'Folks,
I'm having a problem with sourcing the small brass compression fittings
on the ends of the aluminium fuel lines (2 in and 1 out)where they
enter and exit the fuel on/off valves in my UC61K rebuild project. I
cannot rescue the old ones as they have been compressed around the
corroded alloy pipes to such an extent that the internal diameter of
the pipe is reduced. Even if I did get them off they would not fit over
the new pipe.
I'd be interested to know of any method anyone might have used to
overcome the problem; possibly with a suitable combination of adaptor
fittings or knowledge of a secret supplier/manufacturer of these
compression fittings!
With many thanks and Compliments of the season to everyone.
(UC61K G-BCBL)'
Re: Fuel Pipes to fuel selector valve compression fittings
'You might try it. I took 12 double flair compression rings (air conditioner stuff), and carefully cut one of the flairs off. It gave me a single flair on one side and a squared off shoulder on the other side. I used a lathe and put the compression ring in the jaws of the head stock, but backed it up with a hardened rod, so I wouldn't distort the ring. Out of the 12 rings, I got the 8 really good ones that I wanted.
Sent: Wednesday, December 03, 2008 9:19 AM
Subject: [fairchildclub] Fuel Pipes to fuel selector valve compression fittings
Folks,
the new pipe.
(UC61K G-BCBL)
'Frank,
We may have some new (old) fuel shut off valves still in cloth bags complete with original compression fittings. Would you be interested?
Bob Coon
Jim Chybicki
UC61-K
HB-690
Bob Coon
Jim Chybicki
UC61-K
HB-690
'--- On Wed, 12/3/08, Bob Etter wrote:
Subject: Re: [fairchildclub] Fuel Pipes to fuel selector valve compression fittings
Date: Wednesday, December 3, 2008, 8:56 PM
Folks,
the new pipe.
fittings or knowledge of a secret supplier/manufactur er of these
(UC61K G-BCBL)
'Bob 'C'
- Thank you for the offer but my fuel cocks are both in good shape - I think it would be overkill to replace them for the sake of the compression fittings - however if I am totally stuck may I come back to you?
Bob 'E'
- Sounds like an excellent 'way ahead' - I'll attempt to find such fittings - could be difficult over here as we have gone metric! - I'll work on it.
Thanks to both for such rapid response
Bob 'E'
Sent: Thursday, December 04, 2008 4:01 AM
Frank,
Bob Coon
Jim Chybicki
UC61-K
HB-690
Folks,
the new pipe.
(UC61K G-BCBL)
'Frank,
Not a problem. Good luck. Anything else we can help you with let us know.
Seasons Greetings.
Bob Coon
Jim Chybicki
HB-690
UC-61K
Keep em flyin
Seasons Greetings.
Bob Coon
Jim Chybicki
HB-690
UC-61K
Keep em flyin
Date: Thursday, December 4, 2008, 3:37 AM
Bob 'C'
Bob 'E'
Frank,
Bob Coon
Jim Chybicki
UC61-K
HB-690
Folks,
the new pipe.
(UC61K G-BCBL)
