I sent the pictures of the mystry mount to a Beech 18 restoration facility and the owner confirms the mount is not a Beech product and may be from a Cessna Airmaster or 195.
If anyone knows of someone with either of these aircraft, please forwad the pictures to them. We are all dying to know what this mount goes on.
Jim Chybicki
UC-61K
'--- In fairchildclub@yahoogroups.com, Patricia Banks wrote:
> I only know that the isolators were adopted directly from the Cessna T-50 mount. The Serv-Aero guys told me that they are no longer available. They worked with several suppliers over the years but the sources have all since gone out of business. I know that there are a couple of guys trying to have new ones custom manufactured. I don't know what the few remaining T-50 owners are doing either. Fortunately the original isolators are pretty tough ... mine have to be over 20 yrs old and they still look fine. No cracking, dry rot, or separation. Hopefully they will last a while longer.
> --- On Wed, 3/2/11, Fritz wrote:
> From: Fritz
> Subject: RE: [fairchildclub] Re: Jake Powered F24
> Date: Wednesday, March 2, 2011, 9:34 PM
> If the isolators are the same as used with the Continental and the PT-23,
> you can buy hundreds of them from Lance Aircraft in Texas or Dusters and
> Sprayers Supply in Oklahoma....
> -----Original Message-----
> From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
> On Behalf Of Patricia Banks
> Sent: Wednesday, March 02, 2011 12:55 PM
> Subject: Re: [fairchildclub] Re: Jake Powered F24
> Have to agree with George ... definitely not a Jake to F24 mount. The Jake
> mount carried over from the Cessna T-50 mount with the same engine ring and
> the rubber isolators at the firewall. The isolators are impossible to obtain
> these days which will eventually become a problem for us Jake guys.
> I believe that Serv-Aero also produced a mount to put a Continental radial
> on the F24 but I have no idea what it looks like.
> You might send the photo to the Serv-Aero guys and see if they can identify
> it.
> Matt
> F24 - N4263S
> --- On Wed, 3/2/11, Jp Lorie wrote:
> From: Jp Lorie
> Subject: [fairchildclub] Re: Jake Powered F24
> Date: Wednesday, March 2, 2011, 1:01 PM
> Alright, I finally go around to learning how to post pictures on this site.
> Just posted the Engine Mount--Unknown album to see if you can tell what it
> is
> Thanks again! JP.Lorie
> Florida
> ________________________________
> From: Matt & Patty
> Sent: Thu, February 24, 2011 6:25:11 PM
> Didn't get any photos JP. Did you place them in one of the albums?
> Anyway ... if it is a Jake mount it was built by Serv-Aero. But they have
> built
> hundreds of unique mounts for different applications. I talked to the
> deceased
> owners son several weeks ago and he mentioned to me that when his dad built
> these mounts he assigned them a S/N and attached a data plate to them with
> the
> drawing number which should be 1026 for the F24 mount. Some of them have
> apparently had the plates removed or there was never one installed for
> whatever
> reason. I have yet to find mine but it could be buried from view under the
> rats
> nest of hoses, tubes, wires, and accessories. I'm pretty sure I could
> identify
> your mount by sight if it is in fact a serv-aero Jake mount and it would be
> easy
> to confirm with a couple of dimensions.
> Matt
> F24 - N4263S
> --- In fairchildclub@yahoogroups.com, Jp Lorie wrote:
> > Hello, Flyingbanks and others with a Jake powered F24
> > I have attached pictures of a mount to see if someone can
> help identify it
> > as a Jake mount/or not, for an F24. Notice that the firewall attachment
> point
> >is
> > different from that of a Warner
> > powered mount.
> > Thanks
> > JP.Lorie
> > Florida
