Ranger exhaust
Ranger exhaust
'Hey to all,
While pulling the exhaust stacks to install new gaskets all the way
around for my C-5, I found three gaskets with burn marks from hot
gases escaping, warped flanges and one crack at a stud hole. Their SS
type, three in one . They always looked pretty healthy on the walk
around, but? they're junk! Crapola
Anybody know where I can get a set of these?? anybody making
them. Thanks?
Hanford,Ca'
them. Thanks?
Hanford,Ca'
Re: Ranger exhaust
'Tom, I'm not familiar with the West Coast, here in the East there was a
shop at Crooked Branch in West Virginia. This
Shop had the jigs for the front and rear pipes for the ranger. Over the
years I had used his pipes on all three of my
Fairchild Aircraft and still have a set on my PT. They fit and have lasted.
I have seen the edge seamed pipes and
they are two thin and will burn through in a season or two. The butt weld
type is the way to go, as the diameter grows
as each exhaust stack joins the main pipe. Maybe Jamie Treat can steer
right. I am sure some one at Santa Paula
has a line on good pipes too. Good luck, Bob Haas.
On Behalf Of Tom Mueller
Sent: Friday, March 23, 2007 8:13 PM
Subject: [fairchildclub] Ranger exhaust
Hey to all,
around, but. they're junk! Crapola
Anybody know where I can get a set of these.. anybody making
them. Thanks.
Hanford,Ca
Hey to all,
them. Thanks.
Hanford,Ca
Re: Ranger exhaust
'Thanks bob. That sounds very interesting about the stacks made by a
West Virginia Company. What is it made of, does it look ok on the
Fairchild. Would be neat to see a photo if possible. I'll admit the
seamed SS does seem a bit thin, but I wasn't aware there were other
choices. I may be hitting you up for a phone number for that Co.
Sounds like your satisfied with the results.
Tom'
Tom'
Re: Ranger exhaust
'Bob, thanks again for your interest, but my problem has been resolved
in the last hour.
(Thanks mike)
Hanford,ca'
in the last hour.
(Thanks mike)
Hanford,ca'
Re: Ranger exhaust
'I had Dawley Aviation of Burlington, Wisconsin make a set for PT-19 several years ago. They are stainless and still look like new.
their number is 800 338 5420
John
John
Re: Ranger exhaust
'Tom, John:
> John
I also had a good experience with Dawley a couple years ago when one
of my stacks cracked at the carb hot spot tube. They patched the
hole and replaced all the flanges. At that time, they said they
could not build new Ranger stacks because they did not have tooling.
:Dan Michael
:NC81323
Re: Ranger exhaust
'Hi all,
In thinking back, I think I remember machining some stainless flanges in my shop as they didn't have and coudn't make them.
Somehow they did get a set of pipes made for me.
John
John
Sent: Saturday, March 24, 2007 1:08 PM
Subject: [fairchildclub] Re: Ranger exhaust
Tom, John:
> John
:Dan Michael
:NC81323
Re: Ranger exhaust
The club did have some stacks made last yea we co not plan on having any more made but , will talk to the shop who did them.
Sent: Friday, March 23, 2007 6:12 PM
Hey to all,
them. Thanks.
Hanford,Ca
Re: Ranger exhaust
'John,
I did get a member to sell and is sending me an exhaust set with
about 150 hours on it. That solves a big problem, but another
glitch has come up. While removing the exhaust port aluminum
spacers, I noticed the "stamped" serial number and the name "ALCOR"
on the cooling fin were not located in the same position in relation
to each other. . It must be important because there is a very
slight angle difference to the face that mounts to the exhaust
manifold. That could explain the three burnt gaskets found at the
bottom of the spacer where the exhaust manifold flange hooks up.
I find no information on how these spacers are mounted.
Interestingly, the parts manual says of the six spacers, two are
supposed to be stamped part number #6614 and four stamped #6616.
Mine are all #6614 . Can you or another member help me figure this
out??
Hanford,ca'
out??
Hanford,ca'
Re: Ranger exhaust
'I'm also experiencing gas leaks and wonder if I've got the same problem.
Any guidance here?
Mike Danielle
Any guidance here?
Mike Danielle
Sent: Monday, March 26, 2007 2:54 PM
John,
out..
Hanford,ca
