Re: fuel flow
fuel flow
'I checked the fuelflow on both tanks at the carburetor side of the
fuel line.
Left tank:170 liters or app 37 gallons an hour
right tank 150 liters or app 33 gallons an hour
During take off at full power my engine surges.Less power cures the
problem.I tried leaning the mixture,flying on both tanks,but to no avail.
Any ideas out there?
Filters inside the carb and strainer are absolutely clean.
Thanks for any help.
Remko
PS:the other engine in our f24 had a fuelpump installed.Could this be
a hint?'
fuel line.
Remko
a hint?'
Re: fuel flow
'Remko,
In FLIGHT attitude, the Fairchild 24 has about 3 p.s.i. pressure at
the carb. In TAKEOFF attitude, there is less pressure. You don't
mention how steep you are climbing. At anything less than 70 mph,
you are getting pretty steep. You also don't mention whether the
tanks are full. Half full tanks at steep attitude don't provide
much pressure at the carb.
That said, I suspect that you have a carb problem, not a fuel flow
problem. The only fuel flow problem that I have, occurs when some
fuel has leaked out past the needle valve, leaving a void in the
fuel line. This void generally hits the carb all at once, and I get
a 'heck of a surge', to the point where I try to NEVER let it happen.
1939 Fairchild 24 K 200hp
Stillwater MN
Stillwater MN
> fuel line.
avail.
> Remko
be
> a hint?
Re: fuel flow
'Bob, the plane was lightly loaded.Only me,(160 lbs) and 1/3 tanks.I
was climbing pretty steep.70-75 mph.
Carb is clean inside.
BTW,during level flight this problem did not occur.
I can try again with more fuel and more speed to see if this helps..If
you think it is worth the try.
You also speak about a void which you try to never let happen.Could
you please explain this for me?How and why?
Remko
--- In fairchildclub@yahoogroups.com, "rangerrobertmn"
Remko
> Remko,
> Bob Waldron
> Stillwater MN
> > fuel line.
> avail.
> > Remko
> be
> > a hint?
Re: fuel flow
'Dad had a problem with the F24G on takeoff....might have had air in the fuel
line...quit at about 50' AGL.
I'd like to know more about the fuel pump....would be a great idea.
Thanks!
Richard Hawley
_oldoowl@aol.com_ (mailto:oldoowl@aol.com)
************************************** See what's free at http://www.aol.com
Thanks!
Richard Hawley
Re: fuel flow
'climb was slower.65-70 mph.
The fuelpump installed on the other engine was from the PT series I
think.But I do not want to install something which is not needed.
Is my fuel flow ok or did some of us see other values?
Remko
Remko
helps..If
> Thanks,
> Remko
> wrote:
> > Remko,
at
don't
mph,
flow
some
get
happen.
> > Bob Waldron
> > Stillwater MN
the
> > > fuel line.
the
no
> > avail.
> > > Remko
this
> > be
> > > a hint?
Re: fuel flow
'Remko - Have you by chance recently drained your fuel tanks. I once drained my tanks to work on fuel lines and found that air got entrapped between the tank and the fuel selector. So... when I switched to the other tank it gulped only air and quit running. Quickly swapped back to first tank and she started running again. After much experimenting on the ground I find that if I completely drain my tanks and then refill and remove line from gascolator I get no flow unless I first blow 3-5 psi back up the line. Forces air bubble back into tank then fuell flows. This problem is "usually" overcome by adding more fuel to the tanks. More fuel equals more head pressure I guess. Moral of the story for my airplane is never accidentally run a tank dry. - gary
m51rs wrote: climb was slower.65-70 mph.
Remko
Remko
helps..If
> Thanks,
> Remko
> wrote:
> > Remko,
at
don't
mph,
flow
some
get
happen.
> > Bob Waldron
> > Stillwater MN
the
> > > fuel line.
the
no
> > avail.
> > > Remko
this
> > be
> > > a hint?
Get the Yahoo! toolbar and be alerted to new email wherever you're surfing.
Re: fuel flow
'Remko,
Just a thought, I had a similar problem some time ago.
More of an occasional engine stumble when I pulled the nose up and
gave it power to gain altitude. My Stromberg was looking pretty sad
at that time, so I sent it off for a rebuild. The shop said it was a
Carb off a different type Ranger engine than mine. A Ranger with a
mechanically drive fuel pump. Like a PT 19. On the identification
plate on the carb it was clearly stamped 3 lbs psi which according
to the over hauler should only be 1 lbs psi type if installed on a
gravity fed Fairchild. The carb was rebuilt to 1 lb specifications
which does change the float/fuel level. The rebuilder said a Stromberg
off a Ranger with a engine drive fuel pump will work on F-24, but if
the circumstances where just right, it could run lean because of
different fuel levels in the float bowl. .I've experienced no further
problems. Your fuel flow readings appear adequate.
Hanford,Ca'
Hanford,Ca'
Re: fuel flow
'Tom,I will check the id plate tomorrow.
This surely makes things not easier..
Does anbody know how to change the carb to 1 psi?
I learn about fairchilds everyday it seems.
Thanks everybody.
Remko
Thanks everybody.
Remko
'--- In fairchildclub@yahoogroups.com, "Tom Mueller" wrote:
> Remko,
> Tom
> Hanford,Ca
Re: fuel flow
'I had mine done by Aircraft Systems Inc. I didn't do much shopping
around. I just wanted to go fly. They were kind of pricey as I recall,
around $700 bucks, but their knowledge and workmanship with vintage
aircraft Carburetors was superior.
5187 Falcon Rd.
Rockford, IL 61109
(815) 399-0225'
5187 Falcon Rd.
Rockford, IL 61109
(815) 399-0225'
Re: fuel flow
'Hello Remko,
What is the type and part number of the carburettor? Stromberg or
Marvel-Schebler?
If it is a Marvel-Schebler there are AD's of importance, especially
the one of the venturi.
Karl
Marvel-Schebler?
Karl
> Tom
> 5187 Falcon Rd.
> Rockford, IL 61109
> (815) 399-0225
