'Where is the best place to mount an air oil seperator on a PT-19 . Should the return be in tha tank vent?
Michael'
Re: air oil separator
Re: air oil seperator
'On a F-24 I tried to have one on the firewall on the top, in order to make the original engine vent pasing through the separator, thus having the return line from the separator higher level than the oil tank, and being able to drill a return hole on top of the oil tank (tiny diameter regarding the vent tube diameter not to pressurize the oil tank with engine crankcase pressure and vapours.
Airy
Date: Thu, 11 Jun 2009 18:32:16 +0000
Subject: [fairchildclub] air oil seperator
Michael
Téléphonez gratuitement à tous vos proches avec Windows Live Messenger ! Téléchargez-le maintenant !
http://www.windowslive.fr/messenger/1.asp
Airy
Michael
'Better to let the drain from oil separator into a non
pressurized crankcase area, such as the cam box Bob Haas
_____
On Behalf Of Airy Millet
Sent: Thursday, June 11, 2009 2:42 PM
To: fairchildlist
Subject: RE: [fairchildclub] air oil seperator
Airy
Michael
http://www.windowsl
Checked by AVG - www.avg.com
Version: 8.5.339 / Virus Database: 270.12.63/2169 - Release Date: 06/11/09
05:53:00
_____
To: fairchildlist
Airy
Michael
http://www.windowsl
05:53:00
'sorry, but the camshaftcase is pressurized by the big oil link tube, and by the gear link too...
that's also wy such engine do have oil consumption through valve guides, as oily vapors are going this way under pressure too...
so, the only way to drain the oil from separator is in an atmosphere pressure bottle, or so...
Airy
Date: Thu, 11 Jun 2009 19:43:36 -0400
Subject: RE: [fairchildclub] air oil separator
_____
To: fairchildlist
Airy
Michael
http://www.windowsl
05:53:00
Inédit ! Des Emoticônes Déjantées! Installez les dans votre Messenger !
http://www.ilovemessenger.fr/Emoticones/EmoticonesDejantees.aspx
Airy
_____
To: fairchildlist
Airy
Michael
http://www.windowsl
05:53:00
