Re: Cleveland wheels and brakes for fairchilds.
Michael Kelly
Post by Michael Kelly »
'I was looking at the last Fairchild Flyer that John Berendt put out(2008 VOL 20 #2. He had some information about the Cleveland conversion. The 310 Kit has the 3 puck system. Some think the 3 puck is too much braking. I haven't heard of any problems with the 3 puck system but I guess if you got a little heavy on braking, you could over do the braking and maybe nose the plane up. His article has a 2 puck system by Cleveland Part No. 20-278. The wheel size is still a 650-10. I have a copy of a 337 for the Cleveland convertion on a PT in the Club files. Greg Ward did it years ago on the PT-23 they have in the Kalamzoo Aviation History Museum. There are a couple other PT's that have the Cleveland convertion on them that I know of. If anyone would like the owners names, let me know!
Keep 'em Flying!
Mike Kelly
Fairchild Club'
Jim higham
Post by Jim higham »
'Although it sounds logical that three pucks allow more braking action with less
control than two pucks, but using the original master cylinder with Cleveland
wheel cylinders having three actuating pistons (pucks) increase the
amount of travel the master cylinder piston moves to displace enough fluid to
actuate the braking action. By decreasing the wheel cylinder number of pucks by
a third also decreases master cylinder piston movement by a third and braking
action begins a third quicker. My preference is the more pedal travel the more
control you have as long as you don't run out of travel. These Cleveland wheel
cylinders were designed to be actuated by a .625" diameter bore master cylinder,
the Fairchild original master cylinder is 1.25" diameter bore displacing almost
twice as much fluid as the Cleveland's need. I found when I installed the
Cleveland master cylinder it increased the brake pedal travel and as far as I'm
concerned gave me better control and feel and it's almost impossible to
accidentally actuate them.
Sent: Wed, April 6, 2011 9:57:01 PM
Subject: [fairchildclub] Cleveland wheels and brakes for fairchilds.
know!
Keep 'em Flying!
Mike Kelly
Fairchild Club
Fritz
Post by Fritz »
'Well folks, I for one would like to get complete info on what is needed to
convert my PT-19 to the 310 system.
Fritz Mehrer
avdflyr@cox.net
Cell: 1-760-672-8126
On Behalf Of Jim Higham
Sent: Wednesday, April 06, 2011 8:40 PM
Subject: Re: [fairchildclub] Cleveland wheels and brakes for fairchilds.
less
Cleveland
to
by
braking
more
wheel
cylinder,
almost
I'm
20
the
any
article
Club
Cleveland
let me
know!
Keep 'em Flying!
Mike Kelly
Fairchild Club
Yahoo! Groups Links'
Post by Jim »
'Have you got the data disc from the Fairchild Club? It's got a FAA Data section with a good 8110-3 for a F24 and Field Approval 337 for the basis of approval to convert yours.
Jim Higham
Aviation Turbines International
Engine Sales
(319) 533-7890
> Thanks,
> Fritz Mehrer
> avdflyr@cox.net
> less
> Cleveland
> to
> by
> braking
> more
> wheel
> cylinder,
> almost
> I'm
> From: Michael kelly
> 20
> the
> any
> article
> Club
> Cleveland
> let me
> know!
> Keep 'em Flying!
> Mike Kelly
> Fairchild Club
Jay Thomson
Post by Jay Thomson »
'My 24 has the Cessna 310/3 puck system and is not overbraked at all.  The brakes feel the same as my Stinson 108-3 or any other airplane I've flown with disk brakes.  When I first purchased the plane I was a little concerned about it being too touchy on the but they have turned out to be very nice.  I have gotten on them pretty hard doing short field landings and have never felt that the tail was about to come off the ground.
Date: Wednesday, April 6, 2011, 8:57 PM
Keep 'em Flying!
Mike Kelly
Fairchild Club
Jay Thomson
'I can email you a copy of my 337 and data if you would like.
--- On Wed, 4/6/11, Fritz wrote:
Subject: RE: [fairchildclub] Cleveland wheels and brakes for fairchilds.
Date: Wednesday, April 6, 2011, 9:54 PM
Fritz Mehrer
avdflyr@cox.net
less
Cleveland
to
by
braking
more
wheel
cylinder,
almost
I'm
20
the
any
article
Club
Cleveland
let me
know!
Keep 'em Flying!
Mike Kelly
Fairchild Club
Fritz
Re: Cleveland wheels and brakes for fairchild.
Post by Fritz »
'Jim,
I don't have the CD from the Club. How can I identify which reference to
search to get it from the website??
Fritz
On Behalf Of Jim
Sent: Wednesday, April 06, 2011 9:11 PM
Jim Higham
Engine Sales
(319) 533-7890
> Thanks,
> Fritz Mehrer
> avdflyr@cox.net
> less
> Cleveland
> to
pucks
> by
> braking
> more
> wheel
> cylinder,
> almost
as
> I'm
> From: Michael kelly
VOL
> 20
has
> the
of
> any
> article
a
> Club
> Cleveland
> let me
> know!
> Keep 'em Flying!
> Mike Kelly
> Fairchild Club
Post by Jim »
'The website will not have what you are looking for. What you need is examples of 337 Field Approvals from previously modified aircraft to see how they accomplished their installation, you also reference this list of previously approved installations as part of your approved data in your Field Approval. These 337s will show exactly how install the brakes, which is simple, your IA can assist you. The only thing this chat room will show is the conversations regarding peoples installations. I do however recommend the Fairchild Club disc, as well as asking this chat group for registration numbers and copies of their 337s of previously approved aircraft. My registration number is N81207 and is F24R46-108, I also did a friends and his is N81363, F24r46-263. Although these are 24s and not PTs, the installations are the same and you can use the Instructions for Continued Airworthiness to help make yours. I would be glad to send you copies of mine but the Yahoo chat site won't allow attachments on emails, so if you email me at higham_jim@yahoo.com I will forward it to you.
On Apr 7, 2011, at 12:52 AM, "Fritz" wrote:
> Jim,
> Fritz
> On Behalf Of Jim
> Jim Higham
> Engine Sales
> (319) 533-7890
> > Thanks,
> > Fritz Mehrer
> > avdflyr@cox.net
> > less
> > Cleveland
> > to
> pucks
> > by
> > braking
> > more
> > wheel
> > cylinder,
> > almost
> as
> > I'm
> > From: Michael kelly
> VOL
> > 20
> has
> > the
> of
> > any
> > article
> a
> > Club
> > Cleveland
> > let me
> > know!
> > Keep 'em Flying!
> > Mike Kelly
> > Fairchild Club
> > Yahoo! Groups Links
Post by Jamie »
'All,
I heard a rumor that Cleveland (Parker) was not producing the 6:50 x 10 Taper Shaft Wheel assemblies (P/N 40-40A (6.50 x 10 as used on Cessna C-310)). This is not true. I confirmed today that they are and will continue to produce these wheels.
JST
--- In fairchildclub@yahoogroups.com, Jim wrote:
> The website will not have what you are looking for. What you need is examples of 337 Field Approvals from previously modified aircraft to see how they accomplished their installation, you also reference this list of previously approved installations as part of your approved data in your Field Approval. These 337s will show exactly how install the brakes, which is simple, your IA can assist you. The only thing this chat room will show is the conversations regarding peoples installations. I do however recommend the Fairchild Club disc, as well as asking this chat group for registration numbers and copies of their 337s of previously approved aircraft. My registration number is N81207 and is F24R46-108, I also did a friends and his is N81363, F24r46-263. Although these are 24s and not PTs, the installations are the same and you can use the Instructions for Continued Airworthiness to help make yours. I would be glad to send you copies of mine but the Yahoo chat site won't allow attachments on emails, so if you email me at higham_jim@... I will forward it to you.
> Jim
> (319) 533-7890
> > Jim,
> > Fritz
> > On Behalf Of Jim
> > Jim Higham
> > Engine Sales
> > (319) 533-7890
> > > Thanks,
> > > Fritz Mehrer
> > > avdflyr@...
> > > less
> > > Cleveland
> > > to
> > pucks
> > > by
> > > braking
> > > more
> > > wheel
> > > cylinder,
> > > almost
> > as
> > > I'm
> > > From: Michael kelly
> > VOL
> > > 20
> > has
> > > the
> > of
> > > any
> > > article
> > a
> > > Club
> > > Cleveland
> > > let me
> > > know!
> > > Keep 'em Flying!
> > > Mike Kelly
> > > Fairchild Club
> > > Yahoo! Groups Links
> > Yahoo! Groups Links
trp.8888
Post by trp.8888 »
'can someone send me the 337's for this brake conversion? I need to replace mine originals
TimNC25328
trp.8888@gmail.com'
