'I'm forwarding this request to the group. Marinoni is looking for Warner parts.
Quando omni flunkus moritati
- "Red" Green
----- Forwarded Message ----
To: mjd12k
Sent: Monday, February 19, 2007 5:24:56 AM
Subject: Fwd:rfq engine parts warner
Good morning sir
in our maintenance we have one engine Warner 165HP.
I ask you if is possible a help for to need the parts
for the revision.
Please reply me A.S.A.P. is very urgent
Many thank's for your collaboration
Marinoni Pietro
Officine Aeronautiche David
Via Galileo Galilei Trav. III N°4
25010 San Zene Naviglio
Brescia
Italy
Tel. +39 030-2667133
fax +39 030-2160877
E-mail pietromarinoni@libero.it
We attached the parts list
P/N DESCRIPTION QTY
8222 SLEEVE 1
8289-1 GASKET 2
7253 RING 1
LW-757 LOCK WASHER 8
7161 GASKET 14
7875 PACKING 1
7884 GASKET 1
8027 GASKET 7
7150 GASKET 1
7849-02 VALVE GUIDE 7
7261-00 VALVE GUIDE 7
7612 RETAINER 7
7555 RETAINER 7
G-547 GASKET 7
G-771 GASKET 14
7963 HOSE 2
7272 GASKET 7
7906 PACKING 7
7926-1 GASKET 14
G-555 GASKET 1
8034 HOSE 2
7963 HOSE 2
SE-833 SEAL 1
7931 GASKET 1
8226 GASKET 2
7594 GASKET 1
7930 GASKET 2
G-791 GASKET 2
7925 GASKET 2
7295 GASKET 2
G-545 GASKET 4
G-765 GASKET 1
G-766 GASKET 1
7921 GASKET 1
7104 PACKING 1
7883 GASKET 1
SE-797 SEAL 1
G-767 GASKET 1
7930 GASKET 4
8262 GASKET 1
8067 GASKET 1
SE-832 SEAL 2
8065 RETAINER 1
8195 GASKET 1
8057 RING 2
8056 RING 1
G-825 GASKET 1
7589 PISTON RING 7
75089-1 PISTON RING 7
7537 PISTON RING 7
7538 EXPANDER 7
8088 BEARING UPPER 1
8087 BEARING LOWER 1
7235 BOLT 4
7236 NUT 4
7072-B BOLT 6
AN355-5 NUT 6
7069 BUSHING 7
7922 GASKET 1
7808 GASKET 1
G-571 GASKET 1
7156 GASKET 1
8:00? 8:25? 8:40? Find a flick in no time
with the Yahoo! Search movie showtime shortcut.
http://tools.search.yahoo.com/shortcuts/#news'
Re: Used intake and exhaust valves
harry hayman
'Mike,
If I remenber correctly you build up Ranger engines.
I have a number of intake and exhaust valves wich I
think could be bench checked and tagged.Would you know
any repair station which could do this and also do you
know anyone who would be intrested in the valves?
Thanx
Harry
--- Michael Denest wrote:
Phone 904-284-4276
Fax 904-284-3869
Don't get soaked. Take a quick peak at the forecast
with the Yahoo! Search weather shortcut.
http://tools.search.yahoo.com/shortcuts/#loc_weather'
Thanx
Harry
____________________________________________________________________________________> I'm forwarding this request to the group. Marinoni
> Mike
> - "Red" Green
> From: "pietromarinoni@libero.it"
> To: mjd12k
> Good morning sir
> parts
> for the revision.
> Marinoni Pietro
> Brescia
> Italy
> fax +39 030-2160877
> P/N DESCRIPTION QTY
> 8222 SLEEVE 1
> 8289-1 GASKET 2
> 7253 RING 1
> 7161 GASKET 14
> 7875 PACKING 1
> 7884 GASKET 1
> 8027 GASKET 7
> 7150 GASKET 1
> 7612 RETAINER 7
> 7555 RETAINER 7
> G-547 GASKET 7
> G-771 GASKET 14
> 7963 HOSE 2
> 7272 GASKET 7
> 7906 PACKING 7
> 7926-1 GASKET 14
> G-555 GASKET 1
> 8034 HOSE 2
> 7963 HOSE 2
> SE-833 SEAL 1
> 7931 GASKET 1
> 8226 GASKET 2
> 7594 GASKET 1
> 7930 GASKET 2
> G-791 GASKET 2
> 7925 GASKET 2
> 7295 GASKET 2
> G-545 GASKET 4
> G-765 GASKET 1
> G-766 GASKET 1
> 7921 GASKET 1
> 7104 PACKING 1
> 7883 GASKET 1
> SE-797 SEAL 1
> G-767 GASKET 1
> 7930 GASKET 4
> 8262 GASKET 1
> 8067 GASKET 1
> SE-832 SEAL 2
> 8065 RETAINER 1
> 8195 GASKET 1
> 8057 RING 2
> 8056 RING 1
> G-825 GASKET 1
> 7589 PISTON RING 7
> 7537 PISTON RING 7
> 7538 EXPANDER 7
> 7235 BOLT 4
> 7236 NUT 4
> 7072-B BOLT 6
> AN355-5 NUT 6
> 7069 BUSHING 7
> 7922 GASKET 1
> 7808 GASKET 1
> G-571 GASKET 1
> 7156 GASKET 1
Harry Hayman> 8:00? 8:25? 8:40? Find a flick in no time
Phone 904-284-4276
Fax 904-284-3869
'To all, Me too, about 48 good ones! Bob Haas.
On Behalf Of harry hayman
Sent: Monday, February 19, 2007 8:32 PM
Subject: [fairchildclub] Used intake and exhaust valves
Mike,
Thanx
Harry
Phone 904-284-4276
Fax 904-284-3869
http://tools.
Mike,
Thanx
Harry
> Mike
> - "Red" Green
> From: "pietromarinoni@ libero.it"
> To: mjd12k
> Good morning sir
> parts
> for the revision.
> Marinoni Pietro
> Brescia
> Italy
> fax +39 030-2160877
> E-mail pietromarinoni@ libero.it
> P/N DESCRIPTION QTY
> 8222 SLEEVE 1
> 8289-1 GASKET 2
> 7253 RING 1
> 7161 GASKET 14
> 7875 PACKING 1
> 7884 GASKET 1
> 8027 GASKET 7
> 7150 GASKET 1
> 7612 RETAINER 7
> 7555 RETAINER 7
> G-547 GASKET 7
> G-771 GASKET 14
> 7963 HOSE 2
> 7272 GASKET 7
> 7906 PACKING 7
> 7926-1 GASKET 14
> G-555 GASKET 1
> 8034 HOSE 2
> 7963 HOSE 2
> SE-833 SEAL 1
> 7931 GASKET 1
> 8226 GASKET 2
> 7594 GASKET 1
> 7930 GASKET 2
> G-791 GASKET 2
> 7925 GASKET 2
> 7295 GASKET 2
> G-545 GASKET 4
> G-765 GASKET 1
> G-766 GASKET 1
> 7921 GASKET 1
> 7104 PACKING 1
> 7883 GASKET 1
> SE-797 SEAL 1
> G-767 GASKET 1
> 7930 GASKET 4
> 8262 GASKET 1
> 8067 GASKET 1
> SE-832 SEAL 2
> 8065 RETAINER 1
> 8195 GASKET 1
> 8057 RING 2
> 8056 RING 1
> G-825 GASKET 1
> 7589 PISTON RING 7
> 7537 PISTON RING 7
> 7538 EXPANDER 7
> 7235 BOLT 4
> 7236 NUT 4
> 7072-B BOLT 6
> AN355-5 NUT 6
> 7069 BUSHING 7
> 7922 GASKET 1
> 7808 GASKET 1
> G-571 GASKET 1
> 7156 GASKET 1
search.yahoo.com/shortcuts/#news> 8:00? 8:25? 8:40? Find a flick in no time
> http://tools.
Harry Hayman>
Phone 904-284-4276
Fax 904-284-3869
http://tools.
'Harry,
There is no way I know of to bench check and certify valves other than by magna flux inspection. Generally, a repair station or overhaul facility will decarbonize and degrease the valves, dimension inspect and lap in with the valve seats in the cylinder.
----- Original Message ----
Sent: Monday, February 19, 2007 8:32:04 PM
Mike,
Thanx
Harry
Phone 904-284-4276
Fax 904-284-3869
http://tools. search.yahoo. com/shortcuts/ #loc_weather
Yahoo! Music Unlimited
Access over 1 million songs.
http://music.yahoo.com/unlimited
Mike,
Thanx
Harry
____________ _________ _________ _________ _________ _________ _> I'm forwarding this request to the group. Marinoni
> Mike
> - "Red" Green
> To: mjd12k
> Good morning sir
> parts
> for the revision.
> Marinoni Pietro
> Brescia
> Italy
> fax +39 030-2160877
> P/N DESCRIPTION QTY
> 8222 SLEEVE 1
> 8289-1 GASKET 2
> 7253 RING 1
> 7161 GASKET 14
> 7875 PACKING 1
> 7884 GASKET 1
> 8027 GASKET 7
> 7150 GASKET 1
> 7612 RETAINER 7
> 7555 RETAINER 7
> G-547 GASKET 7
> G-771 GASKET 14
> 7963 HOSE 2
> 7272 GASKET 7
> 7906 PACKING 7
> 7926-1 GASKET 14
> G-555 GASKET 1
> 8034 HOSE 2
> 7963 HOSE 2
> SE-833 SEAL 1
> 7931 GASKET 1
> 8226 GASKET 2
> 7594 GASKET 1
> 7930 GASKET 2
> G-791 GASKET 2
> 7925 GASKET 2
> 7295 GASKET 2
> G-545 GASKET 4
> G-765 GASKET 1
> G-766 GASKET 1
> 7921 GASKET 1
> 7104 PACKING 1
> 7883 GASKET 1
> SE-797 SEAL 1
> G-767 GASKET 1
> 7930 GASKET 4
> 8262 GASKET 1
> 8067 GASKET 1
> SE-832 SEAL 2
> 8065 RETAINER 1
> 8195 GASKET 1
> 8057 RING 2
> 8056 RING 1
> G-825 GASKET 1
> 7589 PISTON RING 7
> 7537 PISTON RING 7
> 7538 EXPANDER 7
> 7235 BOLT 4
> 7236 NUT 4
> 7072-B BOLT 6
> AN355-5 NUT 6
> 7069 BUSHING 7
> 7922 GASKET 1
> 7808 GASKET 1
> G-571 GASKET 1
> 7156 GASKET 1
> http://tools. search.yahoo. com/shortcuts/ #news
Phone 904-284-4276
Fax 904-284-3869
harry hayman
'Mike
Thanx much/
Harry
PS I have 6 new new intake valves
in the original boxes.$200.00 for the set.
Phone 904-284-4276
Fax 904-284-3869
Never miss an email again!
Yahoo! Toolbar alerts you the instant new Mail arrives.
http://tools.search.yahoo.com/toolbar/features/mail/'
Thanx much/
Harry
____________________________________________________________________________________> Harry,
> cylinder.
> Mike
> From: harry hayman
> valves
> Mike,
> know
> you
> Thanx
> Harry
> > Mike
> > - "Red" Green
> > To: mjd12k
> > Good morning sir
> 165HP.
> > parts
> > for the revision.
> > Marinoni Pietro
> > Brescia
> > Italy
> > fax +39 030-2160877
> > P/N DESCRIPTION QTY
> > 8222 SLEEVE 1
> > 8289-1 GASKET 2
> > 7253 RING 1
> > 7161 GASKET 14
> > 7875 PACKING 1
> > 7884 GASKET 1
> > 8027 GASKET 7
> > 7150 GASKET 1
> > 7612 RETAINER 7
> > 7555 RETAINER 7
> > G-547 GASKET 7
> > G-771 GASKET 14
> > 7963 HOSE 2
> > 7272 GASKET 7
> > 7906 PACKING 7
> > 7926-1 GASKET 14
> > G-555 GASKET 1
> > 8034 HOSE 2
> > 7963 HOSE 2
> > SE-833 SEAL 1
> > 7931 GASKET 1
> > 8226 GASKET 2
> > 7594 GASKET 1
> > 7930 GASKET 2
> > G-791 GASKET 2
> > 7925 GASKET 2
> > 7295 GASKET 2
> > G-545 GASKET 4
> > G-765 GASKET 1
> > G-766 GASKET 1
> > 7921 GASKET 1
> > 7104 PACKING 1
> > 7883 GASKET 1
> > SE-797 SEAL 1
> > G-767 GASKET 1
> > 7930 GASKET 4
> > 8262 GASKET 1
> > 8067 GASKET 1
> > SE-832 SEAL 2
> > 8065 RETAINER 1
> > 8195 GASKET 1
> > 8057 RING 2
> > 8056 RING 1
> > G-825 GASKET 1
> > 7589 PISTON RING 7
> > 7537 PISTON RING 7
> > 7538 EXPANDER 7
> > 7235 BOLT 4
> > 7236 NUT 4
> > 7072-B BOLT 6
> > AN355-5 NUT 6
> > 7069 BUSHING 7
> > 7922 GASKET 1
> > 7808 GASKET 1
> > G-571 GASKET 1
> > 7156 GASKET 1
> _________ _
> Harry Hayman
> Phone 904-284-4276
> Fax 904-284-3869
> _________ _
> #loc_weather
Harry Hayman> Yahoo! Music Unlimited
> removed]
Phone 904-284-4276
Fax 904-284-3869
