TUBE BENDING
Frank
TUBE BENDING
Post by Frank »
'Folks - I am in a jam over here in UK - can't find any one that has suitable kit to bend a new control stick for a Ranger engined F24 as in drawing 47106 on the CD. I don't fancy the 'Fill it with sand' method.
If anyone knows a person/company that is able to bend a 4130 1 1/8" .049" wall thickness with two 4" centre line radius bends I would get A/C Spruce to ship a tube to them direct and then on to me after bending.
If it could be done in the next few days I have a friend returning to UK who could bring it with them.
Alternatively - does anyone have have a spare that they would sell (top part of stick is parallel to the bottom part, not sloping rearwards when installed)
Many thanks for any info
UC61K 43-15025 G-BCBL'
Craig
Re: TUBE BENDING
Post by Craig »
'Frank: Can you find some Cerrobend or the like and fill the tube and have it bent? Might be able to find it in the UK as Wood's metal. Same stuff that they use in gas cylinders and in sprinkler systems for melt-out plugs.
Craig C.
bty697859
Re: TUBE BENDING
Post by bty697859 »
'http://www.customcages.co.uk/roll-cages/tube-by-tube
Id have thought these guys would be able to help Frank as most are made of 4130?
Best regards
James
> Frank Cox
David Stroud
Re: TUBE BENDING
Post by David Stroud »
'For what it's worth, the " fill it with sand " technique is dead simple to do and if you want to
employ a " plumber's hickey" it makes it even easier and more accurate. Weld a cap on one
end, fill with fine sand, plug the other end, bend where needed and cut off the end pieces to the
dimension you need. If you can't find a hickey of sufficient width for the short radius you may need,
any custom fab shop doing race car tube bending will make short work of this simple task.
Christavia C-FDWS
Fairchild 51 replica
under construction C-FYXV
Sent: Tuesday, November 23, 2010 11:40 AM
Subject: [fairchildclub] TUBE BENDING
Checked by AVG - www.avg.com
Version: 8.5.449 / Virus Database: 271.1.1/3274 - Release Date: 11/23/10 07:34:00
Airy Millet
Re: TUBE BENDING
Post by Airy Millet »
'to make sand bending, I did use the sand usually used for birdcage! very fine, very compact!
Date: Tue, 23 Nov 2010 15:50:52 -0500
Subject: Re: [fairchildclub] TUBE BENDING
Christavia C-FDWS
burnmcc@aol.com
Re: TUBE BENDING
Post by burnmcc@aol.com »
'And packing it tightly.
Bill McClure
To: fairchildlist
Sent: Tue, Nov 23, 2010 4:05 pm
Subject: RE: [fairchildclub] TUBE BENDING
ery compact!
rom: dstroud@xplornet.com
nd if you want to
ap on one
nd pieces to the
adius you may need,
imple task.
hristavia C-FDWS
airchild 51 replica
rom: Frank
7:34:00
Individual Email | Traditional
Frank
TUBE BENDING
Post by Frank »
'Many thanks to all
The search is over - A ready made one has turned up in Europe.
I have certainly learned a lot about the 'Fill it with Sand' method - I must give it a go next time I need to bend a pipe.
What would we do without this site?
Frank'
