Brakes
PT-26 roundels
'It's time to get some roundels painted on the wings of my PT-26, but I'm not sure of their proper locations. Are they on the top of one wing, and the bottom of the other, or top and bottom of both wings?
Seems like they were placed about 1/3 of the way in from the wing tip to the wing/center section attachments.
Any description that can be provided will be appreciated.
Charles Mueller'
Charles Mueller'
Re: PT-26 roundels
'Would some pics of my friends PT- help? I can send them to your e-mail address.
Sent: Thursday, June 24, 2010 6:53 PM
Subject: [fairchildclub] PT-26 roundels
Charles Mueller
Re: PT-26 roundels
'I was meaning the pics I had downloaded of the Denest's PT-26. I'll have to dig....
Charles Mueller
PT-26 roundels
'Here's some shots of their plane.... The Denests can give you some exact dimensions and placing.... Mike posts here a lot.
http://www.warbirdalley.com/articles/pt26-fa.htm
Charles Mueller
Re: PT-26 roundels
'Charles: There is actually a set of measurements for placement of US markings. I'm not sure which manual that they are in. The placement info also gives you the formulas to come up with the correct sizing for diameters, star placement, ect. If someone else doesn't chime in with the info, I can swing by a fiend's place and look it up.
Craig C.
Craig C.
Re: PT-26 roundels
'Charles:
I'm sending you what I have on the PT-26 markings. There is a drawing # 19105 that is on the PT drawing disc that Gene Haines has. If you have the micro film, I think it's on that also. There were several variations of the roundels durring the coarse of the War. I will mail the stuff I have today. I have your address as 1340 W. Sacamento Av. Chico, CA. 95926. You might try Tom Dietrich at the Tiger Boys up in Guleph ONT,e-mail tom_bob_tigerboys@hotmail.com or cell 519-584-4960 Keep 'Em Flying!
Mike Kelly Fairchild Club
Date: Thu, 24 Jun 2010 23:53:56 +0000
Charles Mueller
Hotmail is redefining busy with tools for the New Busy. Get more from your inbox.
http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_2
Charles Mueller
Re: PT-26 roundels
'Thank you all responding to my roundel question. I'll wait for the drawings from Mike before figuring out which way to go.
Charles'
Charles'
Re: PT-26 roundels
'Hi Charles, sounds like you're making good progress on your PT. Do you have
any leftover parts? I'm looking for a lower engine cowl.
> Charles
ptcurt@gmail.com
Re: PT-26 roundels
'Hi Curt,
Progress is normal - 3 steps forward, 2 (or more) back. However there does seem to be light at the end of the tunnel, and it's not a trains' headlamp!
I don't have any cowl pieces left over though. Did spot a nose bowl in a neighbor's hangar the other day though, in case anyone can use one. Looked to be in decent condition.
Charles Mueller
Charles Mueller
> Thanks
> Curt Kinchen
> > Charles
> Curt Kinchen
> ptcurt@...
Re: PT-26 roundels
'Hi all, I am doing some research, and its easier to ask first and get direction(s),
on the pt-19's and pt-26's what is the replacement for the original brakes???????????????
I had an SR-5 i changed out to UC-78's and never had a problem.
