
With many thanks
Frank
UC61K G-BCBL
epoxy varnish.
JST
On Behalf Of Frank
Folks -
With many thanks
Frank
UC61K G-BCBL
'Some angle zerks have the small zerk threaded in at the angle.
www.eaa75.com
On Behalf Of Frank
Sent: Thursday, May 10, 2012 4:16 AM
Folks -
With many thanks
Frank
UC61K G-BCBL
www.eaa75.com
On Behalf Of Frank
Folks -
With many thanks
Frank
UC61K G-BCBL
'We used the same as Jamie for our UC-61K restoration
Jim C
UC-61K 43-14964
Sent: Thursday, May 10, 2012 7:21 AM
Subject: RE: [fairchildclub] Lower longeron balsa wood
Frank,
epoxy varnish.
JST
On Behalf Of Frank
Folks -
With many thanks
Frank
UC61K G-BCBL
Jim C
UC-61K 43-14964
Frank,
epoxy varnish.
JST
On Behalf Of Frank
Folks -
With many thanks
Frank
UC61K G-BCBL
'Thank you guys, very much
- no doubt I'll find some suitable adhesive over this side of the pond and I already use the Stitts varnish - magic stuff but V. expensive!
Frank
UC61K G-BCBL
PS -- Anybody out there any suggestion where I might find a small grease nipple for the gear attachment fittings?
Frank
UC61K G-BCBL
> Jim C
> UC-61K 43-14964
> From: Jamie Treat
> Â
> Frank,
> epoxy varnish.
> JST
> On Behalf Of Frank
> Folks -
> With many thanks
> Frank
> UC61K G-BCBL
