'Folks, Am I correct in thinking that there are seals that fit around the shafts of the fuel shut off valves?
 I have one retaining nut with what looks like the remains of a seal held in by a brass washer which I do not want to force out yet, and the other has nothing, but there is an unthreaded area at the base of the nut below the thread that looks like it should have a seal or something.
 If seals should be there what are people using for both the seal and retaining washers? or are you all relying on a well seated valve body to prevent any leaks!
 Any guidance will be very much appreciated.
 Frank
 UC61K  G-BCBL'
						Re: F24 Fuel valve shaft seals?
'Frank,
When I got my Fairchild both shutoff valves weeped to a small degree. Still it was something I wasn't going to live with. After tearing them down a number of times I have come to the conclusion, the cone and the seat must be just about perfect. You can lap this yourself. Take your time, make'm smooth as glass. I don't think the "O" ring or small packings with a brass ring were ever meant to seal anything, but a way of appling pressure to the spring to keep the cone nicely seated. Brass ring faces the spring, then the packing, then the outside nut. Nut doesn't need to be that tight. Make any sense?
Hanford,Ca
Hanford,Ca
> Frank
> UC61K G-BCBL
				F.J. & D.A. Cox
'Certainly does make sense, thank you Tom, - I am nowhere near flying and having fuel anywhere close to the valves. However I have lapped the cones, in antiucipation,  with 'Fine' valve grinding paste - should I get something finer to get the 'Mirror' finish you mention?
Frank
Devon UK
						Frank
Devon UK
Sent: Monday, June 06, 2011 6:07 PM
Subject: [fairchildclub] Re: F24 Fuel valve shaft seals?
Frank,
Hanford,Ca
> Frank
> UC61K G-BCBL
'Tooth paste works
On Behalf Of F.J. & D.A. Cox
Sent: Monday, June 06, 2011 1:51 PM
Subject: Re: [fairchildclub] Re: F24 Fuel valve shaft seals?
Frank
Devon UK
Frank
Devon UK
Frank,
sense?
Hanford,Ca
prevent any leaks!
> Frank
> UC61K G-BCBL
'Fine grade paste does a nice job, just back off to a lite pressure as you finish the lap job. . I think these valves, after being turned on and off for some seventy years, get a little egg shaped because of the same repetitious 90 degree turn, but they're certainly worth saving.
Hanford,Ca.
Hanford,Ca.
> Frank
> Devon UK
> From: Tom
> Frank,
> Tom
> Hanford,Ca
> > Frank
> > UC61K G-BCBL
