'While checking the torque (80 in/lbs) on the cam cover nuts I found 4
pulled studs.
Can the 'Ranger Gurus' out there please tell me whether Helicoil inserts
are a 'doable fix' or should I go another route (oversize studs)?
I don't think Helicoils were around when the repair manual was printed.
Many thanks
UC61K G-BCBL
Re: Ranger pulled Cam Cover Studs
Jack Threadgill
'For what it's worth, I had a similar experience before having my engine
completely rebuilt last year by John Ellis. I removed five pulled cam cover
studs and cleaned them and the holes with carb cleaner spray. Blew them dry
and reinstalled them with JB Weld. I let them set up for a couple of days
and replaced the nuts to 70 in-lbs. This may not be considered proper
repair, but it worked.
Jack
On Behalf Of Frank
Sent: Sunday, April 08, 2012 5:35 AM
Subject: [fairchildclub] Ranger pulled Cam Cover Studs
pulled studs.
Many thanks
UC61K G-BCBL
Jack
On Behalf Of Frank
pulled studs.
Many thanks
UC61K G-BCBL
Mike Danielle
'Oversized studs are a pain because of the different sized nuts you'll
encounter next time you remove the cover. I've gone the helicoil route with
good success.
On Behalf Of Frank
Sent: Sunday, April 08, 2012 3:35 AM
pulled studs.
Many thanks
UC61K G-BCBL
Yahoo! Groups Links'
good success.
On Behalf Of Frank
pulled studs.
Many thanks
UC61K G-BCBL
ptcurt@gmail.com
'Pretty common problem and I have used helicoils as the solution. But anytime you can fix something with JB Weld its pretty cool.
Sent via BlackBerry by AT&T
Date: Sun, 8 Apr 2012 07:36:50
Reply-To: fairchildclub@yahoogroups.com
Subject: RE: [fairchildclub] Ranger pulled Cam Cover Studs
Jack
On Behalf Of Frank
pulled studs.
Many thanks
UC61K G-BCBL
Jack
On Behalf Of Frank
pulled studs.
Many thanks
UC61K G-BCBL
Jack Threadgill
'One advantage to the JB Weld procedure is that the cover does not have to be
removed to drill the oversize holes for the helicoils. I suspect if the
cover is being removed anyway, then the helicoil is probably a more
permanent and accepted method of repair.
Jack
On Behalf Of ptcurt@gmail.com
Sent: Sunday, April 08, 2012 10:46 AM
Subject: Re: [fairchildclub] Ranger pulled Cam Cover Studs
[/quote]Reply-To: fairchildclub@yahoogroups.com
Jack
On Behalf Of Frank
pulled studs.
Many thanks
UC61K G-BCBL
Jack
Jack
On Behalf Of Frank
pulled studs.
Many thanks
UC61K G-BCBL
'Many thanks to all - such speedy replies - very much appreciated.
Helicoils it will be - and the cover will have to come off.
This engine has been in store for ten years after a rebuild in a certified engine shop! not only this but the mags were wired to the opposite side plugs.
I am getting the 'firewall forward' built up on a stand and do not really need this extra hassle - But what's another day or two after twenty years?
PS. John - What would be the recommended torque for installing these studs? I can't find it in the 'Table of torque values'.
> Jack
> On Behalf Of ptcurt@...
> Curt Kinchen
> From: "Jack Threadgill" >
> To: >
> Jack
> On Behalf Of Frank
> pulled studs.
> Many thanks
> Frank Cox
> UC61K G-BCBL
