Hi Everyone
Does anyone with a Warner powered F-24 use the Air Maze attached in the pictures? If you can't open the attchment and you have the UC-61 Part Catalog AN01-115CA-4 look at page 62B Figure 58 I have a couple of these in N.O.S. condition minus the Filter. I also have a couple of the inlet tubes in Firgure 57 item 11 and Rubber connecting tubes items 24 & 10. If you can use them, please let me know.
Jim Chybicki
UC-61K 43-14964/HB-690
Re: WARNER AR MAZE
Re: WARNER AR MAZE
'G'day Jim,
Yes I would be very interested in obtaining the air maze housings from you as I do not have any on my aircraft. Inlet air on Argus Is was unfiltered which is not a good idea paticularly in a dusty climate such as we often get here. Please see the note I sent to Peter Chamberlain regarding contact details and if this is not suitable for you I can give you a number of a family friend in Sunderland who would pass on my email details to you.
John Gallagher
John Gallagher
'--- In fairchildclub@yahoogroups.com, james chybicki wrote:
> Â
> Hi Everyone
> Does anyone with a Warner powered F-24 use the Air Maze attached in the pictures? If you can't open the attchment and you have the UC-61 Part Catalog AN01-115CA-4 look at page 62B Figure 58 I have a couple of these in N.O.S. condition minus the Filter. I also have a couple of the inlet tubes in Firgure 57 item 11  and Rubber connecting tubes items 24 & 10. If you can use them, please let me know.Â
> Jim Chybicki
> Â
Re: WARNER AR MAZE
'John Gallagher,
Yahoo provides the security feature of "not showing eMail addresses". This is a desired feature, since having your eMail address exposed on the web, increases the likely-hood of getting lots of unsolicited eMail.
YOU may show YOUR eMail address by merely writing it without using the @ sign and the "." in the address. You could instead use: *AT* and *DOT* For example, MY eMail address is RangerRobertMN *AT* Yahoo *DOT* com.
Good Luck.
Webster, MN USA
Good Luck.
Webster, MN USA
'--- In fairchildclub@yahoogroups.com, "wackett129" wrote:
> G'day Jim,
> John Gallagher
> > Â
> > Hi Everyone
> > Jim Chybicki
> > Â
Re: WARNER AR MAZE
'Hello John
I have never sold one before, but a couple 24W drivers figure these are worth a few hundred dollars ($250.00 -300.00 US Dollars.) I would be more then willing to trade this even for a UC-61 Long Pitot Tube , Kollsman Type 765 that extends out of the left wing, about 1 foot from tip. It has a dog leg bend in it.
I also have a set of throttle and mixture rod assemblies for the UC-61A that are also NOS from a large purchase I made a few years ago of Fairchild /UC61A/K parts
I can send you pictures of the AirMaze, but not through the web site.
I tried your direct yahoo mail given below, but it won't go through
Thanks/Cheers
Thanks/Cheers
'--- On Mon, 8/30/10, wackett129 wrote:
Subject: [fairchildclub] Re: WARNER AR MAZE
Date: Monday, August 30, 2010, 5:14 PM
G'day Jim,
John Gallagher
> Â
> Hi Everyone
> Jim Chybicki
> Â
Re: WARNER AR MAZE
'G'day Jim,
Have been corresponding with Peter Chamberlain using the method suggested by Bob Waldron (thanks Bob)so try contacting me using antair at optusnet dot com dot au I will be at my hangar in the next few days and see what I can come up with.
Regards
John
Regards
John
> Hello John
> Â I have never sold one before, but a couple 24W drivers figure these are worth a few hundred dollars ($250.00 -300.00 US Dollars.)Â I would be more then willing to trade this even for a UC-61 Long Pitot Tube , Kollsman Type 765 that extends out of the left wing, about 1 foot from tip. It has a dog leg bend in it.
> IÂ can send you pictures of the AirMaze, but not through the web site.
> I tried your direct yahoo mail given below, but it won't go throughÂ
> Â
> Thanks/Cheers
> Jim
> From: wackett129
> Â
> G'day Jim,
> John Gallagher
> > Ã?Â
> > Hi Everyone
> > Does anyone with a Warner powered F-24 use the Air MazeÃ? attached in the pictures?Ã? If you can't open the attchmentÃ? and you have the UC-61 Part Catalog AN01-115CA-4 look at page 62B Figure 58Ã? I have a couple of these in N.O.S. condition minus the Filter. I also have a couple of the inlet tubes in Firgure 57 item 11 Ã? and Rubber connecting tubes items 24 & 10. If you can use them, please let me know.Ã?Â
> > Jim Chybicki
> > Ã?Â
