Re: Warner 145 Spark Plugs
mcclurebill@rocketmail.com
'Need info fast! Just installing a fresh engine from a well-known shop. The Warner 145 originally had the plugs that were contained within the Breeze (?) bell type shields with bails. The shop installed Skytronics harness and REM40E plugs. Great, modern. However, they don't fit very well. At all. Either front or back. In back, too close to exhaust manifold. In front there is actually interference with the ring cowl on the F-24G, barely 1/8" clearance. We tried some NOS C-26S plugs, and that helped a bit. Overhauler says this has never come up before, but geometry is what it is.
Can anyone out there shed light on this? What plugs are used on the 24G's with the 145? Been through it with this plane, just trying like heck to get it back in the air.Everything else coming together, but trying to make OSH.
Thanks in advance.
Bill McClure'
Thanks in advance.
Bill McClure'
OldOOwl@aol.com
'Just got home from the hangar....when I go back again I'll check the plugs
on my 145. 195 annual is done and test flew this afternoon...OSH here we
come!
Richard
In a message dated 7/14/2010 6:26:38 P.M. Mountain Daylight Time,
burnmcc@aol.com writes:
OSH.
Thanks in advance.
Bill McClure
come!
Richard
OSH.
Thanks in advance.
Bill McClure
burnmcc@aol.com
'Thanks Richard. I am desperately trying to get F-24 ready. Spent 9 days in MEM installing the engine. Nothing went smoothly. Last issue: Plugs.
I will call you tomorrow. I have another question, too.
Bill
Sent: Wed, Jul 14, 2010 8:59 pm
Subject: Re: [fairchildclub] Warner 145 Spark Plugs
come!
Richard
OSH.
Thanks in advance.
Bill McClure
Bill
come!
Richard
OSH.
Thanks in advance.
Bill McClure
Geoff Guest
'Bill;
We run two setups on two F24 C8Es with Warner 145s, one with original Breeze shielding utilizing 7mm unshielded wires and Champion C-26 plugs (plug top req. small amount removed for breeze cap to mate). The cap bails are close to the inside lip of the cowl lip but no interference. The second C8E runs shielded wires and BG 417S shielded plugs (length 2 3/4 in). The BG plugs may have an equivalent such as 3B2-S (length 2-1/2 in.). These are old plugs but you or someone may have access. Hopefully this is helpful. Good luck.
Geoff Guest
Geoff Guest
Sent: Wednesday, July 14, 2010 5:22 PM
Subject: [fairchildclub] Warner 145 Spark Plugs
Thanks in advance.
Bill McClure
Checked by AVG - www.avg.com
Version: 9.0.830 / Virus Database: 271.1.1/3005 - Release Date: 07/14/10 11:36:00
Gene Haines
'Not sure what you need. If it is the BG plugs with the brass ball on the end, I have some NOS. I will get the exect number if that is what your looking for. Unshielded.
Gene Haines
Sent: Wed, Jul 14, 2010 11:31 pm
Bill;
Geoff Guest
Gene Haines
Bill;
Geoff Guest
Thanks in advance.
Bill McClure
'That's just the info I needed! Many thanks to those who replied. Now.... anyone have an idea where I could find the BG 417S or 3B2S plugs??
Wonderful to have this forum.....
Bill McClure
Bill McClure
'--- In fairchildclub@yahoogroups.com, "Geoff Guest" wrote:
> Bill;
> Geoff Guest
> From: mcclurebill@...
> Thanks in advance.
> Bill McClure
David Stroud
'Bill, there's a lad called the Plug Guy. http://www.plugguy.com/
Might be worth a chance....he's quite knowledgeable.
David Stroud Ottawa, Canada
Christavia C-FDWS
Fairchild 51 replica
under construction C-FYXV
Christavia C-FDWS
Sent: Thursday, July 15, 2010 9:41 AM
Subject: [fairchildclub] Re: Warner 145 Spark Plugs
Bill McClure
> Bill;
> Geoff Guest
> Thanks in advance.
> Bill McClure
Version: 8.5.441 / Virus Database: 271.1.1/3007 - Release Date: 07/15/10 11:09:00
'The lengths you mention.....is that length over all or from the top of the threaded portion (gasket area) to top of the plug?
Thanks.
Bill McC
Thanks.
Bill McC
> Bill;
> Geoff Guest
> Thanks in advance.
> Bill McClure
Tom_Downey
'Bill,
I have 2 sets of plugs for your aircraft, one set is BG-706-S and the other set is C-26-S both measure 2.5 inches from the gasket to the top of the plug. they both have about 50 hours on them. and ran fine in my 165.
call me, AREA Code 360-202-0961, I'll be on cell all day.
> Thanks.
> Bill McC
Gene Haines
'We have some NOS B.G. SU-485 Spark Plugs available for sale. We have no idea if these spark plugs are the correct plugs for the Warner.
Gene Haines
Sent: Thu, Jul 15, 2010 3:18 pm
Thanks.
Bill McC
Gene Haines
Thanks.
Bill McC
> Bill;
> Geoff Guest
> Thanks in advance.
> Bill McClure
