Re: POH
jameslbryan@btopenworld.com
POH
'Dear group
I need a Pilot operating handbook for my f24r-46a
Can any one help ?
James Bryan'
Can any one help ?
James Bryan'
Woodward Tom
POH
'I have been asked to check someone out in a Fairchild 24. His insurance wanted someone with Fairchild experience. I used to own a PT19 and I guess that was good enough for the insurance company but I’ve never flown the 24 (Ranger engine).
Does anyone have a scanned POH that I could take a look at before I go fly or are there any recommendations what NOT to do? I understand the fuel system is two valves and both should not be opened at the same time or closed for that matter?
Any other tips or hints?
Tom Woodward
Granbury, Texas'
Tom Woodward
Granbury, Texas'
Re: POH
'Tom,
See attached POH.
JST
Tom Woodward
Granbury, Texas
See attached POH.
JST
Tom Woodward
Granbury, Texas
Dennis Strong
Re: POH
' What year 24 is it?, I own a 1937 24H short nose small vertical Stabilizer. Won't three point, wants to ground loop, wheel landings work well more control.
Sent via the Samsung Galaxy S7, an AT&T 4G LTE smartphone
-------- Original message -------- From: "Woodward Tom buhwana@charter.net [fairchildclub]" Date: 3/20/17 9:40 PM (GMT-08:00) To: fairchildclub@yahoogroups.com Subject: [fairchildclub] POH
Tom Woodward
Granbury, Texas '
Tom Woodward
Granbury, Texas '
Emil Dular
Re: POH
I second that! The little tail on the 1936 24-C8F based here makes three point landings on anything but grass and ideal conditions an adventure. Especially if you forgot to lock the tailwheel.
On 21-Mar-17 10:46, Dennis Strong DStrong@kodiakroofing.com [fairchildclub] wrote:
-------- Original message -------- From: "Woodward Tom buhwana@charter.net [fairchildclub]" fairchildclub@yahoogroups.com Date: 3/20/17 9:40 PM (GMT-08:00) To: fairchildclub@yahoogroups.com Subject: [fairchildclub] POH
Tom Woodward
Granbury, Texas
patteenews
Re: POH
'1946 F24R, N81361She likes grass. Feed her asphalt and she can get a little cross and grab a bit. Rarely three point her, but do and with her longer nose she behaves. Most landings are tail low wheel landings. Extra speed means harder work bleeding it off. Many fly final at 70, I fly at 60 with full flaps. Nice short field takeoff performance. Note the passenger restriction (CG) with full (60 gal) fuel. L magneto had the impulse coupling for the start.
Tom Woodward
Granbury, Texas '
On Mar 20, 2017, at 22:57, Woodward Tom buhwana@charter.net [fairchildclub] wrote:
Tom Woodward
Granbury, Texas '
Richard Ellingworth
Re: POH
Don't be in a huge rush to push the stick forward on the initial roll as it takes some serious pushing if you go too early, wait for a little speed to build and she pushes forward lovely. Be careful with the trim when you first take off, I'd suggest a neutral setting. If you get it wrong it takes some hauling off the deck and a quick turn on the handle on early lift which can be a bit frantic. Approach at 70 first stage of flap with short final 65 to 60 full flap, 55 to 50 over the numbers and fly her down the runway, let it gently bleed off until the wheels rumble on the ground and hold that position. Keep a decent speed on the long approach, don't be tempted to drag it in with a nose high attitude.
I didn't have hundreds of tailwheel hours and found my first flight in the Fairchild a joy. Grass is obviously easy and more forgiving if your not all that straight but tarmac is fine although you will have to be prepared to peddle that bit harder on touchdown! The aircraft can handle superb crosswinds and very stable in flight even if its pretty turbulent.
Make sure your brakes are working sufficiently as in crosswinds you will need some opposite braking, my brakes were binding on one side on a recent flight which made it a bit of a challenge.
Hope this helps and have a brilliant first flight!!
All the best
Richard
UK
From: fairchildclub@yahoogroups.com on behalf of patteenews patteenews@gmail.com [fairchildclub]
Sent: 21 March 2017 20:22
Subject: Re: [fairchildclub] POH
1946 F24R, N81361 She likes grass. Feed her asphalt and she can get a little cross and grab a bit. Rarely three point her, but do and with her longer nose she behaves. Most landings are tail low wheel landings. Extra speed means harder work bleeding it off. Many fly final at 70, I fly at 60 with full flaps. Nice short field takeoff performance. Note the passenger restriction (CG) with full (60 gal) fuel. L magneto had the impulse coupling for the start.
Tom Woodward
Granbury, Texas
All the best
Richard
UK
Tom Woodward
Granbury, Texas
Re: POH
' Yes, don’t drag it in. I turn final at 80 mph indicated and let speed bleed down to touchdown. Wheel it on and keep the tailwheel up as long as you can – that makes it a lot easier to avoid tailwheel chatter, which eventually produces a tailwheel which chatters more, until it needs repairs. There’s a lot of weight on the tailwheel – my original Wt & Bal from the factory in July 1940 shows 155 pounds empty! Keep the tailwheel inflated to 45 psi – nice and hard – that helps a lot. I find it an easy-to-land tailwheel airplane on any surface. Lots of landing gear travel gives soft arrivals. Gear is wide and the airplane doesn’t do anything quick on the ground. In the air, my 24 (F-24W41A – same as the W46A, except pre-war) is marvelously smooth and responsive to the controls alongside modern spam-cans – lots of stick motion, but control feel is quite harmonius – very powerful rudder, by the way. Visibility is pretty good for an old round-engined aeroplane. You’ll be shocked at first by the feeling you are a long way from the panel, but you sit up pretty high. I’m sure it’s a bit harder to see forward at 3-point with the Ranger engine vs. the Warner, but maybe a bit easier to see around the side at 3-point – no visibility trouble with either engine when level, just the fuselage V-bracing, windshield joints and the landing gear and struts, so get the tail up as soon as you can on take-off. My 24 has the Warner 165 with the Sensenich wood prop, and it is not a sprightly climber. I bet you fellows with the 200 horse Ranger do lots better. I’d like to have about a hundred more horsepower. Have fun, and make sure to roll down your window and hang your elbow out in the breeze (after you’ve stowed all the paper and maps in the cockpit)! That should be part of every checkout in the 24. Tony Lowe F-24W41A, S/N 136, N28522 From: Richard Ellingworth richardecho@hotmail.com [fairchildclub] Sent: Tuesday, March 21, 2017 3:44 PM To: fairchildclub@yahoogroups.com Subject: Re: [fairchildclub] POH
All the best
Richard
UK
Subject: Re: [fairchildclub] POH 1946 F24R, N81361 She likes grass. Feed her asphalt and she can get a little cross and grab a bit. Rarely three point her, but do and with her longer nose she behaves. Most landings are tail low wheel landings. Extra speed means harder work bleeding it off. Many fly final at 70, I fly at 60 with full flaps. Nice short field takeoff performance. Note the passenger restriction (CG) with full (60 gal) fuel. L magneto had the impulse coupling for the start.
All the best
Richard
UK
Tom Woodward
Granbury, Texas
Jim higham
Re: POH
'I have the UC61K (same as a F24R46A ) Flight manual but it is too old to email Jim
On Tuesday, March 21, 2017 4:30 PM, "lowea1@comcast.net [fairchildclub]" wrote:
Yes, don’t drag it in. I turn final at 80 mph indicated and let speed bleed down to touchdown. Wheel it on and keep the tailwheel up as long as you can – that makes it a lot easier to avoid tailwheel chatter, which eventually produces a tailwheel which chatters more, until it needs repairs. There’s a lot of weight on the tailwheel – my original Wt & Bal from the factory in July 1940 shows 155 pounds empty! Keep the tailwheel inflated to 45 psi – nice and hard – that helps a lot. I find it an easy-to-land tailwheel airplane on any surface. Lots of landing gear travel gives soft arrivals. Gear is wide and the airplane doesn’t do anything quick on the ground. In the air, my 24 (F-24W41A – same as the W46A, except pre-war) is marvelously smooth and responsive to the controls alongside modern spam-cans – lots of stick motion, but control feel is quite harmonius – very powerful rudder, by the way. Visibility is pretty good for an old round-engined aeroplane. You’ll be shocked at first by the feeling you are a long way from the panel, but you sit up pretty high. I’m sure it’s a bit harder to see forward at 3-point with the Ranger engine vs. the Warner, but maybe a bit easier to see around the side at 3-point – no visibility trouble with either engine when level, just the fuselage V-bracing, windshield joints and the landing gear and struts, so get the tail up as soon as you can on take-off. My 24 has the Warner 165 with the Sensenich wood prop, and it is not a sprightly climber. I bet you fellows with the 200 horse Ranger do lots better. I’d like to have about a hundred more horsepower. Have fun, and make sure to roll down your window and hang your elbow out in the breeze (after you’ve stowed all the paper and maps in the cockpit)! That should be part of every checkout in the 24. Tony Lowe F-24W41A, S/N 136, N28522 From: Richard Ellingworth richardecho@hotmail.com [fairchildclub] Sent: Tuesday, March 21, 2017 3:44 PM To: fairchildclub@yahoogroups.com Subject: Re: [fairchildclub] POH Don't be in a huge rush to push the stick forward on the initial roll as it takes some serious pushing if you go too early, wait for a little speed to build and she pushes forward lovely. Be careful with the trim when you first take off, I'd suggest a neutral setting. If you get it wrong it takes some hauling off the deck and a quick turn on the handle on early lift which can be a bit frantic. Approach at 70 first stage of flap with short final 65 to 60 full flap, 55 to 50 over the numbers and fly her down the runway, let it gently bleed off until the wheels rumble on the ground and hold that position. Keep a decent speed on the long approach, don't be tempted to drag it in with a nose high attitude. I didn't have hundreds of tailwheel hours and found my first flight in the Fairchild a joy. Grass is obviously easy and more forgiving if your not all that straight but tarmac is fine although you will have to be prepared to peddle that bit harder on touchdown! The aircraft can handle superb crosswinds and very stable in flight even if its pretty turbulent. Make sure your brakes are working sufficiently as in crosswinds you will need some opposite braking, my brakes were binding on one side on a recent flight which made it a bit of a challenge. Hope this helps and have a brilliant first flight!! All the best Richard UK
#ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706 -- #ygrps-yiv-1164039916yiv0339943706ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-mkp #ygrps-yiv-1164039916yiv0339943706hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-mkp #ygrps-yiv-1164039916yiv0339943706ads { margin-bottom:10px;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-mkp .ygrps-yiv-1164039916yiv0339943706ad { padding:0 0;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-mkp .ygrps-yiv-1164039916yiv0339943706ad p { margin:0;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-mkp .ygrps-yiv-1164039916yiv0339943706ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-sponsor #ygrps-yiv-1164039916yiv0339943706ygrp-lc { font-family:Arial;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-sponsor #ygrps-yiv-1164039916yiv0339943706ygrp-lc #ygrps-yiv-1164039916yiv0339943706hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-sponsor #ygrps-yiv-1164039916yiv0339943706ygrp-lc .ygrps-yiv-1164039916yiv0339943706ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706activity span { font-weight:700;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706activity span span { color:#ff7900;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706activity span .ygrps-yiv-1164039916yiv0339943706underline { text-decoration:underline;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 .ygrps-yiv-1164039916yiv0339943706attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 .ygrps-yiv-1164039916yiv0339943706attach div a { text-decoration:none;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 .ygrps-yiv-1164039916yiv0339943706attach img { border:none;padding-right:5px;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 .ygrps-yiv-1164039916yiv0339943706attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 .ygrps-yiv-1164039916yiv0339943706attach label a { text-decoration:none;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 .ygrps-yiv-1164039916yiv0339943706bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 .ygrps-yiv-1164039916yiv0339943706bold a { text-decoration:none;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 dd.ygrps-yiv-1164039916yiv0339943706last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 dd.ygrps-yiv-1164039916yiv0339943706last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 dd.ygrps-yiv-1164039916yiv0339943706last p span.ygrps-yiv-1164039916yiv0339943706yshortcuts { margin-right:0;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 div.ygrps-yiv-1164039916yiv0339943706attach-table div div a { text-decoration:none;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 div.ygrps-yiv-1164039916yiv0339943706attach-table { width:400px;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 div.ygrps-yiv-1164039916yiv0339943706file-title a, #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 div.ygrps-yiv-1164039916yiv0339943706file-title a:active, #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 div.ygrps-yiv-1164039916yiv0339943706file-title a:hover, #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 div.ygrps-yiv-1164039916yiv0339943706file-title a:visited { text-decoration:none;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 div.ygrps-yiv-1164039916yiv0339943706photo-title a, #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 div.ygrps-yiv-1164039916yiv0339943706photo-title a:active, #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 div.ygrps-yiv-1164039916yiv0339943706photo-title a:hover, #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 div.ygrps-yiv-1164039916yiv0339943706photo-title a:visited { text-decoration:none;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 div#ygrps-yiv-1164039916yiv0339943706ygrp-mlmsg #ygrps-yiv-1164039916yiv0339943706ygrp-msg p a span.ygrps-yiv-1164039916yiv0339943706yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 .ygrps-yiv-1164039916yiv0339943706green { color:#628c2a;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 .ygrps-yiv-1164039916yiv0339943706MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 o { font-size:0;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706photos div { float:left;width:72px;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706reco-category { font-size:77%;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706reco-desc { font-size:77%;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 .ygrps-yiv-1164039916yiv0339943706replbq { margin:4px;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-mlmsg select, #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 input, #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-mlmsg pre, #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 code { font:115% monospace;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-mlmsg #ygrps-yiv-1164039916yiv0339943706logo { padding-bottom:10px;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-msg p#ygrps-yiv-1164039916yiv0339943706attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-reco #ygrps-yiv-1164039916yiv0339943706reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-sponsor #ygrps-yiv-1164039916yiv0339943706ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-sponsor #ygrps-yiv-1164039916yiv0339943706ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-sponsor #ygrps-yiv-1164039916yiv0339943706ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-text { font-family:Georgia;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-text tt { font-size:120%;} #ygrps-yiv-1164039916 #ygrps-yiv-1164039916yiv0339943706 #ygrps-yiv-1164039916yiv0339943706ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1164039916I have been asked to check someone out in a Fairchild 24. His insurance wanted someone with Fairchild experience. I used to own a PT19 and I guess that was good enough for the insurance company but I’ve never flown the 24 (Ranger engine).
Tom Woodward
Granbury, Texas
Jim higham
Re: POH
'On Thursday, March 23, 2017 3:48 PM, "Jim Higham higham_jim@yahoo.com [fairchildclub]" wrote:
Yes, don’t drag it in. I turn final at 80 mph indicated and let speed bleed down to touchdown. Wheel it on and keep the tailwheel up as long as you can – that makes it a lot easier to avoid tailwheel chatter, which eventually produces a tailwheel which chatters more, until it needs repairs. There’s a lot of weight on the tailwheel – my original Wt & Bal from the factory in July 1940 shows 155 pounds empty! Keep the tailwheel inflated to 45 psi – nice and hard – that helps a lot. I find it an easy-to-land tailwheel airplane on any surface. Lots of landing gear travel gives soft arrivals. Gear is wide and the airplane doesn’t do anything quick on the ground. In the air, my 24 (F-24W41A – same as the W46A, except pre-war) is marvelously smooth and responsive to the controls alongside modern spam-cans – lots of stick motion, but control feel is quite harmonius – very powerful rudder, by the way. Visibility is pretty good for an old round-engined aeroplane. You’ll be shocked at first by the feeling you are a long way from the panel, but you sit up pretty high. I’m sure it’s a bit harder to see forward at 3-point with the Ranger engine vs. the Warner, but maybe a bit easier to see around the side at 3-point – no visibility trouble with either engine when level, just the fuselage V-bracing, windshield joints and the landing gear and struts, so get the tail up as soon as you can on take-off. My 24 has the Warner 165 with the Sensenich wood prop, and it is not a sprightly climber. I bet you fellows with the 200 horse Ranger do lots better. I’d like to have about a hundred more horsepower. Have fun, and make sure to roll down your window and hang your elbow out in the breeze (after you’ve stowed all the paper and maps in the cockpit)! That should be part of every checkout in the 24. Tony LoweF-24W41A, S/N 136, N28522 From: Richard Ellingworth richardecho@hotmail.com [fairchildclub] Sent: Tuesday, March 21, 2017 3:44 PMTo: fairchildclub@yahoogroups.com Subject: Re: [fairchildclub] POH Don't be in a huge rush to push the stick forward on the initial roll as it takes some serious pushing if you go too early, wait for a little speed to build and she pushes forward lovely. Be careful with the trim when you first take off, I'd suggest a neutral setting. If you get it wrong it takes some hauling off the deck and a quick turn on the handle on early lift which can be a bit frantic. Approach at 70 first stage of flap with short final 65 to 60 full flap, 55 to 50 over the numbers and fly her down the runway, let it gently bleed off until the wheels rumble on the ground and hold that position. Keep a decent speed on the long approach, don't be tempted to drag it in with a nose high attitude. I didn't have hundreds of tailwheel hours and found my first flight in the Fairchild a joy. Grass is obviously easy and more forgiving if your not all that straight but tarmac is fine although you will have to be prepared to peddle that bit harder on touchdown! The aircraft can handle superb crosswinds and very stable in flight even if its pretty turbulent. Make sure your brakes are working sufficiently as in crosswinds you will need some opposite braking, my brakes were binding on one side on a recent flight which made it a bit of a challenge. Hope this helps and have a brilliant first flight!! All the best RichardUK
Subject: Re: [fairchildclub] POH 1946 F24R, N81361She likes grass. Feed her asphalt and she can get a little cross and grab a bit. Rarely three point her, but do and with her longer nose she behaves. Most landings are tail low wheel landings. Extra speed means harder work bleeding it off. Many fly final at 70, I fly at 60 with full flaps. Nice short field takeoff performance. Note the passenger restriction (CG) with full (60 gal) fuel. L magneto had the impulse coupling for the start.
Tom Woodward
Granbury, Texas
#yiv0539832480 #yiv0539832480 -- #yiv0539832480ygrp-mkp {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}#yiv0539832480 #yiv0539832480ygrp-mkp hr {border:1px solid #d8d8d8;}#yiv0539832480 #yiv0539832480ygrp-mkp #yiv0539832480hd {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}#yiv0539832480 #yiv0539832480ygrp-mkp #yiv0539832480ads {margin-bottom:10px;}#yiv0539832480 #yiv0539832480ygrp-mkp .yiv0539832480ad {padding:0 0;}#yiv0539832480 #yiv0539832480ygrp-mkp .yiv0539832480ad p {margin:0;}#yiv0539832480 #yiv0539832480ygrp-mkp .yiv0539832480ad a {color:#0000ff;text-decoration:none;}#yiv0539832480 #yiv0539832480ygrp-sponsor #yiv0539832480ygrp-lc {font-family:Arial;}#yiv0539832480 #yiv0539832480ygrp-sponsor #yiv0539832480ygrp-lc #yiv0539832480hd {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}#yiv0539832480 #yiv0539832480ygrp-sponsor #yiv0539832480ygrp-lc .yiv0539832480ad {margin-bottom:10px;padding:0 0;}#yiv0539832480 #yiv0539832480actions {font-family:Verdana;font-size:11px;padding:10px 0;}#yiv0539832480 #yiv0539832480activity {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}#yiv0539832480 #yiv0539832480activity span {font-weight:700;}#yiv0539832480 #yiv0539832480activity span:first-child {text-transform:uppercase;}#yiv0539832480 #yiv0539832480activity span a {color:#5085b6;text-decoration:none;}#yiv0539832480 #yiv0539832480activity span span {color:#ff7900;}#yiv0539832480 #yiv0539832480activity span .yiv0539832480underline {text-decoration:underline;}#yiv0539832480 .yiv0539832480attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}#yiv0539832480 .yiv0539832480attach div a {text-decoration:none;}#yiv0539832480 .yiv0539832480attach img {border:none;padding-right:5px;}#yiv0539832480 .yiv0539832480attach label {display:block;margin-bottom:5px;}#yiv0539832480 .yiv0539832480attach label a {text-decoration:none;}#yiv0539832480 blockquote {margin:0 0 0 4px;}#yiv0539832480 .yiv0539832480bold {font-family:Arial;font-size:13px;font-weight:700;}#yiv0539832480 .yiv0539832480bold a {text-decoration:none;}#yiv0539832480 dd.yiv0539832480last p a {font-family:Verdana;font-weight:700;}#yiv0539832480 dd.yiv0539832480last p span {margin-right:10px;font-family:Verdana;font-weight:700;}#yiv0539832480 dd.yiv0539832480last p span.yiv0539832480yshortcuts {margin-right:0;}#yiv0539832480 div.yiv0539832480attach-table div div a {text-decoration:none;}#yiv0539832480 div.yiv0539832480attach-table {width:400px;}#yiv0539832480 div.yiv0539832480file-title a, #yiv0539832480 div.yiv0539832480file-title a:active, #yiv0539832480 div.yiv0539832480file-title a:hover, #yiv0539832480 div.yiv0539832480file-title a:visited {text-decoration:none;}#yiv0539832480 div.yiv0539832480photo-title a, #yiv0539832480 div.yiv0539832480photo-title a:active, #yiv0539832480 div.yiv0539832480photo-title a:hover, #yiv0539832480 div.yiv0539832480photo-title a:visited {text-decoration:none;}#yiv0539832480 div#yiv0539832480ygrp-mlmsg #yiv0539832480ygrp-msg p a span.yiv0539832480yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;}#yiv0539832480 .yiv0539832480green {color:#628c2a;}#yiv0539832480 .yiv0539832480MsoNormal {margin:0 0 0 0;}#yiv0539832480 o {font-size:0;}#yiv0539832480 #yiv0539832480photos div {float:left;width:72px;}#yiv0539832480 #yiv0539832480photos div div {border:1px solid #666666;height:62px;overflow:hidden;width:62px;}#yiv0539832480 #yiv0539832480photos div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}#yiv0539832480 #yiv0539832480reco-category {font-size:77%;}#yiv0539832480 #yiv0539832480reco-desc {font-size:77%;}#yiv0539832480 .yiv0539832480replbq {margin:4px;}#yiv0539832480 #yiv0539832480ygrp-actbar div a:first-child {margin-right:2px;padding-right:5px;}#yiv0539832480 #yiv0539832480ygrp-mlmsg {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}#yiv0539832480 #yiv0539832480ygrp-mlmsg table {font-size:inherit;font:100%;}#yiv0539832480 #yiv0539832480ygrp-mlmsg select, #yiv0539832480 input, #yiv0539832480 textarea {font:99% Arial, Helvetica, clean, sans-serif;}#yiv0539832480 #yiv0539832480ygrp-mlmsg pre, #yiv0539832480 code {font:115% monospace;}#yiv0539832480 #yiv0539832480ygrp-mlmsg * {line-height:1.22em;}#yiv0539832480 #yiv0539832480ygrp-mlmsg #yiv0539832480logo {padding-bottom:10px;}#yiv0539832480 #yiv0539832480ygrp-msg p a {font-family:Verdana;}#yiv0539832480 #yiv0539832480ygrp-msg p#yiv0539832480attach-count span {color:#1E66AE;font-weight:700;}#yiv0539832480 #yiv0539832480ygrp-reco #yiv0539832480reco-head {color:#ff7900;font-weight:700;}#yiv0539832480 #yiv0539832480ygrp-reco {margin-bottom:20px;padding:0px;}#yiv0539832480 #yiv0539832480ygrp-sponsor #yiv0539832480ov li a {font-size:130%;text-decoration:none;}#yiv0539832480 #yiv0539832480ygrp-sponsor #yiv0539832480ov li {font-size:77%;list-style-type:square;padding:6px 0;}#yiv0539832480 #yiv0539832480ygrp-sponsor #yiv0539832480ov ul {margin:0;padding:0 0 0 8px;}#yiv0539832480 #yiv0539832480ygrp-text {font-family:Georgia;}#yiv0539832480 #yiv0539832480ygrp-text p {margin:0 0 1em 0;}#yiv0539832480 #yiv0539832480ygrp-text tt {font-size:120%;}#yiv0539832480 #yiv0539832480ygrp-vital ul li:last-child {border-right:none !important;}#yiv0539832480
