Re: Strut packing & jacking the tail
robertetter@ymail.com
Post by robertetter@ymail.com »
'I have 2 sets of strut packings.
I also made a detachable jack pad for the tail of my "24". I need only to draw it up, then mail it. My computer isn't up to scanning.
It will fit between the mounting tabs for the drag link. It is a long "U" channel, with a extended pad on the bottom. Than a separate pin will fit through the "U" channel, and pinning below the small diagonal tube, just to the rear of the attach point.
Bob'
William Creighton
Post by William Creighton »
'Bob,
I've been traveling, and still haven't worked on my tailwheel problems. Your jacking solution is of great interest.
Regards,
Bill C.
Date: Thu, 3 Feb 2011 21:56:46 +0000
Subject: [fairchildclub] Strut packing & jacking the tail
Post by robert Etter »
'I will sit down at the computer this weekend, in between house work & football and draw it, the jack assembly, on the computer. I would scan it, then send it, but the computer that I have doesn't allow much flexibility. I tried to jack the tail, many many years ago, and it wasn't pretty. I ran the risk of damaging the bottom longerons.
--- In fairchildclub@yahoogroups.com, William Creighton wrote:
> Bob,
> Regards,
> Bill C.
> From: robertetter@...
> Bob
'I have the drawing done. What is you mailing address?
> Bob,
> Regards,
> Bill C.
> Bob
William Creighton
'Bob,
Bill Creighton
4703 Andover St
Sugar Land, TX 77479
or usma76@hotmail.com
Date: Sun, 6 Feb 2011 00:38:01 +0000
Subject: [fairchildclub] Re: Strut packing & jacking the tail
> Bob,
> Regards,
> Bill C.
> Bob
Seifert
Post by Seifert »
'Hi Robert
I need some help on my F24W46. I know you were doing a great job on yours from the pictures you sent me last summer. Do you have any templates or traceings of the upper and lower fairing bulkheads? The Fairchild drawing was superceded by shop templates on these bulkheads and mine were either missing or deteriated beyond use.
Rich Seifert
seifertr@verizon.net
9886 Onyx St.
Yucaipa, CA. 92399
OldOOwl@aol.com
Post by OldOOwl@aol.com »
'I am in the same boat with the fairings...however...they were rebuilt in an
unacceptable fashion...and I can use them as patterns for a do-over. When
I dis-assemble them I will make patterns.
The wood chosen looks like pine....the worksmanship (by a hired hand)
turned out to be very poor.
See attached pic.
Richard Hawley
NC19105
In a message dated 2/6/2011 9:59:59 A.M. Mountain Standard Time,
seifertr@verizon.net writes:
Hi Robert
Rich Seifert
_seifertr@verizon.net_ (mailto:seifertr@verizon.net)
9886 Onyx St.
Yucaipa, CA. 92399
'I'm sorry that I don't have my old ones. I guess that they were alot better than nothing. At the time I was seriously limited by available space. I was a little wiser when it came to the wings. I still have all 4 spars, and pieces and parts of 1 set of ribs. The spars show early signs of dry rot, but all in all, they are in really good shape.
775-482-9243(new phone)
--- In fairchildclub@yahoogroups.com, "Richard Seifert" wrote:
> Hi Robert
> Thanks
> Rich Seifert
> seifertr@...
> 9886 Onyx St.
> Yucaipa, CA. 92399
Jp Lorie
Post by Jp Lorie »
'Bob, do you still have the NOS Strut packing?
 JP.Lorie
Florida
Sent: Thu, February 3, 2011 4:56:46 PM
the attach point.
'The spring, that I thought was for the tail wheel, apparently isn't. The drawing looks like it said 7" plus, what I have is 6" plus.
Specs on mine: The diameter of the spring stock .15", 1" overall diameter, and 18.5 full wraps. Now, where did I get this darn thing?
> Bob,
> Bill Creighton
> 4703 Andover St
> or usma76@...
> Bob
> > Bob,
> > Regards,
> > Bill C.
> > From: robertetter@
> > Bob
