'Sorry for asking again but just for the record, could anyone please state
FULL particulars on converting to Cleveland wheels and brakes on a F-24?
I contacted one source for Cessna 310 wheels and he said he had plenty of
them..Goodyear wheels though, not Cleveland. Not a good start. Another asked
what size of tire I wanted to use. Another suggested something off an Aztec might
be better. Shyt..I'm getting nowhere.
Jamie Treat was very helpful in detailed info on the 310/210 relationship and it sounds
like a nice workable combination but I could sure use some help in sources or
applications for new or used, or part numbers would be really nice. Thanks..
C-FDWS Christavia
F-24 C-FDAE in restoration
Re: Cleveland wheels and brakes again
ranger440c5
'I have not put a set on a F24 but am familiar with these. The
Fairchild uses a big inner/little outer bearing. The spacing for the
Cleveland kit requires that the axle be pulled outward and rotated
90deg(to allow a fresh hole for the retaining bolt. The axle needs to
be pulled outward by 3/16 - 1/4. This is to keep the rotor centered
about the caliper and torque plate. Many, many , many Wacos use this
Cleveland Cessna 310 conversion kit #199-64(I think) and they have
NOT changed the masters which are the same Hayes '37 Desoto,Chrysler
units that Fairchild use. They seem to be doing just fine with out
needing bushing. The torque plate should bolt to the brake plate
flange with no ordeal. The bearings slide right on. The seal may or
may not, this is an unspoken hush hush area. If a Fairchild axle seal
journal is 1-3/4" OK, if 1-13/16" ..nope won't fit, fix it yourself.
The nut and washer fit, the hub cap gets discarded or punched to fit
for wheel pant bracket. The hose will be a -4 and the caliper takes
AN -4 fittings either with a union or bulkhead fitting and nut and o-
ring. On an F24 you may have to swing the caliper on the bottom to
clear pants, the torque plate can mount in about every 45deg to allow
this.
Now, it sounds like you're trying to get this on the cheap....ain't
gonna happen. There are none of these in the junk yards. You can try
but good luck. I have found one set that Preferred Airparts had..the
rotors were wasted, brgs rusted,and who knows what the wheels were
like...think of the hamfisted nut behind that heavy 310 smacking the
tarmac...there's a reason it was in the junkyard!!! The cost of
admission here is $2025 at Aircraft Spruce(they get them from
Aviall). The only way you're getting them cheaper is to get the
jobber price and I don't think you are getting in for less than
$1700. So for all those who don't have any Pixie dust to sprinkle on
their expander tube system dig deep.
--- In fairchildclub@yahoogroups.com, "david stroud"
this.
state>
F-24?> FULL particulars on converting to Cleveland wheels and brakes on a
plenty of>
Another asked> them..Goodyear wheels though, not Cleveland. Not a good start.
an Aztec might> what size of tire I wanted to use. Another suggested something off
relationship and it sounds> be better. Shyt..I'm getting nowhere.
sources or> like a nice workable combination but I could sure use some help in
Thanks..> applications for new or used, or part numbers would be really nice.
> C-FDWS Christavia
David Stroud
'Thank you for the detailed explanation of what is involved. No..I'm not trying to
get this done on the cheap, but I do a lot of horse trading and I'm just not familiar
with what I really need for this part of the project. There may be other possibilities.
C-FDWS Christavia
C-FDWS Christavia
Sent: Tuesday, January 10, 2006 11:02 PM
Subject: [fairchildclub] Re: Cleveland wheels and brakes again
this.
state
F-24?
plenty of
Another asked
an Aztec might
sources or
Thanks..
> C-FDWS Christavia
YAHOO! GROUPS LINKS
Checked by AVG Free Edition.
Version: 7.1.371 / Virus Database: 267.14.16/225 - Release Date: 1/9/06
ranger440c5
'You had asked about p/n's.....
Kit # 199-64
tire size 6.50 -10
Wheel assembly.... #40-40B
Standard disc (no special treatment,IE: plated) #164-01406
Chrome disc NA
Brake assembly #30-28D
Lining #066-03300
Now, this kit #199-64 includes 2 wheel assemblies and 2 brake
assemblies.
A brake assembly consists of the caliper,linings,pressure
plate,fittings,torque plate.
A wheel assembly consists of wheel halves, tie bolts, brgs, seals,
snap rings, hub cap, rotor,etc.
In other words, all you need EXCEPT: Hardware to mount torque plate,
axle nut, key washer, cotter pin, tires, tubes, grease, hose, entry
fitting to caliper, fluid, and air for the tubes.
You provide $2000 for the 199-64 kit, $230 for the tires, $? for the
tubes, hoses, torque plate mounting hardware, axle nut, keywasher,
cotter pin, grease, fluid, and air.
Without seeing your correspondence with Jamie, by 210/310
relationship, we must assume you are referring to the "hot" setup
with restorers (esp. Wacos). This is a sound concept and is win, win
other than any paperwork issues that might arise when dealing with
various FSDO's for the blk3 337 signoff , but of course, you get the
337 approved first before spending money. The only other issue may be
cost in assembling various NEW components and the machining to do
this. It may exceed a kit price. Your call.
Kit # 199-64
tire size 6.50 -10
Chrome disc NA
Lining #066-03300
assemblies.
not trying to>
just not familiar> get this done on the cheap, but I do a lot of horse trading and I'm
other possibilities.> with what I really need for this part of the project. There may be
the>
> C-FDWS Christavia
> From: ranger440c5
rotated> Cleveland kit requires that the axle be pulled outward and
needs to> 90deg(to allow a fresh hole for the retaining bolt. The axle
centered> be pulled outward by 3/16 - 1/4. This is to keep the rotor
this> about the caliper and torque plate. Many, many , many Wacos use
have> Cleveland Cessna 310 conversion kit #199-64(I think) and they
Desoto,Chrysler> NOT changed the masters which are the same Hayes '37
out> units that Fairchild use. They seem to be doing just fine with
or> needing bushing. The torque plate should bolt to the brake plate
seal> may not, this is an unspoken hush hush area. If a Fairchild axle
yourself.> journal is 1-3/4" OK, if 1-13/16" ..nope won't fit, fix it
fit> The nut and washer fit, the hub cap gets discarded or punched to
takes> for wheel pant bracket. The hose will be a -4 and the caliper
and o-> AN -4 fittings either with a union or bulkhead fitting and nut
to> ring. On an F24 you may have to swing the caliper on the bottom
allow> clear pants, the torque plate can mount in about every 45deg to
cheap....ain't> this.
try> gonna happen. There are none of these in the junk yards. You can
had..the> but good luck. I have found one set that Preferred Airparts
were> rotors were wasted, brgs rusted,and who knows what the wheels
the> like...think of the hamfisted nut behind that heavy 310 smacking
on> tarmac...there's a reason it was in the junkyard!!! The cost of
on a> state
had> F-24?
off> plenty of
> Another asked
in> an Aztec might
nice.> sources or
----------> Thanks..
> > C-FDWS Christavia
of Service.> YAHOO! GROUPS LINKS
1/9/06>
'David the information the Cleveland conversion is in the letter I sent you.
Sent: Tuesday, January 10, 2006 8:40 PM
Subject: [fairchildclub] Cleveland wheels and brakes again
asked
Aztec might
and it sounds
or
Thanks..
> C-FDWS Christavia
John Amundsen
'Has anyone tried the Navajho tire/brake system? There might be a few more of those around.
Sent: Wednesday, January 11, 2006 7:29 AM
Kit # 199-64
tire size 6.50 -10
Chrome disc NA
Lining #066-03300
assemblies.
not trying to
just not familiar
> C-FDWS Christavia
> From: ranger440c5
the
rotated
needs to
centered
this
have
Desoto,Chrysler
out
or
seal
yourself.
fit
takes
and o-
to
allow
> this.
cheap....ain't
try
had..the
were
the
on
please
> state
on a
> F-24?
had
> plenty of
> Another asked
off
> an Aztec might
in
> sources or
nice.
> Thanks..
> > C-FDWS Christavia
> YAHOO! GROUPS LINKS
of Service.
1/9/06
YAHOO! GROUPS LINKS
ranger440c5
'Dunno. The key is what type axle? The wheel must be the big
bearing/little bearing. This (we'll call it "tapered" for clarity)
axle type was the standard thru maybe the late
50's...Howards,warbirds, PT's of all types, Wacos, Fairchilds,
Staggerwings, T50's, 195s, Stinsons,early 310s, twin bo's, Queenairs.
Then straight axles came into vogue...common inner/outer bearing.
Does not a Navajo have straight axles? If so there is no way to
mount the wheel. You have to get a wheel that mounts to the tapered
axle. Cleveland was not really a player when tapered axles were
standard on new airplanes. So these were equipped with Hayes/Autofan
drum&shoe, Bendix drum& shoe, Hayes/Goodrich drum & expander tube,
Goodyear multidisc ring piston(pre war), or Goodyear floating rotor.
As Cleveland began to rise they became the standard but really only
after everything began to morph into straight axles. To service older
aircraft, Cleveland developed conversion kits.
After the wheel stumbling block there is the torque plate. You need
to match the old bolt pattern, offset, seal journal clearance, and
mount bolt size. The tapered axle does not allow much fiddling with
the wheel positioning, hence why the axle is moved as per Mr.Spriggs
337. On newer straight axle applications, you just adjust the seal
collar to space the wheel. So it would seem you should machine new
straight axles (this is essentially what Waco Classic is doing,
except they change the flange for the torque plate as well). Great,
now we can pick any of a thousand wheels...but
what about the torque plate? What fits? The 310 torque plate appears
to be the only bolt on piece that will work. So now will that torque
plate work with the wheel/caliper chosen? On top of that, for
certified, you will still have to take your homebrew unengineered
(ever read the 337 referanced in Mr. Spriggs 337...wow, some one
calculated loads) collection of parts to the FSDO for a blk 3
signoff. It all becomes a quagmire and is much easier to follow Mr.
Spriggs 337 and pony up the bucks.
Of course you can spend half and properly overhaul the existing
expander tube system. I personally never had a moments trouble with
them once given an end to end, methodical overhaul.
--- In fairchildclub@yahoogroups.com, "John Amundsen"
few more of those around.>
seals,> ----- Original Message -----
> From: ranger440c5
> Kit # 199-64
> tire size 6.50 -10
> Chrome disc NA
> Lining #066-03300
> assemblies.
plate,> snap rings, hub cap, rotor,etc.
entry> axle nut, key washer, cotter pin, tires, tubes, grease, hose,
the> fitting to caliper, fluid, and air for the tubes.
keywasher,> tubes, hoses, torque plate mounting hardware, axle nut,
win> cotter pin, grease, fluid, and air.
with> other than any paperwork issues that might arise when dealing
the> various FSDO's for the blk3 337 signoff , but of course, you get
may be> 337 approved first before spending money. The only other issue
I'm> not trying to
be> just not familiar
The> other possibilities.
> > C-FDWS Christavia
> > From: ranger440c5
for> > Fairchild uses a big inner/little outer bearing. The spacing
use> the
> rotated
> needs to
> centered
with> this
> have
> Desoto,Chrysler
plate> out
may> > flange with no ordeal. The bearings slide right on. The seal
axle> or
to> seal
> yourself.
nut> fit
> takes
bottom> and o-
to> to
can> allow
> > this.
> cheap....ain't
smacking> try
> had..the
> were
of> the
the> > admission here is $2025 at Aircraft Spruce(they get them from
than> > jobber price and I don't think you are getting in for less
sprinkle> > $1700. So for all those who don't have any Pixie dust to
anyone> on
brakes> please
> > state
start.> on a
> > F-24?
> had
> > plenty of
something> > Another asked
310/210> off
> > an Aztec might
help> > relationship and it sounds
really> in
> > sources or
----> nice.
> > Thanks..
> > > C-FDWS Christavia
Terms> ----------
> > YAHOO! GROUPS LINKS
----> of Service.
Date:> ----------
reservation> 1/9/06
----------> Fairchild Jet plane Pedal plane
