Re: Tailwheel Question
mcclurebill@rocketmail.com
Tailwheel Question
Post by mcclurebill@rocketmail.com »
'I see Fairchild 24 tailwheel issues have been a high interest topic in the past. I'm wondering if there is a mod to add a locking pin that would make it stay oriented straight ahead for takeoff and landing? It seems that would be a way to stop the shimmy problems.
Thanks.'
Airy Millet
Post by Airy Millet »
'On UC-61K, there is already a locking pin, but the problem is that it wear year after years, then you will have to rebuilt.
The unlocking of those tailwheel happen when full rudder is applied left or right!
That's why, when you are landing under high cross wind, you may unlock at the same time as correcting the wind!!
It is the locking pin, which make the wheel stearable..unless you apply full rudder, or brake heavily at one side when turning!
As much as possible most of the time we try not to use brakes at all, as they are heating quite rapidly, and loosing efficiency!
Airy
Date: Sat, 13 Mar 2010 22:52:46 +0000
Subject: [fairchildclub] Tailwheel Question
Thanks.
Hotmail et MSN dans la poche? HOTMAIL et MSN sont dispo gratuitement sur votre t?l?phone!
http://www.messengersurvotremobile.com/?d=Hotmail
burnmcc@aol.com
Post by burnmcc@aol.com »
'Thanks. I'd like to modify to lock from the cockpit, until you unlock it, by a cable or the like. Other antiques I've owned were set up that way.
Good to know there might be something out there I can adapt, tho.
Thanks again.
Bill McC
To: fairchildlist
Sent: Sun, Mar 14, 2010 5:10 pm
Subject: RE: [fairchildclub] Tailwheel Question
ight!
Airy
rom: burnmcc@aol.com
hanks.
éléphone!
Individual Email | Traditional
Airy Millet
'it may be possible, at first modifying the "unlocking cam plate" to lock the steering anytime...and then adapt something to unlock from the cockpit, like a "warbird" !!
:o))
but the shimmy, is not really due to the tailwheel itself, but due to geometry!
old tailwheel have shortened springs (coil springs shorten under fatigue along years)...and the front arm, may be redesigne a little bit shorter should be better!
but such mods are useless if there are to much play in the tailwheel assy (especially on the pivot parts, which can be badly worn).
and the "unlocking" angle can be adjust by loosing or thightening the c?ble linked to rudder.
Airy
Date: Sun, 14 Mar 2010 19:19:18 -0400
Subject: Re: [fairchildclub] Tailwheel Question
Thanks again.
Bill McC
To: fairchildlist
ight!
Airy
hanks.
?l?phone!
Hotmail arrive sur votre t?l?phone ! Compatible Iphone, Windows Phone, Blackberry, ?
David Stroud
Post by David Stroud »
'That's way I'm setting up my 51. Locked in all conditions and unlocked by cable/lever
in the cockpit for ground handling.
David Stroud Ottawa, Canada
Christavia C-FDWS
Fairchild 51 replica
under construction C-FYXV
Sent: Sunday, March 14, 2010 7:19 PM
Thanks again.
Bill McC
To: fairchildlist
ight!
Airy
hanks.
éléphone!
Checked by AVG - www.avg.com
Version: 8.5.436 / Virus Database: 271.1.1/2746 - Release Date: 03/14/10 07:33:00
AlanM
Post by AlanM »
'My 24W41 has a adjustable brackets to adjust the strut rake angle for the pn 4390 Link tail wheel guide, This has been used for a long time on this airplane and has no shake at all. I am replacing the old fabricaded bracket with a billet 4140,Hardened and cad plated I should have it done soon and will get a 337 on it or a STC if there in enough interest.the old brackets were welded solid to the tail rear section cross tube. Also working on a tail wheel lock set up.Also almost ready to cover my airframe ,Alan
> Thanks.
Airy Millet
'do you have any technical drawing or schemes about your adjustable bracket..I'll be very interested!
Airy
Date: Mon, 15 Mar 2010 14:50:55 +0000
Subject: [fairchildclub] Re: Tailwheel Question
> Thanks.
