Re: F24R9 main gear universala
Jack Threadgill
Re: Ranger Engine on PT-19
Post by Jack Threadgill »
'Dan, as I have studied the issue, I felt I could get at the plug with an
open end like you described. I have not tried it yet, but it certainly
looks possible. I have taken the nut off the top of the plug, but the right
angle connector hits the carb before it gets out enough to remove the
cigarette from the plug. It is possible, I guess that if the plug was
loosened a bit, it would wiggle enough and lean over to remove the cigarette
and elbow. If the cigarette was flexible, it would come out, but on my
engine it is ridged.
I pulled the plugs out late this afternoon and when I hit #4, I decided to
call it a day. So I have not given it a lot of study yet.
I sure thank you for your input and suggestions.
Jack
Jack Threadgill
1602 Brook Hollow Dr
Bryan, TX 77802
979-779-7155
threadgl@suddenlink.net
On Behalf Of danMichael
Sent: Saturday, November 15, 2008 7:27 PM
Cc: threadgl@suddenlink.net
Subject: Re: [fairchildclub] Ranger Engine on PT-19
Jack:
> I need suggestions on how to remove the left hand spark plug from
> the #4
> cylinder on a Ranger engine mounted in a PT-19. Do you have to
> remove the
> carburetor, or is there an easier way? So far, I have not even been
> able to
> get the elbow connector off the top of the plug.
Ah, yes, the intake side #4 spark plug. Its my favorite. I have a
24 but I assume its the same situation on the PT.
My technique is to loosen the intercylinder baffle that the #4 plug
passes through by unscrewing its long retaining bolt (that fastens to
its paired exhaust-side baffle). That allows you to slide the baffle
outboard along the plug body and then access the plug flats with an
open end wrench inserted from below between the intake manifold
branches. There is just enough travel to turn the wrench to align
the wrench with the next flats offset the other way (flipped over).
Its agonizingly slow but it eventually gets the job done. Dont drop
the baffle when removing the plug.
I dont remember an issue with getting the elbow off. I cant remember
if I get that from below, too - its been at least a couple months
since replacing that plug.
Good luck!
:Dan Michael
:NC81323
Yahoo! Groups Links'
rangerrobertmn
Post by rangerrobertmn »
'Jack,
On mine, the elbow connector is a two-piece affair. Once the nut is
loose, I can slide the nut back up the ignition wire. The cigarette
is hard porcelain, and one edge of the cigarette near the plug is
chipped off about 45 degrees.
1939 Fairchild 24K
Sky Harbor airpark
Webster, Minnesota U.S.A.
--- In fairchildclub@yahoogroups.com, "Jack Threadgill"
> Another question from a new owner.
> I need suggestions on how to remove the left hand spark plug from the #4
remove the
able to
> Thanks for any and all suggestions.
> Jack
> Jack Threadgill
> Bryan, TX 77802
> 979-779-7155
> threadgl@...
Jack Threadgill
'Bob, the cigarette is hard material on mine as you describe. There are two
nuts on the lead. One above the elbow and one at the plug. The flexible
lead is pushed thru the metal elbow and attached to the cigarette. The
first nut attaches the shield to the metal elbow. I will study the
cigarette more carefully and see if mine has a chipped off side to allow it
to make the corner.
Thanks so much for your insight and info.
Jack
Jack Threadgill
Bryan, TX 77802
979-779-7155
On Behalf Of rangerrobertmn
Sent: Saturday, November 15, 2008 8:16 PM
Subject: [fairchildclub] Re: Ranger Engine on PT-19
Jack,
1939 Fairchild 24K
Sky Harbor airpark
remove the
able to
> Jack
> Jack Threadgill
> Bryan, TX 77802
> 979-779-7155
> threadgl@...
norbert J. Mc Luckie
Post by norbert J. Mc Luckie »
'There was a posting, some time ago, giving the details to make a wrench, made to reach that plug. I have to take the carburetor off or seriously loose, in order to remove that plug.
Lucky
Sent: Saturday, November 15, 2008 7:53 PM
Subject: [fairchildclub] Ranger Engine on PT-19
cylinder on a Ranger engine mounted in a PT-19. Do you have to remove the
carburetor, or is there an easier way? So far, I have not even been able to
Jack
Jack Threadgill
Bryan, TX 77802
979-779-7155
Tim Epperhart
Re: Headsets for open cockpits
Post by Tim Epperhart »
'I use my David Clark H20-13s with the ENC turned off in my PT.  They have excellent passive noise canceling abilities.  Hit the web and look at the noise reduction specs on different models that you are interested in.  If you fly other aircraft, I recommend the ENC.  If it's just the PT, then get a high quality passive set.  Make sure it fits your head well..  Glasses and sunglasses cause gaps between your head and earcups and let noise in, minimizing the effectiveness of your headset, so check the fit there as well.  Taking extra care to choose a headset will minimize fatigue on long flights.
Good luck!
Tim
Sent: Friday, November 14, 2008 9:05:19 AM
Subject: [fairchildclub] Headsets for open cockpits
Good morning,
I am a fairly new owner of a Fairchild PT-19 and have been trying several
headsets. I have been told the noise canceling sets don't work very well in
the open cockpits. I would appreciate any comments or suggestions on
successful models of headsets to be used in a PT-19.
Jack
Jack Threadgill
Bryan, TX 77802
979-779-7155
threadgl@suddenlink .net
Robert Webster
Post by Robert Webster »
'Check the Spring of 1992 and the Spring of 1997 Newsletters. I think I like the one in 1997 better, but your choice
Sent: Sunday, November 16, 2008 12:16 PM
Lucky
Jack
Jack Threadgill
Bryan, TX 77802
979-779-7155
Checked by AVG - http://www.avg.com
Version: 8.0.175 / Virus Database: 270.9.4/1790 - Release Date: 11/15/2008 9:32 AM
Jamie Treat
Post by Jamie Treat »
'Lucky,
See attached pics of Ranger Plug Wrench.
Aircraft Restoration & Repair
IAC 5, Chapter President
http://iac5.org
Kelly Airpark (CO15)
New Email: JamieTreat@q.com
Hm/Hgr 303-648-0130
Cell 303-304-7937
Quote of the Month: If helicopters are so safe, how come there are no vintage/classic
helicopter fly-ins? - Anonymous
Sent: Sunday, November 16, 2008 11:16 AM
Lucky
Jack
Jack Threadgill
Bryan, TX 77802
979-779-7155
Cy Galley
Post by Cy Galley »
'No attachment!
To: threadgl@suddenlink.net
Cc: fairchildclub@yahoogroups.com
Sent: Sunday, November 16, 2008 5:08 PM
Lucky,
http://iac5.org
Hm/Hgr 303-648-0130
Cell 303-304-7937
Lucky
Jack
Jack Threadgill
Bryan, TX 77802
979-779-7155
Jack Threadgill
'Bob, thanks for the suggestion on newsletters. I will look them up.
Jack
Jack Threadgill
Bryan, TX 77802
979-779-7155
On Behalf Of Robert Webster
Sent: Sunday, November 16, 2008 2:50 PM
Lucky
Jack
Jack Threadgill
Bryan, TX 77802
979-779-7155
Checked by AVG - http://www.avg com
9:32 AM
harry hayman
Post by harry hayman »
'Need help
I have been told tht these universals must be changed out for beffier ones.Is this true?
I have researched and find only one AD (47 50 09)Which does not pertain to the universals.
Any info would be appreciate any imput on this matter
Harrry
Harry Hayman
Phone 904-284-4276
Fax 904-284-3869
Date: Sunday, November 16, 2008, 6:08 PM
Lucky,
http://iac5. org
New Email: JamieTreat@q. com
Hm/Hgr 303-648-0130
Cell 303-304-7937
Lucky
Jack
Jack Threadgill
Bryan, TX 77802
979-779-7155
