'Hi Guys
I have recently refurbished my brakes and am wondering what fluid to
use ? have heard some horror stories ?
I am using the original system .
Best regards
James Bryan
G-RGUS'
Re: Brake fluid
Re: Brake fluid
'James,
Do not use 5606!! It will destroy your system.
If you want to switch over to Syn Dot 5 you can do so now You will need to flush the entire system with de-natured Alcohol. It must be free of all mineral base other wise it will foam up and render brakes non-effective. Make sure you annotate the logs and mark the Brake system of what type. I make up a fluids list for the older aircraft for the A&P and next owner.
If you stick with the old Dot 4 you will have the moisture problem, corrosion, and paint stripping capability.
Aircraft Restoration & Repair
Kelly Airpark (CO15)
Elbert, CO 80106
Hm/Hgr 303-648-0130
Always keep an 'out' in your hip pocket. - Bevo Howard
Elbert, CO 80106
Hm/Hgr 303-648-0130
Sent: Thursday, February 01, 2007 4:59 PM
Subject: [fairchildclub] Brake fluid
Hi Guys
Best regards
James Bryan
G-RGUS
Re: Brake fluid
'I concur with Jamie. Save your old Dot 3 & Dot 4. It makes a good poor mans substitute for paint remover.
Bob Etter
PO Box 974
Tonopah, NV 89049
775-482-6820
rletter@citlink.net
Bob Etter
PO Box 974
Tonopah, NV 89049
775-482-6820
rletter@citlink.net
Re: Brake fluid
'--- In fairchildclub@yahoogroups.com, "Robert Etter"
poor mans substitute for paint remover.>
'> Bob Etter
> PO Box 974
> Tonopah, NV 89049
> 775-482-6820
> rletter@...
