'Wondering if there are opinions about props, diameters and pitch, for Warners, specifically the 145. What static/takeoff rpms should be seen. How about Aeromatics.....any out there? What has been the experience with those?
Thanks.
Bill McC'
Re: Warner Props
Hugh Loewenhardt
Re: Warner Props
'--- On Tue, 12/1/09, mcclurebill@rocketmail.com wrote:
'> From: mcclurebill@rocketmail.com
> Subject: [fairchildclub] Warner Props
> Date: Tuesday, December 1, 2009, 12:10 AM
> Bill, Most,if not,all the infomation you seek regarding prop selection and RPM data for specific applications is available from the various propeller manufacture's technical literature as well as aircraft type certificates. Model specifications for wooden Sensenich propellers for various Warner 145 engine/aircraft combinations are on their web site or I can send you a copy. I have a Warner 145 series 40 engine and I know that prop selection depends on various factors such as the propeller hub (taper vs spline) and the aircraft, definitely not opinions. Contact me if you want a copy of the Sensenich document. Hugh (860)535-1699
> Thanks.
> Bill McC
Re: Warner Props
'Thanks for that. I suppose I should have said which props amongst the approved options are working out the best for the members. Kind of a black art, I think, since there a few manufacturers and the criteria are not necessarily the same amongst them. I will look at the Sensenich list online. I am working with a 145 50A, splined shaft. I think I'd like to find a suitable Aeromatic if available.
Bill McC
Bill McC
'--- In fairchildclub@yahoogroups.com, Hugh Loewenhardt wrote:
> --- On Tue, 12/1/09, mcclurebill@... wrote:
> > From: mcclurebill@...
> > Â
> > Thanks.
> > Bill McC
jhed9253@aol.com
Re: Warner Props
'Check with Kent at: info@aeromatic.com
He is the man.
Sent: Tue, Dec 1, 2009 2:07 pm
Subject: [fairchildclub] Re: Warner Props
Bill McC
He is the man.
Bill McC
> > Â
> > Thanks.
> > Bill McC
Re: Warner Props
'--- In fairchildclub@yahoogroups.com, "mcclurebill@..." wrote:
as reguards your question about who to overhaul a warner 145 :
Please contact Mr. Charley Bell ( F-22 )
He has a frend who can do them I believe !
Tim B.
Bill :>
> Bill McC
> --- In fairchildclub@yahoogroups.com, Hugh Loewenhardt > --- On Tue, 12/1/09, mcclurebill@ wrote:
> > > From: mcclurebill@
> > > Â
> > > Thanks.
> > > Bill Mc
Tim B.
