Re: Fabric covering Qestion?
'Hi,
I am trying to finish my long overdue F-24W46. Have installed the fabric and the
wing seaplane grommets on the wings.
The question is should I install drain grommets on the ailerons and elevator or
not? It appears to me that as those control surfaces deflect into the wind air
will be rammed into the drain hole and cause ballooning of the control surface.
As this is new to me, I need your response.
Thank you
JP.Lorie
Florida
Thank you
JP.Lorie
Florida
'Put em on.
'On 3/8/2011 4:28 PM, Jp Lorie wrote:
> Hi,
> fabric and the
> elevator or
> wind air
> surface.
> Thank you
> JP.Lorie
> Florida
'JP, Check the instruction manual for the covering process you are using or consult with your marerials supplier. Placement details for installation of drain gromments are in the Polyfiber covering instruction manual.if that is the process you are using.
'--- On Tue, 3/8/11, Jp Lorie wrote:
Subject: [fairchildclub] Fabric covering Qestion?
Date: Tuesday, March 8, 2011, 9:28 PM
Hi,
Thank you
JP.Lorie
Florida
'usually ventilation holes are always at the trailling edge, don't be afraid to do so on mobile control surface!
I never saw anything "ballooning"!
Date: Wed, 9 Mar 2011 06:18:32 -0800
Subject: Re: [fairchildclub] Fabric covering Qestion?
Hi,
Thank you
JP.Lorie
Florida
'Just wondering, JP...if the seaplane grommets are on the bottom and rear of the surfaces with
the drain hole pointing towards the rear, under what conditions could ram air enter. If anything I
think it might actually create some suction.
Like Hugh said, check the manual from your supplier.
By the way, AC43.13.1B says ....Install drain grommets on the underside of all components at
the lowest point in each fabric panel when the aircraft is in stored attitude. Earlier, it says....
atmospheric temperature changes cause the humidity in the air to condense on the inside of aircraft
surfaces in all low areas.
Christavia C-FDWS
Fairchild 51 replica
under construction C-FYXV
Christavia C-FDWS
Hi,
Thank you
JP.Lorie
Florida
Checked by AVG - www.avg.com
Version: 8.5.449 / Virus Database: 271.1.1/3493 - Release Date: 03/09/11 07:25:00
'Thus far, I have installed only seaplane grommets on the wing (opening to
the rear!). When I posted the question I was referring to washer style drain
grommets. Thanks for the reference. Would you suggest sea grommets on the
control surfaces as well? Or will they be perhaps too bulky?
JP.Lorie
Florida
Sent: Wed, March 9, 2011 9:41:00 AM
surfaces with
components at
inside of aircraft
Christavia C-FDWS
JP.Lorie
Florida
surfaces with
components at
inside of aircraft
Christavia C-FDWS
Hi,
Thank you
JP.Lorie
Florida
07:25:00
'But! Is your F24R a seaplane version?? on floats??
Otherwise you don't need any specific grommets, just as flat as possible not to generate too much vortex!
Date: Wed, 9 Mar 2011 06:55:53 -0800
JP.Lorie
Florida
surfaces with
components at
inside of aircraft
Christavia C-FDWS
JP.Lorie
Florida
surfaces with
components at
inside of aircraft
Christavia C-FDWS
Hi,
Thank you
JP.Lorie
Florida
07:25:00
'I don't think bulkiness will have much affect on anything. Flat washer type would
work fine too but make sure the hole is right under the lowest aft surface where
moisture could puddle.
Christavia C-FDWS
Christavia C-FDWS
Sent: Wednesday, March 09, 2011 9:55 AM
JP.Lorie
Florida
surfaces with
components at
inside of aircraft
Christavia C-FDWS
Hi,
Thank you
JP.Lorie
Florida
07:25:00
'I've put donuts on the ailerons and seaplane grommets on the wing. Seems to look right. Does much the same.
Bill McClure
Christavia C-FDWS
Bill McClure
Christavia C-FDWS
JP.Lorie
Florida
surfaces with
components at
inside of aircraft
Christavia C-FDWS
Hi,
Thank you
JP.Lorie
Florida
07:25:00
'Why use a Grommet at all. Melt the hole in your polyesther fabric with a small soldering iron.
www.eaa75.com
From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com] On Behalf Of DAVID STROUD
Sent: Wednesday, March 09, 2011 9:18 AM
Christavia C-FDWS
www.eaa75.com
Christavia C-FDWS
JP.Lorie
Florida
surfaces with
components at
inside of aircraft
Christavia C-FDWS
Hi,
Thank you
JP.Lorie
Florida
07:25:00
