Re: Master Rod Bearings
Tom_Downey
Master Rod Bearings
Post by Tom_Downey »
'I have found a method of renewing the master rod Babbitt in any size up to .008" under. anyone interested?'
Tom_Downey
Master Rod Bearings
John Duncan
Post by John Duncan »
'Hello Tom,
I am interested in learning about your new procedure.
Regards, JD
Sent: Friday, December 31, 2010 12:34 PM
Subject: [fairchildclub] Master Rod Bearings
OldOOwl@aol.com
Post by OldOOwl@aol.com »
'me too!
In a message dated 12/31/2010 6:22:25 P.M. Mountain Standard Time,
johnaduncan@msn.com writes:
Hello Tom,
Regards, JD
Kevin Trumpore
Post by Kevin Trumpore »
'Tom, Please pass on the info, hopefully it will be easier / cleaner than the method we have been using. I get called upon to do a half dozen or so babbitt bearings a year. Never fun, never profitable, but it does keep an antique running.
Kevin
Date: Friday, December 31, 2010, 2:34 PM
Tom_Downey
'I trying to Get a feeling for the market, I have found a company that will regrind a crank and rebabbitt the old bearing shell, and fit the two parts at the proper clearance.
the number will reflect the price.
> Kevin
Fritz
Post by Fritz »
'Which engines are affected with Babbitt bearings??
On Behalf Of Tom_Downey
Sent: Friday, December 31, 2010 6:30 PM
Subject: [fairchildclub] Re: Master Rod Bearings
antique running.
> Kevin
Yahoo! Groups Links'
Tom_Downey
'I would like to collect a few old insert bearings for the warner and see what pricing on the lot will be. then place these renewed bearing on the shelf at Harlon Dickersons for any one who needs them.
Tom_Downey
Gene Haines
Post by Gene Haines »
'Are these bearings for the Warner? At first I thought the discussion was about Ranger engines.
Sent: Fri, Dec 31, 2010 9:24 pm
Subject: Re: [fairchildclub] Master Rod Bearings
Kevin
