'I have sent a request to the Smithsonian asking for drawing for the 24, they send my order form and money back stating that they were not reproducing the drawings at this time and could not tell me when they would be back to doing so, maybe the earlier part of 2012 not sure.
So my question to you ALL is dose anyone have drawings for the 46 24 R or W that I could get so I can start my restoration project on my 1946 24W N81288 sn 46215,
Any thing would be greatly appreciated.
Brett'
Re: 1946 Fairchild 24 R or W Drawing
'Brett,
The FC Club has many of them on CD ROM. Good to poor cond.
Contact me direct.
JST
Fairchild Club CD ROM Editor
IAC 5, Chapter President
http://iac5.org
Kelly Airpark (CO15)
http://www.kellyairpark.com
Hm/Hgr 303-648-0130
Cell 303-304-7937
Quote of the Month: I hope you either take up parachute jumping or stay out
of single motored airplanes at night. - Charles A. Lindbergh, to Wiley Post
1931
On Behalf Of Brett
Sent: Wednesday, September 21, 2011 6:47 AM
Subject: [fairchildclub] 1946 Fairchild 24 R or W Drawing
sn 46215,
Brett
Contact me direct.
JST
http://iac5.org
Hm/Hgr 303-648-0130
Cell 303-304-7937
1931
On Behalf Of Brett
sn 46215,
Brett
'Brett
The Smithsonian told me that they are relocatng the archives and will resume making copies next year sometime. I have the complete list of Drawings for the 1946 F24. Joining the Fairchild Club and purchasing a copy of the club disc will get you quite a few but not all, but there is alot of other good information. I know of several other Fairchild owners including myself who are looking for drawings as well. I would be glad to send the list, just send me an email at higham_jim@yahoo.com and I will atach it to a reply.
Jim Higham
F24R46-108
N81204
Jim Higham
F24R46-108
N81204
> Thanks
> Brett
'I have the Club CD, but have never figured out how to navigate it. Does anyone know is there an index or the like I am missing?
Also, I have had trouble with a VMN7D magneto on my Warner 145. Thinking coil or condenser. I have located a couple, but it seems these are hard to come by in general. Does anyone know of a supplier? Thanks.
Bill McClure
To: fairchildclub
Sent: Wed, Sep 21, 2011 9:25 am
Subject: Re: [fairchildclub] 1946 Fairchild 24 R or W Drawing
Brett
Jim Higham
F24R46-108
N81204
Bill McClure
To: fairchildclub
Brett
Jim Higham
F24R46-108
N81204
> Thanks
> Brett
'On the bottom of the drawing list there are 2 index. One sorts by drawing number the other by name. Make sure you verify the drawing is for your airplane
Jim Higham
Aviation Turbines International
Engine Sales/Service
(319) 533-7890
Jim Higham
(319) 533-7890
> Bill McClure
> From: Jim
> To: fairchildclub
> Brett
> Jim Higham
> F24R46-108
> N81204
> > Thanks
> > Brett
'Hello Bill McClure,
For magneto work, try Savage Magneto Service, 2415 Radley Ct, #7, Hayward, CA 94545, contact person is Al Marcucci, 510 782-7081.
Regards, John Duncan
Sent: Wednesday, September 21, 2011 8:13 AM
Jim Higham
(319) 533-7890
> Bill McClure
> From: Jim
> To: fairchildclub
> Brett
> Jim Higham
> F24R46-108
> N81204
> > Thanks
> > Brett
'Bill,
There is a TOC on the CD. Give me a call and I can walk you through.
JST
JST
Sent: Wednesday, September 21, 2011 7:30:25 AM
Bill McClure
To: fairchildclub < fairchildclub@yahoogroups.com >
Brett
Jim Higham
F24R46-108
N81204
> Thanks
> Brett
'The only trouble that I ever had with the VMN7DF as the oil paper seat for for one of the bearing had dried and the outer race started to turn I wear the paper. It started to wobble in the seat. It caused some serious mis-fires. It didn't show up until after the motor was warmed up. For some unknown reason, (I was holding for 15 minutes) I did a second Mag check prior to take off (attempted) and I was greeted with a second of silence, followed by a large bang.
When I took the mag apart, one of the out bearing shell fell out into my hands.
Anyone the works around P&W 985's can help you. They use the same basic unit, but no spark retard. That can be removed from your old Mag and added without much difficulty.
Sent: Wednesday, September 21, 2011 6:30 AM
Bill McClure
To: fairchildclub
Brett
Jim Higham
F24R46-108
N81204
Bill McClure
To: fairchildclub
Brett
Jim Higham
F24R46-108
N81204
> Thanks
> Brett
'Thanks to those who replied. I did find two coil assys and condensers. Replaced same, all is well. Since I replaced both, not sure which was giving the trouble, just wanted to get it running again so did not replace one then the other. Based upon experience with another radial I'd say it was probably a condenser. but not sure. May try them out singly later.
While searching for parts I spoke with Al Marcuci at Savage Magneto. Late in the week he called me back to say that he had heard someone was making up a batch of new coils. Not sure of details, but there is that word. Condensers seem available, coil assy seems to be harder to get.
Also recently had to R&R right fuel tank due to leak, started small but got worse. About a 2" stress crack in seam at base of pressed out sump, plus a couple of smaller leaks. Sent out to Sinclair Aircraft in Hampton, NH for repair/welding, a real nice job. Then, a pretty fair bit of work to restore fabric and match, etc. All OK for now.
Bill McClure
I sure do appreciate this forum for mutual support.
To: fairchildclub
Sent: Sun, Sep 25, 2011 12:59 pm
Bill McClure
To: fairchildclub
Brett
Jim Higham
F24R46-108
N81204
Bill McClure
To: fairchildclub
Bill McClure
To: fairchildclub
Brett
Jim Higham
F24R46-108
N81204
> Thanks
> Brett
