Re: Cabin heat box needed
jwm1801
Airbox wanted-needed
Post by jwm1801 »
'I am in need of a airbox for my 1946 Fairchild 24R project. The one I have is not in good condition. Please let me know if you have one I could buy. Thank you,
JON MARTIN 610-476-1702, obliquephoto@comcast.net'
mileslong2k
Re: Airbox wanted-needed
Post by mileslong2k »
'Hi Jonathan,
To clarify, is that the air filter airbox or the carburetor airbox that you are in need of?
Jim Long'
Post by obliquephoto@comcast.net »
'The air box that holds the filter which is attached to the nose bowl and the air straighter elbow on the carb. Jon
Sent from my Verizon Wireless BlackBerry
Date: Wed, 17 Feb 2010 20:37:50
Subject: [fairchildclub] Re: Airbox wanted-needed
Hi Jonathan,
Jim Long
ausian24
Post by ausian24 »
'Jon,
I was looking for my 24R model K. Scott Bracket at Bracket Aero Filters email baf@citilink.net was very helpful they make a filter box and replacement filters and very reasonably priced.You can also google Bracket Air filters. A few weeks back he was about to do a run of F24 housings. Hope that helps.
Ian Kearsley
> From: "mileslong2k"
> Hi Jonathan,
> Jim Long
David Stroud
Post by David Stroud »
'Does anyone have a largish cabin heat box sitting under the bench they
would sell ? I'm looking for a large one, say 3" in diameter. Thanks.
Christavia C-FDWS
Fairchild 51 replica
under construction C-FYXV
harry hayman
Post by harry hayman »
'David I have what appears to be a heat box as you described..
4" dia 0pening .with flapper opening approx. 3 1/2 by 3 1/2..Suggest you call me .to verify this is what you need.The photo portion of my system is inop..The unit could be put in service with cleaning.also see if you can come up with a price.A good time to catch me is around
8:PM
Harry
 Harry Hayman
Phone 904-284-4276
Fax 904-284-3869
Sent: Fri, February 26, 2010 7:26:04 AM
Subject: [fairchildclub] Cabin heat box needed
Christavia C-FDWS
james chybicki
Post by james chybicki »
'Hi David
Not sure this will work for you, but I have  couple of these UC-61A intake boxes I acquired a few years ago with a truck load of UC-61A & K parts. please see the attached "pdf" picture from the UC-61 Parts Catalog.  It's complete minus the filter insert
thanks!
Jim Chybicki
UC-61K 43-19464/H690
847-530-4377
RampRatOne@yahoo.com
Date: Friday, February 26, 2010, 6:26 AM
Christavia C-FDWS
mileslong2k
'I sent an email to Scott at Brackett Aero Filters regarding them making new Fairchild 24 air filter housings. This is his reply.
Hello Jim,
With the Fairchild you have two choices, P/N BA-3610 is most common. Early model 24's utilized a thinner filter, our P/N BA-216. The BA-3610 is 2" thick, were as the BA-216 is 3/4" thick. Cost are $72.75 for the BA-3610 or $81.50 for BA-216. Lead time currently is 4 weeks, parts are in process.
Sincerely,
Scott Brackett
Phone: 001-928-757-4009
Fax: 001-928-757-4433
e-mail: baf@citlink.net'
David Stroud
'I didn't see a pdf attached Jim. If you can resend pls. do. Can you indicate the diameter
of the intake tube? Thanks.
Christavia C-FDWS
Sent: Friday, February 26, 2010 3:45 PM
Subject: Re: [fairchildclub] Cabin heat box needed
Hi David
thanks!
Jim Chybicki
847-530-4377
Christavia C-FDWS
Checked by AVG - www.avg.com
Version: 8.5.435 / Virus Database: 271.1.1/2709 - Release Date: 02/25/10 07:34:00
