'Fellow members please tell me what I need to know about putting a
scott 3200 tail wheel on my 24.
http://www.whidbey.com/fairchild-nc19143'
Re: Tail Wheels
Re: Tail Wheels
'Hi Tom,
Look in the files section of the group for " bushwheel -scott- tailwheel
337.pdf "
I converted mine this summer. There are at least two others, including
one in your area ( the grey 24G that appeared in Randolph dope
advertising), but they don't have 337's.
I'm quite happy with the result thus far (about 27 hrs on it).
I can put you in touch with the IA that installed it for me; he is in
Colville in eastern WA.
Dan Casali
337.pdf "
Dan Casali
Tom Downey wrote:
Re: Tail Wheels
'--- In fairchildclub@yahoogroups.com, Dan Casali wrote:
turn radius or damage the steering cables. I was hoping some one had
converted to the 3200 Scott assembly.'
tailwheel>
> Hi Tom,
including> 337.pdf "
in> one in your area ( the grey 24G that appeared in Randolph dope
My tail wheel does not caster all th way around, I must limit the> Colville in eastern WA.
> Dan Casali
Re: Tail Wheels
Alaska Bushwheel is a PMA'd manufacturer of all the components of the
Scott 3200; thus the Bushwheel is actually a Scott 3200, full castering.
The installation requires no welding to the frame to install. Check out
the 337.
Dan
Tom Downey wrote:
Dan Casali
MacWizard
Box 1286 Ketchum, ID 83340
208.726.5120
the 337.
Dan
> , Dan Casali wrote:
> > Hi Tom,
> tailwheel
> > 337.pdf "
> including
> in
> > Dan Casali
Dan Casali
MacWizard
208.726.5120
