Re: Jake Powered F24
Jake Powered F24
'Hello, Flyingbanks and others with a Jake powered F24
I have attached pictures of a mount to see if someone can help identify it
as a Jake mount/or not, for an F24. Notice that the firewall attachment point is
different from that of a Warner
powered mount.
JP.Lorie
Florida
powered mount.
JP.Lorie
Florida
Matt & Patty
'Didn't get any photos JP. Did you place them in one of the albums?
Anyway ... if it is a Jake mount it was built by Serv-Aero. But they have built hundreds of unique mounts for different applications. I talked to the deceased owners son several weeks ago and he mentioned to me that when his dad built these mounts he assigned them a S/N and attached a data plate to them with the drawing number which should be 1026 for the F24 mount. Some of them have apparently had the plates removed or there was never one installed for whatever reason. I have yet to find mine but it could be buried from view under the rats nest of hoses, tubes, wires, and accessories. I'm pretty sure I could identify your mount by sight if it is in fact a serv-aero Jake mount and it would be easy to confirm with a couple of dimensions.
Matt
F24 - N4263S
Matt
F24 - N4263S
> powered mount.
> Thanks
> JP.Lorie
> Florida
'I sent the pictures in as an attachment. If this is not the way to send in
pics, can someone plese give me detailed instructions on how to post these
pictures. Thanks.
Mat and Patty thanks for your reply, there is no tag on this mount. will try to
properly post the pics as soon as I figure out haw.
JP.Lorie
Florida
Sent: Thu, February 24, 2011 6:25:11 PM
Subject: [fairchildclub] Re: Jake Powered F24
Matt
F24 - N4263S
pictures. Thanks.
JP.Lorie
Florida
Matt
F24 - N4263S
>is
> powered mount.
> Thanks
> JP.Lorie
> Florida
'Alright, I finally go around to learning how to post pictures on this site.
Just posted the Engine Mount--Unknown album to see if you can tell what it is
Thanks again! JP.Lorie
Florida
Matt
F24 - N4263S
Florida
Matt
F24 - N4263S
>is
> powered mount.
> Thanks
> JP.Lorie
> Florida
Leighton, George
'JP.
That is deffinatly not a Jacobs mount for the f-24. I am not sure what
it is for.
George
[mailto:fairchildclub@yahoogroups.com] On Behalf Of Jp Lorie
Sent: Wednesday, March 02, 2011 10:01 AM
site.
it is
Florida
have built
deceased
built
with the
whatever
the rats
identify
be easy
Matt
F24 - N4263S
, Jp Lorie
it is for.
George
site.
it is
Florida
have built
deceased
built
with the
whatever
the rats
identify
be easy
Matt
F24 - N4263S
, Jp Lorie
identify it>
attachment point> as a Jake mount/or not, for an F24. Notice that the firewall
[Non-text portions of this message have been removed]>is
> powered mount.
> Thanks
> JP.Lorie
> Florida
Patricia Banks
'Have to agree with George ... definitely not a Jake to F24 mount. The Jake mount carried over from the Cessna T-50 mount with the same engine ring and the rubber isolators at the firewall. The isolators are impossible to obtain these days which will eventually become a problem for us Jake guys.
I believe that Serv-Aero also produced a mount to put a Continental radial on the F24 but I have no idea what it looks like.
You might send the photo to the Serv-Aero guys and see if they can identify it.
Matt
F24 - N4263S
Matt
F24 - N4263S
Date: Wednesday, March 2, 2011, 1:01 PM
Florida
Matt
F24 - N4263S
>is
> powered mount.
> Thanks
> JP.Lorie
> Florida
'If the isolators are the same as used with the Continental and the PT-23,
you can buy hundreds of them from Lance Aircraft in Texas or Dusters and
Sprayers Supply in Oklahoma....
On Behalf Of Patricia Banks
Sent: Wednesday, March 02, 2011 12:55 PM
Subject: Re: [fairchildclub] Re: Jake Powered F24
it.
Matt
F24 - N4263S
it.
Matt
F24 - N4263S
is
Florida
built
deceased
the
whatever
rats
identify
easy
Matt
F24 - N4263S
help identify it
point
>is
> powered mount.
> Thanks
> JP.Lorie
> Florida
ketrumpore@yahoo.com
'If you have a sample, a print, or even a sketch with dimensions, I may be able to help you. We remanufacture many engine mounts for different aircraft, including several different sizes for Fairchild's with rangers and warners. We also make mounts for Stinsons, Staggerwings, Fleetwing Seabird, Porterfield, and several others. You can contact me offline at ketrumpore at yahoo dot com, or call us at (908)459-5858.
Regards;
Kevin Trumpore
Southland Mfg. Co.
Connected by DROID on Verizon Wireless
-----Original message-----
Sent: Thu, Mar 3, 2011 02:34:10 GMT+00:00
Subject: RE: [fairchildclub] Re: Jake Powered F24
it.
Matt
F24 - N4263S
Regards;
Kevin Trumpore
Southland Mfg. Co.
it.
Matt
F24 - N4263S
is
Florida
David Stroud
'I'm not to cool with Dusters and Sprayers. They sell ( or used to sell ) new master cylinders compatible
to a BT-13 wheel brake cylinder for about $500 or so. You can get the same part, new on Ebay for about
$100. It's off a Ford F-100 pickup, can't remember the year. ....Hmmm.
Christavia C-FDWS
Fairchild 51 replica
under construction C-FYXV
Christavia C-FDWS
Sent: Wednesday, March 02, 2011 9:34 PM
it.
Matt
F24 - N4263S
is
Florida
built
deceased
the
whatever
rats
identify
easy
Matt
F24 - N4263S
help identify it
point
>is
> powered mount.
> Thanks
> JP.Lorie
> Florida
Checked by AVG - www.avg.com
Version: 8.5.449 / Virus Database: 271.1.1/3477 - Release Date: 03/02/11 07:34:00
Patricia Banks
'I only know that the isolators were adopted directly from the Cessna T-50 mount. The Serv-Aero guys told me that they are no longer available. They worked with several suppliers over the years but the sources have all since gone out of business. I know that there are a couple of guys trying to have new ones custom manufactured. I don't know what the few remaining T-50 owners are doing either. Fortunately the original isolators are pretty tough ... mine have to be over 20 yrs old and they still look fine. No cracking, dry rot, or separation. Hopefully they will last a while longer.
Date: Wednesday, March 2, 2011, 9:34 PM
it.
Matt
F24 - N4263S
is
Florida
built
deceased
the
whatever
rats
identify
easy
Matt
F24 - N4263S
help identify it
point
>is
> powered mount.
> Thanks
> JP.Lorie
> Florida
